i2cmaster library problem
** I2CMASTER , NOT I2CMAX
hello.
i am trying to make this project and repair my batteries SMBus Laptop Battery "Hacker" with phi_prompt LCD user interface - Exhibition / Gallery - Arduino Forum
first , there is was problems on sketch. i repair it. then i2cmax named library give error
error is ;
I2C\twimaster.c.o: In function `i2c_init':
C:\Users\ugur\Documents\Arduino\libraries\I2C/twimaster.c:31: multiple definition of `i2c_init'
I2C\i2cmaster.S.o:(.text+0x10): first defined here
I2C\twimaster.c.o: In function `i2c_start':
C:\Users\ugur\Documents\Arduino\libraries\I2C/twimaster.c:42: multiple definition of `i2c_start'
I2C\i2cmaster.S.o:(.text+0x1a): first defined here
I2C\twimaster.c.o: In function `i2c_start_wait':
C:\Users\ugur\Documents\Arduino\libraries\I2C/twimaster.c:78: multiple definition of `i2c_start_wait'
I2C\i2cmaster.S.o:(.text+0x36): first defined here
I2C\twimaster.c.o: In function `i2c_rep_start':
C:\Users\ugur\Documents\Arduino\libraries\I2C/twimaster.c:130: multiple definition of `i2c_rep_start'
I2C\i2cmaster.S.o:(.text+0x22): first defined here
I2C\twimaster.c.o: In function `i2c_stop':
C:\Users\ugur\Documents\Arduino\libraries\I2C/twimaster.c:141: multiple definition of `i2c_stop'
I2C\i2cmaster.S.o:(.text+0x4a): first defined here
I2C\twimaster.c.o: In function `i2c_write':
C:\Users\ugur\Documents\Arduino\libraries\I2C/twimaster.c:161: multiple definition of `i2c_write'
I2C\i2cmaster.S.o:(.text+0x5a): first defined here
I2C\twimaster.c.o: In function `i2c_readAck':
C:\Users\ugur\Documents\Arduino\libraries\I2C/twimaster.c:182: multiple definition of `i2c_readAck'
I2C\i2cmaster.S.o:(.text+0x96): first defined here
I2C\twimaster.c.o: In function `i2c_readNak':
C:\Users\ugur\Documents\Arduino\libraries\I2C/twimaster.c:197: multiple definition of `i2c_readNak'
I2C\i2cmaster.S.o:(.text+0x92): first defined here
i2cmaster.h
#ifndef _I2CMASTER_H
#define _I2CMASTER_H   1
* Title:    C include file for the I2C master interface
*           (i2cmaster.S or twimaster.c)
* Author:   Peter Fleury <pfleury@gmx.ch>  http://jump.to/fleury
* File:     $Id: i2cmaster.h,v 1.10 2005/03/06 22:39:57 Peter Exp $
* Software: AVR-GCC 3.4.3 / avr-libc 1.2.3
* Target:   any AVR device
* Usage:    see Doxygen manual
#ifdef DOXYGEN
 @defgroup pfleury_ic2master I2C Master library
 @code #include <i2cmaster.h> @endcode
 @brief I2C (TWI) Master Software Library
 Basic routines for communicating with I2C slave devices. This single master
 implementation is limited to one bus master on the I2C bus.
 This I2c library is implemented as a compact assembler software implementation of the I2C protocol
 which runs on any AVR (i2cmaster.S) and as a TWI hardware interface for all AVR with built-in TWI hardware (twimaster.c).
 Since the API for these two implementations is exactly the same, an application can be linked either against the
 software I2C implementation or the hardware I2C implementation.
 Use 4.7k pull-up resistor on the SDA and SCL pin.
 Adapt the SCL and SDA port and pin definitions and eventually the delay routine in the module
 i2cmaster.S to your target when using the software I2C implementation !
 Adjust the  CPU clock frequence F_CPU in twimaster.c or in the Makfile when using the TWI hardware implementaion.
