I'm looking for "best practices" when reading data from an I2C device.
I have sample code (for a BNO085 IMU) that does this:
Wire.beginTransmission(CMPS14_ADDRESS); // starts communication with CMPS14
Wire.write(ANGLE_8); // Sends the register we wish to start reading from
Wire.endTransmission();
Wire.requestFrom(CMPS14_ADDRESS, 5);
while((Wire.available() < 5));
angle8 = Wire.read();
My first concern is the while() loop...if there are not 5 bytes available, it's going to hang. Should I add a loop until I get to 5 bytes, and error out if I don't get there after some time?
I was thinking a specific number of cycles, but then I have to consider the implications of delay().
Also, the BNO returns 5 bytes of data for yaw, pitch, and roll, which I'm using. Then there's a string of bytes I don't need (mag/accel/gyro raw output). But I need the next byte, at register 0x1E. So would it be better to read 26 bytes and discard what I don't want, or would it be better to start a new beginTransmission(); write(0x1e); endTransmission() each cycle?
After doing some hex math in my head, it occurs to me that there's a gap between the last the last byte of IMU data (0x17) and the last byte I'm interested in, at 0x1E. So I should probably do two separate beginTransmission() calls, but I'm still interested in what the experts think is the "right way".
