I2c -> Arduino - > KnX
Hallo, ich hab eine schöne Variante online gefunden mein Lüftungsanlage mit i2C bus auf denn knx zu bekommen. Ich bekomme werte vom i2C auf den KNX, aber wenn ich vom knx auf den i2c bus sende kommt keine veränderungen. Vielleicht kann mir wer helfen?
  Board: Arduino/Genuino Micro
// Include Arduino Wire library for I2C
#include <Wire.h>
#include <KnxTpUart.h>
// some addresses for the two buses we service
#define I2C_SLAVE_ADDR 42
#define KNX_HW_ADDR "1.1.201"
#define KNX_GA_LEVEL_SET "18/1/1"
#define KNX_GA_LEVEL_STAT "18/1/2"
#define KNX_GA_POWER_SET "18/1/3"
#define KNX_GA_POWER_STAT "18/1/4"
#define KNX_GA_SCHEDULED_SET "18/1/5"
#define KNX_GA_SCHEDULED_STAT "18/1/6"
#define MEASUREMENT_INTERVAL 60000  // interval between bursts of KNX measurements updates (milliseconds)
#define BUTTON_DELAY 700            // delay between successive button commands for a sequence of level up/down commands
#define WHEEL_DELAY 50              // time between successive i2c packets for a wheel button command
#define CHANGED_POWER_VENT 1
#define CHANGED_SCHEDULED 2
#define CHANGED_LEVEL 4
#define CRC_POLY 0x49  // generator of the 8-bit crc
// button codes
#define BUTTON_DOWN 0x01
#define BUTTON_UP 0x02
#define BUTTON_POWER_VENT 0x0c
// #define PRINT_SERIAL 1  // enable debug printout via uart/usb
byte ledVal = 0;           // current LED state for blinking when there's i2c activity
uint32_t last = 0;         // timestamp of last KNX update
uint32_t last_button = 0;  // timestamp of last i2c button packet we sent
// pre-defined buffer for the button packets. the last two bytes
// (button code and checksum) are filled in as needed
byte button_packet[] = { 0xe3, 0x30, 0x20, 0x00, 0x00, 0x00, 0x00 };
// a measurement record -- glueing a register number from the i2c packet to the corresponding
// KNX group address and the scaling factor
struct Measurement {
  byte reg;    // register number
  String ga;   // group address
  byte scale;  // divisor for scaling the fixed-point decimal value
const byte MAX_REG = 0x55 + 1;  // number of registers in 0..MAX_REG-1
const byte N_MEAS = 34;         // number of measurerements to observe
byte changed = 0;  // bit-mask of changed measurements
Measurement measurements[N_MEAS] = {
  { 0x00, "18/1/11", 10 },  // I13 Henpunktextraktluft
  { 0x01, "18/1/12", 10 },  // I14 Schewpunktluft
  { 0x06, "18/1/13", 10 },  // I9 Temperaturluft
  { 0x07, "18/1/14", 10 },  // I10 Temperaturluft
  { 0x08, "18/1/15", 10 },  //      I2 Ablufttemperatur
  { 0x09, "18/1/16", 10 },  // I11 Temperaturluft
  { 0x0e, "18/1/17", 10 },  // I12 rel. Feuchtigkeitsluft
  { 0x0f, "18/1/18", 10 },  //       I3 Relative Feuchtigkeit Abluft
  { 0x10, "18/1/19", 1 },   // I16 sügend Luftstrom, berechnet
  { 0x11, "18/1/20", 1 },   // I18 Abluftstrom, berechnet
  { 0x14, "18/1/21", 10 },  // I15 Antriebsstromluftventilator
  { 0x15, "18/1/22", 10 },  //  I17 Antriebsluftlüfter
  { 0x16, "18/1/23", 1 },   //  I19 Strom vor Heizung
  { 0x1e, "18/1/24", 1 },   //   	P6 	m3/h
  { 0x1f, "18/1/25", 1 },   //   	P7 	m3/h
  { 0x20, "18/1/26", 1 },   //   	P8 	m3/h
  { 0x21, "18/1/27", 1 },   //   	P9 	m3/h
  { 0x50, "18/1/28", 1 },   //  I21 Fanbetriebszeit
  { 0x51, "18/1/29", 1 },   //  I20 Lüftanlagebetriebszeit
  { 0x5a, "18/1/30", 1 },   //        Filter Betriebsdauer
  { 0x4d, "18/1/31", 1 },   //  P10 	Pa
  { 0x53, "18/1/32", 1 },   //  P11 	Pa
  { 0x54, "18/1/33", 1 },   //  P12 	Pa
  { 0x55, "18/1/34", 1 },   //  P13 	Pa
byte registers[MAX_REG];      // easy lookup of records in `measurements` from a register number
int16_t values[N_MEAS] = {};  // the actual values of the measurements above
// status determined from the display state those are essentially bools,
// but allowing for `-1` to indicate unknown/uninitialised states
