I am trying to interface a mega with a due per I2C. I have done:
- grounds are shared.
- SCL/SDA on mega 2560 (not 20/21) are connected to SCL1/SDA1 on due. The connection is with 4.7k Ohm resistors (both SCL and SDA) is connected to 3.3 V on both arduinos. Note: SCL/SDA of due (20/21) are connected to an imu bno055 which is working fine.
on mega I do:
#include <Time.h>
#include <DFRobot_sim808.h>
#include <SoftwareSerial.h>
#include <Wire.h>
#include <EasyTransferI2C.h>
EasyTransferI2C ET_GPS_data;
struct SEND_DATA_STRUCTURE{
double GPS_la;
double GPS_lo;
double GPS_alt;
SEND_DATA_STRUCTURE GPS_data;
#define I2C_SLAVE_ADDRESS 9
SoftwareSerial mySerial(PIN_TX,PIN_RX);
DFRobot_SIM808 sim808(&mySerial);
double GPS_la = 0.0;
double GPS_lo = 0.0;
double GPS_alt = 0.0;
#define GPS_Sampling_Time_ms 20
unsigned long currentMillis_GPS = 0;
unsigned long previousMillis_GPS = 0;
void getGPS();
mySerial.begin(9600);
Wire.begin();
// ******** Initialize sim808 module *************
while(!sim808.init())
delay(3000);
if(sim808.attachGPS()){
//Serial.println("Open the GPS power success");
}else{
//Serial.println("Open the GPS power failure");
ET_GPS_data.begin(details(GPS_data), &Wire);
currentMillis_GPS = millis();
if (currentMillis_GPS - previousMillis_GPS > GPS_Sampling_Time_ms) {
getGPS();
sim808.detachGPS();
previousMillis_GPS = currentMillis_GPS;
ET_GPS_data.sendData(I2C_SLAVE_ADDRESS);
GPS_data.GPS_la = GPS_la;
GPS_data.GPS_lo = GPS_lo;
GPS_data.GPS_alt = GPS_alt;
void getGPS(){
while(!sim808.attachGPS()){}
delay(80);
while(!sim808.getGPS()){}
GPS_la = sim808.GPSdata.lat;
GPS_lo = sim808.GPSdata.lon;
GPS_alt = sim808.GPSdata.altitude;
on due:
#include <Arduino.h>
#include <Wire.h>
struct RECEIVE_DATA_STRUCTURE{
double GPS_la;
double GPS_lo;
double GPS_alt;
RECEIVE_DATA_STRUCTURE GPS_data;
double GPS_la = 0.1;
double GPS_lo = 0.1;
double GPS_alt = 0.1;
#define GPS_Sampling_Time_ms 100
Serial.begin(57600);
Wire1.begin(I2C_SLAVE_ADDRESS);
ET_GPS_data.begin(details(GPS_data), &Wire1);
Wire1.onReceive(receive);
if(ET_GPS_data.receiveData()){
GPS_la = GPS_data.GPS_la;
GPS_lo = GPS_data.GPS_lo;
GPS_alt = GPS_data.GPS_alt;
Serial.println(GPS_alt);
without the i2c, both of the boards work fine. What am I doing wrong?