 @note
    The module i2cmaster.S is based on the Atmel Application Note AVR300, corrected and adapted
    to GNU assembler and AVR-GCC C call interface.
    Replaced the incorrect quarter period delays found in AVR300 with
    half period delays.
 @author Peter Fleury pfleury@gmx.ch  http://jump.to/fleury
 @par API Usage Example
  The following code shows typical usage of this library, see example test_i2cmaster.c
 @code
 #define Dev24C02  0xA2      // device address of EEPROM 24C02, see datasheet
 int main(void)
     unsigned char ret;
     i2c_init();                             // initialize I2C library
     // write 0x75 to EEPROM address 5 (Byte Write)
     i2c_start_wait(Dev24C02+I2C_WRITE);     // set device address and write mode
     i2c_write(0x05);                        // write address = 5
     i2c_write(0x75);                        // write value 0x75 to EEPROM
     i2c_stop();                             // set stop conditon = release bus
     // read previously written value back from EEPROM address 5
     i2c_rep_start(Dev24C02+I2C_READ);       // set device address and read mode
     ret = i2c_readNak();                    // read one byte from EEPROM
     i2c_stop();
     for(;;);
 @endcode
#endif /* DOXYGEN */
#if (__GNUC__ * 100 + __GNUC_MINOR__) < 304
#error "This library requires AVR-GCC 3.4 or later, update to newer AVR-GCC compiler !"
#endif
#include <avr/io.h>
/** defines the data direction (reading from I2C device) in i2c_start(),i2c_rep_start() */
#define I2C_READ    1
/** defines the data direction (writing to I2C device) in i2c_start(),i2c_rep_start() */
#define I2C_WRITE   0
 @brief initialize the I2C master interace. Need to be called only once
 @param  void
 @return none
extern void i2c_init(void);
 @brief Terminates the data transfer and releases the I2C bus
 @param void
 @return none
extern void i2c_stop(void);
 @brief Issues a start condition and sends address and transfer direction
 @param    addr address and transfer direction of I2C device
 @retval   0   device accessible
 @retval   1   failed to access device
extern unsigned char i2c_start(unsigned char addr);
 @brief Issues a repeated start condition and sends address and transfer direction
extern unsigned char i2c_rep_start(unsigned char addr);
 If device is busy, use ack polling to wait until device ready
 @return   none
extern void i2c_start_wait(unsigned char addr);
 @brief Send one byte to I2C device
 @param    data  byte to be transfered
 @retval   0 write successful
 @retval   1 write failed
extern unsigned char i2c_write(unsigned char data);
 @brief    read one byte from the I2C device, request more data from device
 @return   byte read from I2C device
extern unsigned char i2c_readAck(void);
 @brief    read one byte from the I2C device, read is followed by a stop condition
extern unsigned char i2c_readNak(void);
 Implemented as a macro, which calls either i2c_readAck or i2c_readNak
 @param    ack 1 send ack, request more data from device
               0 send nak, read is followed by a stop condition
extern unsigned char i2c_read(unsigned char ack);
#define i2c_read(ack)  (ack) ? i2c_readAck() : i2c_readNak();
#endif
And the problematic twimaster.h
* Title:    I2C master library using hardware TWI interface
* File:     $Id: twimaster.c,v 1.3 2005/07/02 11:14:21 Peter Exp $
* Target:   any AVR device with hardware TWI
* Usage:    API compatible with I2C Software Library i2cmaster.h
#include <inttypes.h>
#include <compat/twi.h>
/* define CPU frequency in Mhz here if not defined in Makefile */
#ifndef F_CPU
#define F_CPU 4000000UL
#endif
/* I2C clock in Hz */
#define SCL_CLOCK  100000L
 Initialization of the I2C bus interface. Need to be called only once
void i2c_init(void)
  /* initialize TWI clock: 100 kHz clock, TWPS = 0 => prescaler = 1 */
  TWSR = 0;                         /* no prescaler */
  TWBR = ((F_CPU/SCL_CLOCK)-16)/2;  /* must be > 10 for stable operation */
}/* i2c_init */
  Issues a start condition and sends address and transfer direction.
