Here's my code for testing one out that I wrote up a while ago under IDE -0022. Should work under -0023 also.
IDE 1.0 made changes, you will have to tweak the Wire.x commands for it to work.
Test of RTC DS1307 via I2C.
Counts
Seconds,
Minutes,
Hours,
Date of the Month,
Month,
Day of the week, and
Year with Leap-Year
56 bytes battery backed RAM
Square Wave Output, can connect to INT2/D6 or PD7
// use F0xx, F1xx,F2xx, F3xx, F4xx, F5xx, F6xx, F7xx from IDE's serial port window
// use F0xx to send one register write commands to set the seconds. Upper bit must be 0 to enable counting.
// F1xx for minutes,
// F2xx for hours,
// F3xx for day_week,
// F4 for date_month,
// F5 for month,
// F6 for year,
// F7 for square wave
#include <Wire.h>
//variables
byte seconds_address = 0x00;
byte seconds; // bit 7 = Clock Halt, Enabled = 0, Halt = 1
// bits 6-5-3 = tens of seconds 0-6, bits 3-2-1-0 = units of seconds, 0-9
byte minutes_address = 0x01;
byte minutes; // bits 6-5-4 = tens of minutes, bits 3-2-1-0 = units of minutes
byte hours_address = 0x02;
byte hours; // 7=0. 6 = 1 for 12 hr, 0 for 24 hr.
// bit 5: 12 hr mode = AM(0)/PM(1). 24 hr mode = upper tens of hrs
// bit 4 = lower tens of hrs, bits 3-2-1-0 = units of hours (0-9)
byte day_week_address = 0x03;
byte day_week = 0; // range 01-07
byte date_month_address = 0x04;
byte date_month = 0; // range 01-31
byte month_address = 0x05;
byte month = 0; // range 01-12
byte year_address = 0x06;
int year = 0; // upper byte 0-9, lower byte 0-9
byte square_address = 0x07;
byte sqwe = 0; // square wave enable
// Out-0-0-Sqwe-0-0-RS1-RS0
// Out, Sqwe = 0/0 - Square wave output = 0
// Out, Sqwe = 1/0 - Square wave output = 1
// Out, Sqwe = 0/1 or 1/1 - Square wave output per RS1/RS0
// RS1/RS0 = 00 = 1 Hz
// RS1/RSo = 01 = 4 KHz
// RS1/RS0 = 10 = 8 KHz
// RS1/RS0 = 11 = 32 KHz
byte RTC_ram_address = 0x08; //range = 08-63, 0x08-0x3F
int RTC_address = 0x68; // 1101 000
byte incomingCommand = 0;
byte RTC_write_command = 0;
byte RTC_read_command = 0;
byte RTC_ram_command = 0;
byte incomingRegister = 0;
byte RTC_register = 0;
byte incomingData1 = 0;
byte incomingData2 = 0;
byte new_data = 0;
byte outgoingData = 0;
int delay_time = 100;
unsigned long currentMillis = 0;
unsigned long previousMillis = 0;
unsigned long duration = 5000;
Wire.begin(); // no address, we are master
Serial.begin (57600);
Serial.flush();
currentMillis = millis();
if (Serial.available() >3){
incomingCommand = Serial.read();
incomingRegister = Serial.read();
incomingData1 = Serial.read();
incomingData1 = incomingData1 - 0x30; // convert ASCII to HEX
incomingData2 = Serial.read();
incomingData2 = incomingData2 - 0x30; // convert ASCII to HEX
new_data = (incomingData1 << 4) + incomingData2; // put the Upper/Lower nibbles together
Serial.print ("command ");
Serial.println (incomingCommand);
Serial.print ("register ");
Serial.println(incomingRegister);
Serial.print ("data1 ");
Serial.println (incomingData1, HEX);
Serial.print ("data2 ");
Serial.println (incomingData2, HEX);
Serial.print ("combined data ");
Serial.println (new_data, HEX);
// RTC_write_command = incomingCommand & 0xF0; // mask off high byte
// if (RTC_write_command == 0xF0){ // check for Write command
if ((incomingCommand == 'F') | (incomingCommand == 'f')){
incomingCommand = 0; // reset for next pass
// RTC_register = incomingCommand & 0x0F; // mask off low btye
// incomingCommand = 0;
// new_data = incomingData;
Serial.println (" Sending a command ");
// switch (RTC_register){
switch (incomingRegister){
case '0': // write seconds
Serial.println ("Seconds ");
Wire.beginTransmission(RTC_address); // select device
Wire.send(seconds_address); // queue the register
Wire.send(new_data); // queue data
Wire.endTransmission(); // send it
delay (delay_time);
case '1': // write minutes
Serial.println ("Minutes ");
Wire.send(minutes_address); // queue the register
delay (delay_time);
case '2': // write hours
Serial.println ("Hours ");
Wire.send(hours_address); // queue the register
delay (delay_time);
case '3': // write day
Serial.println ("Day ");
Wire.send(day_week_address); // queue the register
delay (delay_time);
case '4': // write date of month
Serial.println ("Day of Month ");
Wire.send(date_month_address); // queue the register
delay (delay_time);
case '5': // write month
Serial.println ("Month ");
Wire.send(month_address); // queue the register
delay (delay_time);
case '6': // write year
Serial.println ("Year ");
Wire.send(year_address); // queue the register
delay (delay_time);
case '7': // write square wave
Serial.println ("Square Wave ");
Serial.println (RTC_register, HEX);
Wire.send(square_address); // queue the register
delay (delay_time);
case '8': // write RAM
Serial.print ("RAM ");
Wire.send(RTC_ram_address); // queue the register
delay (delay_time);
// all others,do nothing
Serial.println ("Invalid command ");
} // end Switch
} // end if command == 'F'
if ( (currentMillis - previousMillis) >= duration){
// Reset the register pointer
Wire.send(0x00);
Wire.requestFrom(RTC_address,8 );
seconds = Wire.receive();
minutes = Wire.receive();
hours = Wire.receive();
day_week = Wire.receive();
date_month = Wire.receive();
year = Wire.receive();
sqwe = Wire.receive();
// Seconds
// Hours
Serial.print ("Hrs " );
Serial.print (hours, HEX);
Serial.print (" Mins ");
Serial.print (minutes, HEX);
Serial.print (" Secs ");
Serial.print (seconds, HEX);
Serial.print (" Day ");
Serial.print (day_week, HEX);
Serial.print (" Date ");
Serial.print (date_month, HEX);
Serial.print (" Month ");
Serial.print (month, HEX);
Serial.print (" Year 20");
Serial.print (year, HEX);
Serial.print (" Square Wave ");
Serial.println (sqwe, HEX);
