I2C - Gerneral
Hello everybody, I am new here, but not unskilled.
I see many problems between DUE and I2C.
Is everbody here and say the actually status of this?
Is there a working library to download somewhere?
My Projekt:
I have the LCD16x2 from OLIMEX:
Link: SHIELD-LCD16x2 - Open Source Hardware Board
I will this run on DUE.
OLIMEX can't help. --> ok --> but I have information for register of this.
The next step is running the I2C on DUE. --> connection with LCD16x2
Who can help me? --> maybe a working I2C-scanner for DUE?
I promise, I write all results here, with backgroundinformations.
http://2manyprojects.net/lcd-tutorial
...thank you. I tested and posted.
Hello,
I have a another problem with wire.h , I get the message "No such file or directory" (wire.h).
Normaly easy, but wire.h is installed under ...\Documents\Arduino\libraries\Wire\Wire.h
Installed over ZIP from https://www.resistorpark.com/arduino-wire-library-download/
Who is my problem?
(wire.h)
\Wire\Wire.h
Capitalization is important to the compiler, even if many windows programs will auto-correct for you...
...oh no, yes, you have right, thank you.
