I2S_STD_CONFIG_T help
I am new to this and am trying to make a Bluetooth speakers for work and I am having issues understanding what is needed to get this code working. Right now I am stuck on the communication format how am I suppose to fill this in. I keep getting error: expected primary-expression before 'handle' and expected primary-expression before 'const'
bool intI2S(int _bclk, int _lrclk, int _din) {
  static const i2s_std_config_t i2s_config = {
    .mode = i2s_role_t(I2S_ROLE_MASTER),  //Work as host, only transmit data
    .sample_rate = _sampleRate,
    .bits_per_sample = 16,        // 16 bits per sample
    .channel_format = 2,        // 2-channels
    .communication_format = i2s_channel_init_std_mode(i2s_chan_handle_t handle, const i2s_std_config_t *std_cfg);  // I2S communication I2S Philips standard, data launch at second BCK
    .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,        // Interrupt level 1
    .dma_buf_count = 4,        // number of buffers, 128 max.
    .dma_buf_len = 400,        // size of each buffer, AVRC communication may be affected if the value is too high.
    .use_apll = false,        // For the application of a high precision clock, select the APLL_CLK clock source in the frequency range of 16 to 128 MHz. It’s not the case here, so select false.
    .tx_desc_auto_clear = true;
A snippet is of no use. Show a complete sketch that demonstrates the problem; show the complete error message in <CODE/> tags. Tell us what board this is being compiled for. Tell us which libraries you're using.
I know there is other issues with the code this is an example l am using from github
#include <Arduino.h>
#include <esp_bt_main.h>  // Bluetooth
#include <esp_bt_device.h>
#include <esp_gap_bt_api.h>
#include <esp_a2dp_api.h>    // Bluetooth A2DP protocol
#include <esp_avrc_api.h>    // Bluetooth AVRC protocol
#include <driver/i2s_std.h>  // I2S communication
const int bclk = 25;
const int lrclk = 26;
const int din = 27;
uint8_t remoteAddress[6];  // address of the connected remote Bluetooth device
float _volume = 1.0;          // change the coefficient of audio signal volume
int32_t _sampleRate = 44100;  // I2S communication frequency
bool _avrcConnected = false;  // AVRC connection status
String _metadata = "";  // metadata
uint8_t _metaFlag = 0;  // metadata refresh flag
                     Setup And Loop
void setup(void) {
  // Initialize I2S
  if (!intI2S(bclk, lrclk, din)) {
    Serial.println("Initialize I2S failed !");
  // Initialize bluetooth
  if (!initBluetooth("counstomAmplifier")) {
    Serial.println("Initialize bluetooth failed !");
  // 详细参见: https://github.com/espressif/esp-idf/blob/master/components/bt/host/bluedroid/api/include/api/esp_avrc_api.h
  esp_avrc_ct_send_metadata_cmd(6, ESP_AVRC_MD_ATTR_TITLE);  // request metadata from remote Bluetooth device via AVRC command
  delay(3000);
                           Init
    .communication_format = i2s_channel_init_std_mode(i2s_chan_handle_t handle, const i2s_std_config_t *std_cfg),  // I2S communication I2S Philips standard, data launch at second BCK
    .tx_desc_auto_clear = true};
static const i2s_std_config_t pin_config = {
  .bck_in_25 = bclk,   // serial clock (SCK), aka bit clock (BCK)
  .ws_in_26 = lrclk,   // word select (WS), i.e. command (channel) select, used to switch between left and right channel data
  .data_out_27 = din,  // serial data signal (SD), used to transmit audio data in two's complement format
  //  .data_in_num = I2S_PIN_NO_CHANGE   // Not used
if (i2s_std_driver_install(I2S_NUM_0, &pin_config, 0, NULL)) {
  Serial.println("Install and start I2S driver failed !");
  return false;
if (i2s_set_pin(I2S_NUM_0, &pin_config)) {
  Serial.println("Set I2S pin number failed !");
  return false;
return true;
bool initBluetooth(const char *_btName) {
