IDE 1.8.19 compile error but same code is OK on IDE 2.1.1 SOLVED!
I have a little Dell Laptop (Win 10) with IDE 1.8.19 installed that I use to load remote processors here on my homestead.
I am getting an error message on the 1.8.19 compile that is not generated on the IDE 2.1.1 on my Windows 11 PC with the very same sketch code.
I emphasized the related code lines for clarity.
Any ideas appreciated,
Ed
Error message:
Arduino: 1.8.19 (Windows 10), Board: "ESP32 Wrover Module, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), QIO, 80MHz, 921600, None, Disabled"
WARNING: library StackString claims to run on avr architecture(s) and may be incompatible with your current board which runs on esp32 architecture(s).
C:\Users\edthe\AppData\Local\Temp\arduino_modified_sketch_558916\Pump_House_Monitor_ver8M.ino: In function 'void loop()':
Pump_House_Monitor_ver8M:162:24: error: operation on 'on_off_cycle_count' may be undefined [-Werror=sequence-point]
     on_off_cycle_count = (++ on_off_cycle_count);
cc1plus.exe: some warnings being treated as errors
Multiple libraries were found for "WiFi.h"
 Used: C:\Users\edthe\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\libraries\WiFi
 Not used: C:\Users\edthe\Arduino 1.8.19 Sketches\libraries\WiFiNINA
 Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
exit status 1
Main code:
#include "hashtag_includes.h"  // see tabs at top
#include "constants.h"
void setTimezone(const char* timezone) {
  Serial.print("Setting Timezone to ");
  Serial.println(timezone);
  setenv("TZ", timezone, 1);
  tzset();
void initTime(const char* timezone) {
  struct tm timeinfo;
  Serial.println("Getting time from NTP server");
  configTime(0, 0, "pool.ntp.org");  // First connect to NTP server, use 0 TZ offset
  if (!getLocalTime(&timeinfo)) {
    Serial.println("  Failed to obtain time");
    return;
  Serial.println("OK, Got the time from NTP");
  setTimezone(timezone);  // then set your timezone
void printLocalTime() {  // this function monitors current time of day to initiate
                         // pump counter reset at midnight
  struct tm timeinfo;
    Serial.println("Failed to obtain time");
    return;
  int time_hour = timeinfo.tm_hour;  // tm structure element "hour" from time.h
  int time_min = timeinfo.tm_min;    //                     "minute"  "    "
  int time_sec = timeinfo.tm_sec;    //                      "second"
  if (time_hour == hour_trigger && time_min == min_trigger && time_sec == sec_trigger) {
    Serial.println("Reset counters...");
    counter_reset = true;
    delay(1000);  // used to avoid conflict as time rolls over to new day
  Serial.println(&timeinfo, "%A, %B %d %Y %H:%M:%S zone %Z %z ");
//  ***************** VOID SETUP ***************
  delay(2000);  // allow voltage stabilization on startup
  startup_Millis = millis();
  pinMode(ONBOARD_LED, OUTPUT);     //  Blink LED function
  pinMode(Alarm_Relay, OUTPUT);     //  Alarm relay
  pinMode(Pressure_Switch, INPUT);  // Alarm Input
  pinMode(Pump_Run_Status, INPUT);  // Spare Dry Contacts on 220v pump contactor
  pinMode(System_Reset, INPUT);     // Reset/clear system alarms
  digitalWrite(Alarm_Relay, LOW);
    Initial_Connect_Attempts++;
    Serial.println("Attempting to Connect To Local Network:   ");
    Serial.println(wifissid);
    WiFi.begin(wifissid, wifipass);
    delay(4000);
    if (Initial_Connect_Attempts == 5) {
      Serial.println("5 LAN connect attempts unsuccessful; going to connectToWifi()");
      connectToWiFi();
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to WiFi network with IP Address: ");
  Serial.println("Attempting to connect to local WPA network...");
