i2C PIC Code 2 Arduino
I have a 7"display but the only examples i find are pic examples (i think)
I ported the SPI version for the display already from that to arduino and that works as expected.
But now i'm busy with the I2C code so i can choose which connection i want. and make a library for it.
I don't know if its necessary but i will use it on my due
but i have a couple of Wire issues i'm not sure off.
I think the only functions which needs to be corrected are the
master_ACK
slave_ACK
IIC_WriteByte
IIC_ReadByte
so i think start en stop voids can be removed
Start() and stop() changed for Wire.beginTransmission(); and Wire.endTransmission();
sbit  	MCU_RST=P2^3;
sbit  	SCL=P1^1;
sbit  	SDA=P1^0;
sbit 	next =P2^7;		//next
bit 	ack;
#define write_data_addr  0x0c  //slave addresses with write data
#define read_data_addr  0x0d  //slave addresses with write data
#define write_cmd_addr  0x0e  //slave addresses with write command
#define read_cmd_addr  0x0f  //slave addresses with read status
//I2C_Init()
void SPI_Init(void)
//	SCL = 1;
//	SDA = 1;
        wire.begin();    //         i think only this line instead of the two above
//start
void start(void)
	SDA=1;
	delay(1);
	SCL=1;
	delay(1);
	SDA=0;
	delay(1);
	SCL=0;
	delay(1);
 //stop
 void stop(void)
	SDA=0;
	delay(1);
	SCL=1;
	delay(1);
	SDA=1;
	delay(1);
	SCL=0;
	delay(1);
//Host sends an ACK
//ack=0  ACKNOWLEDGE  ack=1 NOT ACKNOWLEDGE
void master_ACK(bit acknow)
{	SDA=acknow;
	delay(1);
	SCL=1;
	delay(1);
	SCL=0;
	delay(1);
//Slave sends ACK
void slave_ACK(void)
{uchar i=0;
	delay(1);
	SDA=1;
	delay(1);
	SCL=1;
	delay(1);
	while((SDA==1)&&i<200)i++;
	delay(1);
	SCL=0;
	delay(1);
//*********I2C send byte
void IIC_WriteByte(uchar Byte)
{uchar t;
	for(t=0;t<8;t++)
  	{		delay(1);
	   	SDA=(bit)(Byte & 0x80) ;
	   	Byte <<=1;
	delay(1);
	   	SCL=1;
	delay(1);
	   	SCL=0;
	delay(1);
	slave_ACK();
//*********I2C Read byte
uchar IIC_ReadByte(void)
{uchar t,read_data=0;
	SCL=0;
	delay(1);
	SDA=1;
	delay(1);
	for(t = 0; t < 8; t++)
	{		delay(1);
	 	SCL = 1;
	delay(1);
	 	read_data<<=1;
	 	if(SDA == 1)
	 	read_data=read_data|0x01;
	 	SCL=0;
	master_ACK(ack);
	return read_data;
void LCD_CmdWrite(uchar cmd)
	IIC_WriteByte(0x0e);
	IIC_WriteByte(cmd);
//////////////SPI Write data or  parameter
void LCD_DataWrite(uchar Data)
	IIC_WriteByte(0x0c);
	IIC_WriteByte(Data);
///////////////Read data or  parameter
uchar LCD_DataRead(void)
	uchar Data;
	IIC_WriteByte(0x0d);
	ack=1;
	Data=IIC_ReadByte();
	return Data;
///////////SPI Read  status
uchar LCD_StatusRead(void)
	uchar Data;
	IIC_WriteByte(0x0f);
	ack=1;
	return Data;
Already Thanks
Johan
I have this right now.
But no luck with the screen.
first command i send is a 0x00
which should be acknowledged with a 0x75
i see i get a 0 back but when i disconnect the screen i also receive a 0
void LCD_CmdWrite(unsigned char cmd) {
  Wire.beginTransmission(write_cmd_addr);
  Serial.println(cmd,HEX);
  Wire.write(cmd);
void LCD_DataWrite(unsigned char Data) {
  Wire.beginTransmission(write_data_addr);
  Serial.println(Data,HEX);
  Wire.write(Data);
unsigned char LCD_DataRead(void) {
  unsigned char Data;
  Wire.requestFrom(read_data_addr, 1);
  while (Wire.available())  {
    Data =  Wire.read();
    Serial.println(Data, HEX);  }
  return Data;
////////////////Write command and parameter
void Write_Dir(unsigned char Cmd, unsigned char Data) {
  LCD_CmdWrite(Cmd);
  LCD_DataWrite(Data);
unsigned char LCD_StatusRead(void) {
  unsigned char Data;
    Data =  Wire.read();}
  return Data;
I think i have it. although the screen isn't working yet but i see responces which looks according the datasheet correct.
So if it work i will update this thread with the solution for other users.