  // Initialize bluedroid
  if (!btStarted() && !btStart()) {
    Serial.println("Initialize controller failed");
    return false;
  esp_bluedroid_status_t bt_state = esp_bluedroid_get_status();
  if (bt_state == ESP_BLUEDROID_STATUS_UNINITIALIZED) {
    if (esp_bluedroid_init()) {
      Serial.println("Initialize bluedroid failed !");
      return false;
  if (bt_state != ESP_BLUEDROID_STATUS_ENABLED) {
    if (esp_bluedroid_enable()) {
      Serial.println("Enable bluedroid failed !");
      return false;
  if (esp_bt_gap_set_device_name(_btName)) {
    Serial.println("Set device name failed !");
    return false;
  // Initialize AVRCP
  if (esp_avrc_ct_init()) {
    Serial.println("Initialize the bluetooth AVRCP controller module failed !");
    return false;
  if (esp_avrc_ct_register_callback(avrcCallback)) {  // non-essential, callback for Bluetooth AVRC protocol
    Serial.println("Register application callbacks to AVRCP module failed !");
    return false;
  // Initialize A2DP
  if (esp_a2d_sink_init()) {
    Serial.println("Initialize the bluetooth A2DP sink module failed !");
    return false;
  if (esp_a2d_register_callback(a2dpCallback)) {  // non-essential, callback for Bluetooth A2DP protocol
    Serial.println("Register application callbacks to A2DP module failed !");
    return false;
  if (esp_a2d_sink_register_data_callback(audioDataProcessCallback)) {  // required, callback for processing data received by Bluetooth
    Serial.println("Register A2DP sink data output function failed !");
    return false;
  // Set discoverability and connectability mode for legacy bluetooth.
  if (esp_bt_gap_set_scan_mode(ESP_BT_CONNECTABLE, ESP_BT_GENERAL_DISCOVERABLE)) {
    Serial.println("Set discoverability and connectability mode for legacy bluetooth failed !");
    return false;
  return true;
                           Callback Function
// This callback function is required to transfer the audio stream data received by Bluetooth to the amplifier via I2S, the audio stream data can be processed here.
// Refer to: https://github.com/espressif/esp-idf/blob/master/examples/bluetooth/bluedroid/classic_bt/a2dp_sink/main/main.c
void audioDataProcessCallback(const uint8_t *data, uint32_t len) {
  int16_t *data16 = (int16_t *)data;  // convert to 16-bit sample data
  int16_t processedData;              // store the processed audio data
  int count = len / 2;                // the number of audio data in int16_t to be processed
  size_t i2s_bytes_write = 0;         // i2s_write() the variable storing the number of data to be written
  for (int i = 0; i < count; i++) {
    processedData = (int16_t)((*data16) * _volume);  // change the volume of audio data
    data16++;
    i2swrite(I2S_NUM_0, &processedData, 2, &i2s_bytes_write, 10);  // transfer audio data to the amplifier via I2S
// Non-required, callback for Bluetooth AVRC protocol, some events are triggered by sending the corresponding command
// e.g. metadata request event: esp_avrc_ct_send_metadata_cmd(num, type);   // request metadata from remote Bluetooth device via AVRC command
void avrcCallback(esp_avrc_ct_cb_event_t event, esp_avrc_ct_cb_param_t *param) {
  esp_avrc_ct_cb_param_t *rc = (esp_avrc_ct_cb_param_t *)(param);
  switch (event) {
    /*!< metadata response event */
    case ESP_AVRC_CT_METADATA_RSP_EVT:
        char *attr_text = (char *)malloc(rc->meta_rsp.attr_length + 1);
        memcpy(attr_text, rc->meta_rsp.attr_text, rc->meta_rsp.attr_length);
        attr_text[rc->meta_rsp.attr_length] = 0;
        _metadata = String(attr_text);
        _metaFlag = rc->meta_rsp.attr_id;
        Serial.print("_metadata : ");
        Serial.println(_metadata);
        // Serial.println(rc->meta_rsp.attr_id);
        free(attr_text);
    /*!< connection state changed event */
