I2C sample code rewriting in Wire
I got stuck in rewriting this in Wire. Following code is for reading data out of the IQS253 chip. I want adapt the code, so it is then implemented against the Wire library. Can somebody please help me?
unsigned char i2c_read_byte(unsigned char ack)
  unsigned char i, receive_byte = 0;
  I2C_DATA_IN_FLOAT;     // Set I2C DATA pin as input and floating
  wait(2);               // Wait two I2C clock cycles
  for (i = 8; i > 0; i--) // Loop and read 8 bits from I2C DATA pin
    I2C_CLK_IN_FLOAT;    // Set I2C CLK pin as input and floating
    while(!I2C_CLK_IN);  // Wait for I2C CLK line low (clock stretching)
    if (I2C_DATA_IN) receive_byte |= (1 << (i - 1)); //Read data from I2C DATA pin
    wait(1);             // Wait one I2C clock cycle
    I2C_CLK_OUT_PP_LOW;  // Set I2C CLK pin as output (push-pull) and floating
  if (ack == 0) I2C_DATA_IN_FLOAT; //
  else I2C_DATA_OUT_PP_LOW; //Send acknowledge if required
  while(!I2C_CLK_IN);    // Wait for I2C CLK pin low (clock stretching)
  return receive_byte;
This is more or less what Wire.read()'s function is, although the actual code is part of Wire.requestFrom().
This code is a software implementation of the I2C bus if you don’t have hardware support for it. The Wire library uses the hardware support the ATmega family offers.
Hi pylon,
Thank you for your answer. I saw that I posted the wrong code snippet. The datasheet tells to handle readings as follows: - Send control byte with LSB = 0 - Send memory address - Generate restart - Send control byte with LSB = 1 - Read register value
How can this be done with Wire?
Screenshot of the relevant section in the datasheet: http://www.picfront.org/d/8RO6
This is a standard I2C behavior. So it’s more or less:
#define DEVICE_ADDRESS 0x47 // just an example, has to be changed for actual device
byte get_register(byte memory_address) {
  Wire.beginTransmission(DEVICE_ADDRESS);
  Wire.write(memory_address);
  Wire.endTransmission();
  Wire.requestFrom(DEVICE_ADDRESS, 1);
  if (Wire.available() > 0) {
    return Wire.read();
  return 0;
The low-level stuff is handled by the Wire library and the underlying hardware. As in your example code control byte is device_address << 1 and here DEVICE_ADDRESS is control byte >> 1, you can directly set the device address (which is 7-bit).
Unfortunately the code does not work. There's always a "0" returning. Where do I have to write the control bytes? And how can a repeated start be done?
Which one? Mine? That wasn't intended to work, it was just an example. For example the address was just a random number. You have to modify or at least provide a link to the datasheet of your device, so we have a chance to get the necessary information.
The control bytes are the address plus read/write bit, so they are in the code already.
Does that mean a start condition without a stop condition? Else you have to define it.
Now it works. I didn't know that read/write bits are set by the library. Another problem was the endTransmission. In Arduino v1.0.1 this method can be called with the false flag. So no stop condition is sent.
Device address is 0x44.
  Wire.endTransmission(false);
    return Wire.read();
  return 0;
Thanks again for your help.