  initTime("CST6CDT,M3.2.0,M11.1.0");  // https://sites.google.com/a/usapiens.com/opnode/time-zones
  server.begin();
  // you're connected now, so print out the status:
  Serial.print("WiFi Status:  ");
  Serial.println(WiFi.status());
  Serial.print("ESP Board MAC Address:  ");
  Serial.println(WiFi.macAddress());
  DS18B20.begin();  // initialize the DS18B20 space sensor
  printLocalTime();  // used to determine midnight reset of "daily" pump counters
  current_Millis = millis();
  DS18B20.requestTemperatures();              // send the command to get temperatures
  space_temp_1 = DS18B20.getTempCByIndex(0);  // read temperature in °C
  sp_temp_1F = (space_temp_1 * 9 / 5) + 32;   // convert C to F
  sp_temp_1 = sp_temp_1F + tmp_adj_1;         // sensor calibration
  digitalWrite(ONBOARD_LED, HIGH);  //  Blink for run indicator
  delay(200);
  digitalWrite(ONBOARD_LED, LOW);
  delay(400);
  //              ***************** Pump Run Time Monitor & Alarm/Report Function ********
  pump_run_contacts = digitalRead(Pump_Run_Status);  // spare set of contacts from 220 volt contactor
  if (pump_run_contacts == HIGH) {
    pump_ON = true;
    strcpy(Pump_Status, "ON");
    pump_ON = false;
    strcpy(Pump_Status, "OFF");
  if (pump_ON == true && pump_run_state == false) {
    pump_ON_Millis = current_Millis;
    pump_run_state = true;
  if (pump_ON == true) {
    current_pump_cycle = (current_Millis - pump_ON_Millis);
    current_pump_cycle_sec = (current_pump_cycle / 1000);
    current_pump_cycle_min = (current_pump_cycle_sec / minute);
    // pump_runtime_hours = (pump_runtime_minutes / hour);
    if (current_pump_cycle >= max_pump_runtime) {
      pump_alarm = true;
  if (pump_run_state == true && pump_ON == false) {  // timestamp pump turning off
    pump_OFF_Millis = current_Millis;
    last_pump_cycle_Millis = pump_OFF_Millis - pump_ON_Millis;
    last_pump_cycle_sec = (last_pump_cycle_Millis / 1000);
    daily_run_Millis = (last_pump_cycle_Millis + daily_run_Millis);
    daily_run_seconds = (daily_run_Millis / 1000);
    daily_run_minutes = (daily_run_seconds / minute);
    on_off_cycle_count = (++on_off_cycle_count);
    pump_run_state = false;
    current_pump_cycle_sec = 0;
    current_pump_cycle_min = 0;
  if (counter_reset == true) {  // clear daily counters at midnight
    daily_run_Millis = 0;
    daily_run_seconds = 0;
    daily_run_minutes = 0;
    on_off_cycle_count = 0;
    counter_reset = false;
  if (pump_ON == false) {
    pump_alarm = false;
    // pump_run_state = false;
    //  current_pump_cycle = 0;
    pump_ON_Millis = 0;
  if (pump_alarm == true && pump_alarm_state == false)  // check if pump has ran too long in a cycle
  {                                                     // AND alm state "was" false;
    strcpy(Pump_Alm, "ON");                             // this ensures alm is not repeatedly sent to API.
    pump_alarm_state = true;                            // ie pump alarm has been reported
    sendToPushingBox(DEVID3);                           //  sendToPushingBox(DEVID3);
  //              ***************** Low Water Pressure Alarm Function ********
  pressure_switch_state = digitalRead(Pressure_Switch);  //Pressure Switch Input Pin Read
  if (pressure_switch_state == HIGH) {
    pressure_alarm = true;
    pressure_alarm = false;
  //  ********************* If pressure alarm initiate API msg; turn on audible alarm **********
  if (pressure_alarm == true && press_alarm_state == false)  // check if pressure switch has changed state
  {                                                          // AND alm state "was" false; this ensures alm is not repeatedly sent to API.