    case ESP_AVRC_CT_CONNECTION_STATE_EVT:
        /*!< connection established */
        _avrcConnected = rc->conn_stat.connected;
        if (_avrcConnected) {
          uint8_t *p = rc->conn_stat.remote_bda;
          Serial.print("remoteAddress : ");
          for (uint8_t i = 0; i < 6; i++) {
            remoteAddress[i] = *(p + i);
            Serial.print(remoteAddress[i], HEX);
            Serial.print("-");
          /*!< disconnecting remote device */
          memset(remoteAddress, 0, 6);
    /*!< passthrough response event */
    case ESP_AVRC_CT_PASSTHROUGH_RSP_EVT:
    /*!< notification event */
    case ESP_AVRC_CT_CHANGE_NOTIFY_EVT:
    /*!< feature of remote device indication event */
    case ESP_AVRC_CT_REMOTE_FEATURES_EVT:
    /*!< supported notification events capability of peer device */
    case ESP_AVRC_CT_GET_RN_CAPABILITIES_RSP_EVT:
    /*!< play status response event */
    case ESP_AVRC_CT_PLAY_STATUS_RSP_EVT:
    /*!< set absolute volume response event */
    case ESP_AVRC_CT_SET_ABSOLUTE_VOLUME_RSP_EVT:
    default:
      // "unhandled AVRC event: %d", event
// Non-required, callback for Bluetooth A2DP protocol, some events are triggered by sending the corresponding command.
void a2dpCallback(esp_a2d_cb_event_t event, esp_a2d_cb_param_t *param) {
  esp_a2d_cb_param_t *a2d = (esp_a2d_cb_param_t *)(param);
  switch (event) {
     * Audio codec is configured, only used for A2DP SINK
     * @brief ESP_A2D_AUDIO_CFG_EVT
     * struct a2d_audio_cfg_param {
     *     esp_bd_addr_t remote_bda;              /*!< remote bluetooth device address
     *     esp_a2d_mcc_t mcc;                     /*!< A2DP media codec capability information
     * } audio_cfg;                               /*!< media codec configuration information
    case ESP_A2D_AUDIO_CFG_EVT:
     * Connection state changed event
     * @brief  ESP_A2D_CONNECTION_STATE_EVT
     * struct a2d_conn_stat_param {
     *     esp_a2d_connection_state_t state;      /*!< one of values from esp_a2d_connection_state_t
     *     esp_a2d_disc_rsn_t disc_rsn;           /*!< reason of disconnection for "DISCONNECTED"
     * } conn_stat;                               /*!< A2DP connection status
    case ESP_A2D_CONNECTION_STATE_EVT:
    /*!< audio stream transmission state changed event */
    case ESP_A2D_AUDIO_STATE_EVT:
    /*!< acknowledge event in response to media control commands */
    case ESP_A2D_MEDIA_CTRL_ACK_EVT:
    /*!< indicate a2dp init&deinit complete */
    case ESP_A2D_PROF_STATE_EVT:
    default:
      // "a2dp invalid cb event: %d", event
You were asked to do four things.
You did one.
I've got better things to do than beg you for the information you should have provided up front. Good-bye.
To hell with this crappy community nothing but jerks and smart alecks. NOBODY is any help here.
You've made zero effort to provide the information anyone needs to help you. Exactly which ESP32 are you compiling for? Which version of the ESP32 Arduino Core? Where did you get this code since you obviously didn't write it yourself? Provide a link. Which version of the ESP32 Arduino Core was the person who wrote the code using?
The documentation for ESP32 I2S is here: https://docs.espressif.com/projects/esp-idf/en/stable/esp32/api-reference/peripherals/i2s.html#introduction
There is example code here: https://github.com/espressif/esp-idf/tree/v5.4/examples/peripherals/i2s
The read your mind magicians are on a different forum.
In order to solve your Arduino issue information is needed really not difficult. The people here are very good and for a not for profit setup you can get great results here. But with out the right information you would choke on the possible results if everyone guessed answers.
A little maturity would help you on some of your other issues.