struct Status {
  int8_t power_vent;  // if power-venting is enabled (level 3)
  int8_t scheduled;   // if the device runs on a schedule (timer symbol)
  int8_t level;       // currently active ventilation level
byte stat_changed = 0;
Status stat = { -1, -1, -1 };  // initialising as `-1` (unknown)
const byte DIGIT_0 = 0x3f;  // 7-segment encoded `0`
const byte DIGIT_1 = 0x06;  // 7-segment encoded `1`
const byte DIGIT_2 = 0x5b;  // 7-segment encoded `2`
const byte DIGIT_3 = 0x4f;  // 7-segment encoded `3`
// requested status changes
int8_t target_level = -1;
bool set_scheduled = false;
KnxTpUart knx(&Serial1, KNX_HW_ADDR);  //KnxTpUart
  pinMode(LED_BUILTIN, OUTPUT);
#ifdef PRINT_SERIAL
  Serial.println("starting ...");
#endif
  Serial1.begin(19200, SERIAL_8E1);
  knx.uartReset();
  knx.addListenGroupAddress(KNX_GA_LEVEL_SET);
  knx.addListenGroupAddress(KNX_GA_POWER_SET);
  knx.addListenGroupAddress(KNX_GA_SCHEDULED_SET);
  for (byte i = 0; i < MAX_REG; i++) {
    registers[i] = 0x00;
  for (byte i = 0; i < N_MEAS; i++) {
    byte idx = measurements[i].reg;
    registers[idx] = i + 1;
  Wire.begin(I2C_SLAVE_ADDR);
  TWAR = (I2C_SLAVE_ADDR << 1) | 1;  // listen for broadcasts -- all i2c messages are sent using "general calls"
  Wire.onReceive(receiveEvent);
// i2c handler
void receiveEvent(int howMany) {
  byte data[28];
  Wire.readBytes(data, howMany);
  if (howMany == 7 and data[0] == 0xe3 and data[1] == 0x20) {
    byte reg = data[3];
    if (reg < MAX_REG) {
      byte idx = registers[reg];
      if (idx) {
        idx--;
        values[idx] = (data[4] << 8) + data[5];
        changed |= (1 << idx);
  if (howMany == 28) {
    int8_t power_vent = (bool)(data[26] & 0x01);
    int8_t scheduled = (bool)(data[15] & 0x01);
    if (power_vent != stat.power_vent) {
      stat.power_vent = power_vent;
      stat_changed |= CHANGED_POWER_VENT;
    if (scheduled != stat.scheduled) {
      stat.scheduled = scheduled;
      stat_changed |= CHANGED_SCHEDULED;
    // only read fan level when the "home screen" is shown
    if ((data[20] & 0x04) or (bool)(data[19] & 0x10)) {
      byte digit = data[8];
      int8_t level;
      if (digit == DIGIT_1) {
        level = 1;
      } else if (digit == DIGIT_2) {
        level = 2;
      } else if (digit == DIGIT_3) {
        level = 3;
        level = 0;
      if (level != stat.level) {
        stat.level = level;
        stat_changed |= CHANGED_LEVEL;
byte crc8(byte crc, byte* data, int len) {
  while (len--) { crc = crc8_push_byte(crc, *data++); }
  return crc;
byte crc8_push_byte(byte crc, byte data) {
  crc ^= data;
  for (int i = 0; i < 8; i++) {
    if ((crc & 0x80) != 0) {
      crc = (byte)((crc << 1) ^ CRC_POLY);
      crc <<= 1;
  return crc;
void send_button(byte code, byte count) {
  digitalWrite(LED_BUILTIN, ledVal ^= 1);
  button_packet[5] = code;
  button_packet[6] = crc8_push_byte(0, code);
  for (byte i = 0; i < count; i++) {
    if (i != 0) { delay(WHEEL_DELAY); }
    send_cmd(button_packet);
void send_cmd(byte* cmd) {
  Wire.beginTransmission(0);  // start i2c broadcast (general call)
  Wire.write(cmd, 7);
  Wire.endTransmission();
  uint32_t now = millis();
  // send changed measurements to KNX
  if (now - last >= MEASUREMENT_INTERVAL) {
    last = now;
    long mask = changed;
    changed = 0;
      if (mask & 1) {
        Measurement mmnt = measurements[i];
        String ga = mmnt.ga;
#ifdef PRINT_SERIAL
        Serial.print(ga);
        Serial.print(" ");
        Serial.println((float)values[i] / mmnt.scale);
#endif
        knx.groupWrite2ByteFloat(ga, (float)values[i] / mmnt.scale);
      mask >>= 1;
  int8_t stat_mask = stat_changed;
  stat_changed = 0;
  if (stat_mask & CHANGED_POWER_VENT) {  // power_vent
#ifdef PRINT_SERIAL
    Serial.print("POWER VENT ");
    Serial.println(stat.power_vent);
