IC to read Voltage Level
I'm looking for an IC that I can drop into an Arduino project to measure the voltage level of a battery. The battery voltage will often be higher than an Arduino or it's power regulator can handle, so I'm looking for an IC that is dedicated to this purpose.
Does such an IC exist?
Thanks!
You don't need an IC, you can use two resistors to make a potential divider.
Choose resistor values so that the voltage going to the Arduino analogue input is always less than 5V, and then multiply the voltage measured by a scaling factor for the resistor values chosen.
Yes it is a ICL7135 a four and a half digit DVM.
How high? Most ICs run off 5V and you will need to pot the input down to this with most things.
Am I able to use this?
To read a voltage? No.
It seems that that board can measure current as well as voltage, with 12bit resolution.
The chip also calculates power.
Leo..
It says that the device can handle up to 3A. Would 200A blow it out or destroy it?
Yes.
And if you are playing about with a 200A power supply with your current knowledge of electronics then it is a triumph of optimism over expectation.
http://hypertextbook.com/facts/2000/AronFisch.shtml
Just trying to get a simple voltage monitor set up for my volunteer ambulance service, so we can ensure that our EMT's never run to an ambulance with a dead battery.
Please, please, please, give me some guidance.
Anyone have any advice here? I've been doing some reading that Zener diodes may be a good fit here? How would I configure the circuit? I think I need two resistors to step down the voltage and current to something the Arduino can handle, and then measure the voltage, and I need the Zener diode (along with another resistor) to send the voltage/current to ground when it goes past a certain point. Does that make sense?
You seem to have ignored the reply you received from JohnLincoln.
Sorry, you're right. I read that, but I forgot to write back that I still had a question on that: is it possible to choose resistors capable of handling the voltage spikes, while at the same time still being able to provide me with the "true" voltage of the battery that I can read with the Arduino?
osmosis311:
You can use quite high values of resistor for your voltage divider, say over 10kΩ. The resistors will easily withstand voltage spikes that may occur. The question is whether the input of your Arduino will withstand spikes above the Arduino's Vcc (including when its Vcc is zero) and spikes below ground. In another recent thread on this subject contributors claimed that the voltage divider will protect the Arduino and that is almost certainly true (if the resistor values are over say 10kΩ).
osmosis311:
Can you elaborate on that part please? What exactly is it we're hoping to end up with here?
Something like this
I think I'm officially lost.
Me tooo.
Why use an Arduino to measure car batery voltage (unless you want to use it for other tasks).
You can pick up a 2-wire LED voltage module from ebay for a few dollars.
Arduino can measure a car battery voltage with ~15-20mV resolution (steps) with two resistors.
If you choose the values correctly, you don't need zeners. Zeners leak and add non-linearity.
A 10k/22k voltage divider protects the arduino to 38volt (1mA input protection diode current).
Adding a 100n cap from input pin to ground eleminates spikes.
Another question was if the module from post #3 was able to measure a few hundred amps.
Sure. Try connecting the two current terminals across a piece of battery wire.
0.001ohm cable resistance can measure 320A. Use an oline wire resistance calculator.
Leo..
Wawa:
Arduino can measure a car battery voltage with ~15-20mV resolution (steps) with two resistors. If you choose the values correctly, you don't need zeners.
Exactly. And if all this is an exercise to determine if the battery is flat or not, we don't really care about resolution anyway. Given the dividers in Crossroad's example... well, if the zener does end up conducting, you'll find you have problems way bigger than a blown arduino. Besides, if this is an ambulance, isn't there some sort of isolation/protection/bus seperation built in already? I find it hard to believe that anyone would run equipment right off of 12V rail?
edit: sorry, posting mishap
Thanks for all the guidance here guys, really appreciate it!
I'm using an Arduino for this project, connected to an Adafruit FONA (GSM board; eventually a Particle Electron), so that when the voltage gets "too low" it will automatically sent a text message alerting someone to come and start it / charge it up.
I'm going to try and use an Adafruit INA219 Current Sensor (INA219 High Side DC Current Sensor Breakout - 26V ±3.2A Max [STEMMA QT] : ID 904 : $9.95 : Adafruit Industries, Unique & fun DIY electronics and kits) and see if that works.
After watching several Youtube videos of people who have built automotive voltage sensors, I'm not convinced that these 200V spikes are something that I really need to worry about.