    press_alarm_state = true;
    strcpy(Pressure_Alm, "ON");
    sendToPushingBox(DEVID2);
  if (pressure_alarm == false && press_alarm_state == true)  // alarm condition cleared
    press_alarm_state = false;
    strcpy(Pressure_Alm, "OFF");
  if (temp_alarm == true || pressure_alarm == true || pump_alarm == true) {
    bldg_alarm_state = true;
    strcpy(Bldg_Alarm, "ON");
    if (DEBUG) {
      Serial.println("              Building alarm state is true!!!!    ");
      bldg_alarm_state = false;
      strcpy(Bldg_Alarm, "OFF");
  if (bldg_alarm_state == true) {
    digitalWrite(Alarm_Relay, HIGH);
    strcpy(Alm_Relay, "ON");
    if (DEBUG) { Serial.println("           Turn Horn ON & kill pump !!!          "); }
    strcpy(Alm_Relay, "OFF");
  //               ***************** System Alarm Reset/Clear **************
  alarm_reset = digitalRead(System_Reset);  // switch input activated by human operator
  if (alarm_reset == HIGH) {
    bldg_alarm_state = false;  // reset flags & audibles
    pump_alarm = false;
    strcpy(Pump_Alm, "OFF");
    pump_alarm_state = false;
    temp_alarm = false;
    // pump_ON_Millis = 0;
    delay(2000);  // wait 20 seconds to allow pump time to rebuild line pressure
  //               ***************** Low Temp Alarm Function ***************
  if (sp_temp_1 <= Low_Tmp_Alm) {
    temp_alarm = true;
    strcpy(Temp_Alm, "ON");
    temp_alarm = false;
    strcpy(Temp_Alm, "OFF");
  if ((sp_temp_1 > Low_Tmp_Alm + 2) && temp_alarm == true) {
    temp_alarm = false;
  if (temp_alarm == true && temp_alarm_state == false) {
    temp_alarm_state = true;
    sendToPushingBox(DEVID1);  // Send request to PushingBox ONCE when temp alm is true
  if (temp_alarm == false && temp_alarm_state == true)  // Temp alarm is OFF.
    if (DEBUG) { Serial.println("              Pump House Temp Alarm is false / No message sent."); }
    temp_alarm_state = false;
  if (WiFi.status() != WL_CONNECTED && current_Millis - startup_Millis > wait_interval)  //  && millis() - last_Connection_Attempt_At_Ms  > 15000ul )
    WiFi.disconnect();  // last_Connection_Attempt_At_Ms = millis();
    delay(2000);
    delay(4000);
    restart_Flag = true;
    connectToWiFi();
  if (WiFi.status() == WL_CONNECTED && restart_Flag == true) {
    restart_Flag = false;
    server.begin();
  //   ******************** WiFiWebServer Code***********
  WiFiClient client = server.available();  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n')  //     && currentLineIsBlank)
          client.println();
          client.println();
          StackString<50> AString = StackString<50>("                      Pump House");
          client.println(AString.c_str());
          StackString<50> BString = StackString<50>("                      **********");
          client.println(BString.c_str());
          client.println();
          client.println();
          StackString<50> HString = StackString<50>("                  Pump Status =  ");
          HString.append(Pump_Status);
          client.println(HString.c_str());
          client.println();
          StackString<50> KString = StackString<50>(" Current Pump Cycle [seconds] =  ");
          KString.append(current_pump_cycle_sec);
          client.println(KString.c_str());
          client.println();
          client.println();
          StackString<50> LString = StackString<50>(" Current Pump Cycle [minutes] =  ");
          LString.append(current_pump_cycle_min);
          client.println(LString.c_str());
          client.println();
          client.println();
          StackString<50> MString = StackString<50>("    Last Pump Cycle [seconds] =  ");
          MString.append(last_pump_cycle_sec);
          client.println(MString.c_str());
          client.println();
          client.println();
          StackString<50> NString = StackString<50>("Daily Total Runtime [seconds] =  ");
          NString.append(daily_run_seconds);
          client.println(NString.c_str());
          client.println();
          client.println();
          StackString<50> PString = StackString<50>("Daily Total Runtime [minutes] =  ");
          PString.append(daily_run_minutes);
          client.println(PString.c_str());
          client.println();
          client.println();
          StackString<50> OString = StackString<50>("          Daily On-Off Cycles =  ");
          OString.append(on_off_cycle_count);
          client.println(OString.c_str());
          client.println();
          client.println();
          StackString<50> CString = StackString<50>("              Pump House Temp =  ");
          CString.append(sp_temp_1);
          client.println(CString.c_str());
          client.println();
          client.println();
          StackString<50> IString = StackString<50>("               Building Alarm =  ");
          IString.append(Bldg_Alarm);
          client.println(IString.c_str());
          client.println();
          client.println();
          StackString<50> JString = StackString<50>("  Audible Alarm/Pump Shutdown =  ");
          JString.append(Alm_Relay);
          client.println(JString.c_str());
          client.println();
          client.println();
          StackString<50> DString = StackString<50>("          Temp Alarm Setpoint =  ");
          DString.append(Low_Tmp_Alm);
          client.println(DString.c_str());
          client.println();
          client.println();
          StackString<50> EString = StackString<50>("               Low Temp Alarm =  ");
          EString.append(Temp_Alm);
          client.println(EString.c_str());
          client.println();
          client.println();
          StackString<50> FString = StackString<50>("           Low Pressure Alarm =  ");
          FString.append(Pressure_Alm);
          client.println(FString.c_str());
          client.println();
          client.println();
          StackString<50> GString = StackString<50>("           Pump Runtime Alarm =  ");
          GString.append(Pump_Alm);
          client.println(GString.c_str());
    delay(3000);    // give the web browser time to receive the data
    client.stop();  // close the connection:
    Serial.println("client disonnected");
  // this write the response from PushingBox Server.
  // You should see a "200 OK"
  /*     if (client.available())
       if(DEBUG){Serial.print(c);}
  //   if there's no net connection, but there was one last time
  //                through the loop, then stop the client:
  if (!client.connected() && lastConnected) {
    if (DEBUG) { Serial.println(); }
    if (DEBUG) { Serial.println("             disconnecting"); }
    client.stop();
  lastConnected = client.connected();
// **************************** END OF VOID LOOP() ****************************************
void sendToPushingBox(char devid[])  // Function for sending the request to PushingBox
  client.stop();
  delay(2000);
  if (DEBUG) { Serial.println("      connecting..."); }
  if (client.connect(serverName, 80)) {
    if (DEBUG) { Serial.println("     connected"); }
    if (DEBUG) { Serial.println("          sending request to PushingBox API"); }
    client.print("GET /pushingbox?devid=");
    client.print(devid);
    client.println(" HTTP/1.1");
    client.print("Host: ");
    client.println(serverName);
    client.println("User-Agent: ESP32");
    client.println();
    if (DEBUG) { Serial.println("            connection failed"); }
void connectToWiFi() {
  Try_Count = 0;
    Try_Count++;
    WiFi.disconnect();
    vTaskDelay(10000);
    if (Try_Count == 10) {
      Serial.println("..... 10 attempts failed....rebooting processor...");
      ESP.restart();  // reboot processor!!!
  // WiFi.onEvent( WiFiEvent );    > define WiFiEvent to do ???
constants.h:
OneWire oneWire(SENSOR_PIN);
DallasTemperature DS18B20(&oneWire);
int status = WL_IDLE_STATUS;  // the Wifi radio's status
WiFiClient client;
WiFiServer server(80);  // added for testing 2/4
int Initial_Connect_Attempts = 0;
int Try_Count = 0;
char wifissid[18] = "*******";  //     "Homestead-LAN_EXT" for in house testing
char wifipass[13] = "******";           //
char DEVID1[] = "v5A61F203ED29211";  //   token/key low temp alarm    [ v5A61F203ED29211 ]
char DEVID2[] = "v9072310CAE86043";  //   token/key low wtr pressure alarm [ v9072310CAE86043 ]
char DEVID3[] = "va71BBE853590654";  //   pump runtime alarm   [  va71BBE853590654  ]
static uint32_t startup_Millis = millis();  // static uint32_t last_Connection_Attempt_At_Ms = millis();
static uint32_t current_Millis = 0;
static uint32_t wait_interval = 300000;  // 5 minutes of no wifi connection
signed long hour = 3600000;              // 3,600,000 millis per hr
signed long minute = 60;                 // 60,000 millis per minute
static uint32_t pump_ON_Millis = 0;
static uint32_t pump_OFF_Millis = 0;
signed int last_pump_cycle_Millis = 0;
signed int last_pump_cycle_sec = 0;
signed int daily_run_Millis = 0;
signed int daily_run_seconds = 0;
signed int daily_run_minutes = 0;
signed int current_pump_cycle = 0;
signed int current_pump_cycle_sec = 0;
signed int current_pump_cycle_min = 0;
int on_off_cycle_count = 0;
static uint32_t max_pump_runtime = 300000;  // 5 minutes maximum run time before an alarm*emphasized text*
static bool restart_Flag = false;
boolean DEBUG = true;  // Debug mode     !!!!
