Hello
I'm not used to using ESP8266 yet.
I tried to print the value of the sensor to the web server using this. Now I'm going to try to save the sensor's value in the database. I tried this by looking at a number of examples, but the connection kept failing.
Below are my php code and arduino code.
<?php
$servername = '127.0.0.1'; //localIP
$username = 'root';
$password = 'PASSWORD';
$dbName = 'sensordata'; //Database name
$conn = mysqli_connect($servername, $username, $password, $dbname);
$temp = $_GET['temp'];
$humidity = $_GET['humidity'];
$sql = "INSERT INTO sensor2(temperature, humidity) VALUES($temp, $humidity)"; //Insert data to table
mysqli_query($conn, $sql);
mysqli_close($conn);
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPClient.h>
#include "Adafruit_SHTC3.h"
#include "Adafruit_SI1145.h"
const char* ssid = "V Pro";
const char* password = "PASSWORD";
String host = "169.254.225.148"; //WiFi IP
const long interval = 5000;
unsigned long previousMillis = 0;
WiFiServer server(80);
WiFiClient client;
HTTPClient http;
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
Serial.println("");
Serial.print("Connecting to ");
Serial.println(ssid);
Serial.print("IP address: ");
Serial.println(WiFi.localIP()); //169.254.225.148
server.begin();
Serial.println("Server started");
//send data 5sec
if(currentMillis - previousMillis >= interval) {
float humidity = 1.1; //send data test
float temp = 2.2;
//data send to DB thouth php
String phpHost = host+"/insert.php?temp="+String(temp)+"&humidity="+String(humidity);
Serial.print("Connect to ");
Serial.println(phpHost);
http.begin(client, phpHost);
http.setTimeout(1000); //update for 1sec
int httpCode = http.GET();
if(httpCode > 0) {
Serial.printf("GET code : %dnn", httpCode);
if(httpCode == HTTP_CODE_OK) {
String payload = http.getString();
Serial.println(payload);
else {
Serial.printf("GET failed, error: %sn", http.errorToString(httpCode).c_str());
http.end();
// Web server
client = server.available();
if(!client) return;
Serial.println("New client");
client.setTimeout(5000);
String request = client.readStringUntil('r');
Serial.println("request: ");
Serial.println(request);
while(client.available()) {
client.read();
float temp = 2.2;
client.print("HTTP/1.1 200 OK");
client.print("Content-Type: text/htmlrnrn");
client.print("<!DOCTYPE HTML>");
client.print("<html>");
client.print("<head>");
client.print("<meta charset="UTF-8" http-equiv="refresh" content="1">");
client.print("<title>Senrsor test Webpage</title>");
client.print("</head>");
client.print("<body>");
client.print("<h2>Senrsor test Webpage</h2>");
client.print("
client.print("Temperature : ");
client.print(temp);
client.print(" °C");
client.print("
client.print("Humidity : ");
client.print(humidity);
client.print(" %");
client.print("</body>");
client.print("</html>");
Serial.println("Disconnected client");
This is the result of running this.
GET failedm error: connection failed
This is the IP address of the Wi-Fi I connected to.
Connecting to V Pro
IP address: 169.254.225.148
I don't know much about the database and the server yet. The IP address is suspected as the cause of this problem. It's because I've followed many examples, but they've never been connected properly.
Can I get some help with this problem?
Thank you in advance.