  return 0 = device accessible, 1= failed to access device
unsigned char i2c_start(unsigned char address)
    uint8_t   twst;
	// send START condition
	TWCR = (1<<TWINT) | (1<<TWSTA) | (1<<TWEN);
	// wait until transmission completed
	while(!(TWCR & (1<<TWINT)));
	// check value of TWI Status Register. Mask prescaler bits.
	twst = TW_STATUS & 0xF8;
	if ( (twst != TW_START) && (twst != TW_REP_START)) return 1;
	// send device address
	TWDR = address;
	TWCR = (1<<TWINT) | (1<<TWEN);
	// wail until transmission completed and ACK/NACK has been received
	if ( (twst != TW_MT_SLA_ACK) && (twst != TW_MR_SLA_ACK) ) return 1;
	return 0;
}/* i2c_start */
 If device is busy, use ack polling to wait until device is ready
 Input:   address and transfer direction of I2C device
void i2c_start_wait(unsigned char address)
    uint8_t   twst;
    while ( 1 )
    	if ( (twst != TW_START) && (twst != TW_REP_START)) continue;
    	TWDR = address;
    	if ( (twst == TW_MT_SLA_NACK )||(twst ==TW_MR_DATA_NACK) )
    	    /* device busy, send stop condition to terminate write operation */
	        TWCR = (1<<TWINT) | (1<<TWEN) | (1<<TWSTO);
	        // wait until stop condition is executed and bus released
	        while(TWCR & (1<<TWSTO));
    	    continue;
    	//if( twst != TW_MT_SLA_ACK) return 1;
}/* i2c_start_wait */
 Return:  0 device accessible
unsigned char i2c_rep_start(unsigned char address)
    return i2c_start( address );
}/* i2c_rep_start */
void i2c_stop(void)
    /* send stop condition */
}/* i2c_stop */
  Input:    byte to be transfered
  Return:   0 write successful
            1 write failed
unsigned char i2c_write( unsigned char data )
    uint8_t   twst;
	// send data to the previously addressed device
	TWDR = data;
	if( twst != TW_MT_DATA_ACK) return 1;
	return 0;
}/* i2c_write */
 Read one byte from the I2C device, request more data from device
 Return:  byte read from I2C device
	TWCR = (1<<TWINT) | (1<<TWEN) | (1<<TWEA);
    return TWDR;
}/* i2c_readAck */
 Read one byte from the I2C device, read is followed by a stop condition
    return TWDR;
}/* i2c_readNak */
how i can fix it ?
how i can fix it ?
We need to see the corresponding source files and the sketch.
sketch is too long , i will give link directy
library is this ;
http://homepage.hispeed.ch/peterfleury/i2cmaster.zip
sketch is this ;
http://forum.arduino.cc/index.php?action=dlattach;topic=62955.0;attach=3389
The i2cmaster.S and twimaster.c files provide the same functions. You can use one or the other but not both. Look at the makefile samples provided.
sorry , i dont understand
where will write "or" ?
There is no 'or' to be written. DO NOT COMPILE twimaster.c and i2cmaster.S TOGETHER THEY DEFINE THE SAME FUNCTIONS. REMOVE THE i2cmaster.S FILE FROM THE LIBRARY FOLDER. Read the documentation that comes with the I2C Master library.
i have do it
but sketch doesnt compiling properly
Sketch uses 3.138 bytes (9%) of program storage space. Maximum is 32.256 bytes.
Global variables use 103 bytes (5%) of dynamic memory, leaving 1.945 bytes for local variables. Maximum is 2.048 bytes.
That looks to me like it compiled properly. Why do you think it didn't?