boolean currentLineIsBlank = false;  //added 10/31/22 debugging
char serverName[19] = "api.pushingbox.com";  //  [  api.pushingbox.com   ]
//  int keyIndex = 0;       WiFi Communication Parameter      NEEDED????
const int Alarm_Relay = 4;  // Alarm Relay output pinMode(GIOP4/D2, OUTPUT)
int hour_trigger = 23;        // hour to reset pump counters to zero
int min_trigger = 59;         // minute            (23 : 59 : 59)
int sec_trigger = 59;         // second             HR   MIN  SEC
boolean counter_reset = false;
boolean bldg_alm_ON = false;
boolean bldg_alarm_state = false;
boolean temp_alarm = false;
boolean temp_alarm_state = false;
boolean lastConnected = false;
boolean pump_ON = false;
boolean pump_run_state = false;
boolean pump_alarm = false;
//  ************* Low Water Pressure Alm Parameters ***********
const int Pressure_Switch = 25;  // Board Digital Input GIOP25;  pinMode(GIOP#, INPUT);
const int Pump_Run_Status = 18;  // Dig Input for pump run status
const int System_Reset = 21;     // Reset/clear alarms switch input; GPIO21, D21
int pressure_switch_state = 0;
int alarm_reset = 0;
int pump_run_contacts = 0;
boolean pressure_alarm = false;
boolean press_alarm_state = false;
boolean pump_alarm_state = false;
//  ***************** Low Temp Alarm Parameters ***************
char Pump_Status[4] = "OFF";
char Pump_Alm[4] = "OFF";
char Temp_Alm[4] = "OFF";
char Pressure_Alm[4] = "OFF";
char Alm_Relay[4] = "OFF";
char Bldg_Alarm[4] = "OFF";
//    const int B = 4275;                 // B value of the thermistor;  +- 275 = .6 C (1.0 F)
//   const uint32_t R0 = 100000;            // R0 = 100k; int type uint32_t required (unsigned 32 bit)
int tmp_adj_1 = 0;  // sensor 1 calibration adjustment
float space_temp_1;  //    Dallas DS18B20 temp sensor
int sp_temp_1;
float sp_temp_1F;
int Low_Tmp_Alm = 38.00;  // Low Alarm Setpoint
hashtag_includes.h:
#include <SPI.h>
#include <WiFi.h>
#include <math.h>
#include "time.h"
#include <StackString.hpp>  // save memory using this function: character arrays
using namespace Stack;
//    #include <DS18B20.h>
#include <OneWireNg.h>
#include <DallasTemperature.h>
#define SENSOR_PIN 14  // ESP32 pin GPIO14; D14 silkscreen connected to DS18B20
#define ONBOARD_LED 2
Don't know why that's not an error on IDE 2.1.1, but it's definitely wrong. What are you trying to do here?
Increase the cycle count by 1 every time the pump cycles on/off.
It works because the webpage update changes the cycle count after the pump has cycled.
Is my syntax wrong?
Yup. Just do:
on_off_cycle_count++;
or
++on_off_cycle_count;
The ESP32 boards platform is unique in that the compilation result is affected by the setting of Arduino IDE's "Compiler warnings" preference.
Traditionally this preference has only influenced how many warnings we see in the compilation output, but the Arduino boards platform framework allows each platform developer to decide exactly what effect they want each of the levels of this preference to have. The ESP32 developers decided to add the -Werror=all flag to the compilation command when you set the "Compiler warnings" preference to the "More" or "All" levels. This flag causes compilation to fail when the sketch code produces a compilation warning.
So the reason for the different results between the two IDE versions is that you have a different "Compiler warnings" preference setting in each of them.
Good to finally know why that happens with ESP32. Thanks.
Thank you sir.
Hopefully this will appease the compile. Lol...
I appreciate that information you provided. good to know... :+1: :+1:
