Hello!
I have had some issues using the PCF8574 GPIO Pin expander chip ([link])(PCF8574N Texas Instruments | Integrated Circuits (ICs) | DigiKey)), so to help troubleshoot I have been trying to find its address using the following I2C scanner scripts.
#include <Wire.h>
Wire.begin();
while (!Serial);
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for (address = 1; address < 127; ++address) {
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0) {
Serial.print("I2C device found at address 0x");
if (address < 16) {
Serial.print("0");
Serial.print(address, HEX);
Serial.println(" !");
++nDevices;
} else if (error == 4) {
Serial.print("Unknown error at address 0x");
if (address < 16) {
Serial.print("0");
Serial.println(address, HEX);
if (nDevices == 0) {
Serial.println("No I2C devices found\n");
Serial.println("done\n");
delay(5000); // wait 5 seconds for the next scan
I always get "No I2C device found"
I have tried this same script with the Adafruit PCF8574 Breakout Board and I get an address of 0x20 so I know the script works just not with the IC.
I have tried swapping out the chip itself so it isn't a chip defect.
I have used SCL and SDA on the Arduino Uno as well as A4 and A5.
I have 10k pull-up resistors on SDA and SCL.
I have tried a power supply of 3.3V and 5V.
My address lines are tied to ground.
I have tried adding by-pass and coupling capacitors.
This is the breadboard setup I have:
