Nano-Every: I've been working with the Nano-Every. I have attempted to use Wire.setClock() method but watching on an oscilloscope sees no change in clock rate. It stays at 100khz regardless of what I set. Even for the standard rates. I'm working on an old legacy application that uses a nonstandard max clock speed of 25khz. Any ideas on how I can drive that down? I notice that some other processors have a timer register but I haven't found any for the Nano Every.
twi.c is forcing the minimum clock rate to 100kHz:
void TWI_MasterSetBaud(uint32_t frequency){
// Formula is: BAUD = ((F_CLKPER/frequency) - F_CLKPER*T_RISE - 10)/2;
// Where T_RISE varies depending on operating frequency...
// From 1617 DS: 1000ns @ 100kHz / 300ns @ 400kHz / 120ns @ 1MHz
uint16_t t_rise;
if(frequency < 200000){
frequency = 100000;
t_rise = 1000;
} else if (frequency < 800000){
frequency = 400000;
t_rise = 300;
} else if (frequency < 1200000){
frequency = 1000000;
t_rise = 120;
frequency = 100000;
t_rise = 1000;
uint32_t baud = ((F_CPU_CORRECTED/frequency) - (((F_CPU_CORRECTED*t_rise)/1000)/1000)/1000 - 10)/2;
TWI0.MBAUD = (uint8_t)baud;
It's not clear that 25kHz is possible without changing the CPU clock. The divisor for the clock is only 8bits.
Wire.setClock() method never works properly.
The result of formula must be an integer (if it is same for UNo, nano, mini-pro)
Do the calculation on the opposite side.
Use excel, inputs different values for register, the result frequency is inevitably an integer and select the result frequency most near that you want.