#endif
    knx.groupWriteBool(KNX_GA_POWER_STAT, stat.power_vent);
  if (stat_mask & CHANGED_SCHEDULED) {  // scheduled
#ifdef PRINT_SERIAL
    Serial.print("SCHEDULED ");
    Serial.println(stat.scheduled);
#endif
    knx.groupWriteBool(KNX_GA_SCHEDULED_STAT, stat.scheduled);
  if (stat_mask & CHANGED_LEVEL) {  // level
#ifdef PRINT_SERIAL
    Serial.print("LEVEL ");
    Serial.println(stat.level);
#endif
    knx.groupWrite1ByteInt(KNX_GA_LEVEL_STAT, stat.level);
  // read KNX telegrams and adjust targets
  if (Serial1.available() > 0) {
    KnxTpUartSerialEventType eType = knx.serialEvent();
    if (eType == KNX_TELEGRAM) {
      KnxTelegram* telegram = knx.getReceivedTelegram();
      String target =
        String(0 + telegram->getTargetMainGroup()) + "/" + String(0 + telegram->getTargetMiddleGroup()) + "/" + String(0 + telegram->getTargetSubGroup());
      if (telegram->getCommand() == KNX_COMMAND_WRITE) {
        if (target == KNX_GA_LEVEL_SET) {
          int8_t value = telegram->get1ByteIntValue();
          if ((value >= 0) and (value <= 2)) { target_level = value; }
        } else if (target == KNX_GA_POWER_SET) {
          if (telegram->getBool() != stat.power_vent) { send_button(BUTTON_POWER_VENT, 1); }
        } else if (target == KNX_GA_SCHEDULED_SET) {
          bool value = telegram->getBool();
          if ((bool)value != (bool)stat.scheduled) {
            if (value) {
              set_scheduled = true;
              target_level = stat.level;
  // to get to the requested targets, send one level change at a time and wait BUTTON_DELAY ms before sending the next
  if (now - last_button >= BUTTON_DELAY) {
    if ((!stat.scheduled and (target_level == stat.level)) or (set_scheduled and stat.scheduled)) {
      target_level = -1;
    } else if ((target_level > -1) or set_scheduled) {
      byte code;
      if (set_scheduled) {
        code = BUTTON_UP;
      } else if ((stat.scheduled == 1) or (target_level < stat.level)) {
        code = BUTTON_DOWN;
      } else if (target_level > stat.level) {
        code = BUTTON_UP;
      send_button(code, 2);
    last_button = millis();
Kannst Du das nochmal allgemeinverständlich schreiben? Was ist ein KNX und wer soll sich ändern?
KNX ist ein Bussystem in der Elektroinstallation
Mach dir doch hier mal ein Serial.print rein um überhaupt zu prüfen, ob Daten ankommen.
Danke, probiere ich heute mal.
Dein Code wirft unter anderem eine Warnung:
/tmp/arduino_modified_sketch_719963/sketch_nov27b.ino:313:18: warning: 'code' may be used uninitialized in this function [-Wmaybe-uninitialized]
/tmp/arduino_modified_sketch_719963/sketch_nov27b.ino:304:12: note: 'code' was declared here/home/user1/arduino-1.8.19/portable/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -R .eeprom /tmp/arduino_build_640692/sketch_nov27b.ino.elf /tmp/arduino_build_640692/sketch_nov27b.ino.hex
       byte code;
Ich verstehe nicht, warum man hier das Stringkonstrukt braucht.
     String target =
Das wird Dir vermutlich das Genick brechen.
Lass Dir target auf dem SerMon ausgeben.
Und wenn Du der Meinung bist, dass der genauso aussieht wie Du erwartest, dann vergleiche das mal Wert für Wert in HEX mit Deiner Vergleichsvariablen.
Danke für die Unterstützung, muss mich erst mal zurecht finden. Ist Neuland für mich da ich normal nur KNX mache.
Die werte vom KNX kommen an, aber werden nicht zur Lüftung gesendet
Dann musst du wohl weiter debuggen. Zusätzliche Serial printe einbauen um zu sehen was ankommt und in welchem "if" das Programm hängt.
Das heißt, Du hast Dir target ausgeben lassen udn festgestellt, dass die Ausgabe mit dem übereinstimmt, was Du erwartest.
Hast Du den zweiten Teil auch gemacht?
Las Dir mal die Länge von target ausgeben.
Ich bin der festen Überzeugung, dass da mehr drin ist, als Du tatsächlich siehst.
