Hello, i have downloaded the latest version IDE 2.3.4 and it is stuck with pulsating loading screen. Running windows 11. I need some help ASAP this is my first time downloading the software for our subject Basic Electronics Engineering.
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.4" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.1.1" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-12-03T10:03:03.490Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.4","cliVersion":"1.1.1","buildDate":"2024-12-03T10:03:03.490Z"}
Starting backend process. PID: 3852
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/arias/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-02-02T12:16:51.973Z root INFO Backend Object.initialize: 9.8 ms [Finished 0.812 s after backend start]
2025-02-02T12:16:51.976Z root INFO Backend Object.configure: 8.7 ms [Finished 0.812 s after backend start]
2025-02-02T12:16:51.976Z root INFO Backend s.onStart: 4.7 ms [Finished 0.812 s after backend start]
2025-02-02T12:16:51.977Z root INFO Backend s.configure: 0.4 ms [Finished 0.845 s after backend start]
2025-02-02T12:16:51.977Z root INFO Backend d.onStart: 0.3 ms [Finished 0.845 s after backend start]
2025-02-02T12:16:51.979Z root INFO Backend d.configure: 0.1 ms [Finished 0.845 s after backend start]
2025-02-02T12:16:51.980Z root INFO Backend d.initialize: 32.7 ms [Finished 0.845 s after backend start]
2025-02-02T12:16:51.980Z root INFO Backend c.onStart: 0.3 ms [Finished 0.845 s after backend start]
2025-02-02T12:16:51.981Z root INFO Backend a.configure: 3.5 ms [Finished 0.849 s after backend start]
2025-02-02T12:16:51.983Z config INFO >>> Initializing CLI configuration...
2025-02-02T12:16:51.983Z root INFO Backend c.initialize: 0.7 ms [Finished 0.850 s after backend start]
2025-02-02T12:16:51.983Z root INFO Backend x.onStart: 1.3 ms [Finished 0.850 s after backend start]
2025-02-02T12:16:51.984Z config INFO Loading CLI configuration from c:\Users\arias\.arduinoIDE\arduino-cli.yaml...
2025-02-02T12:16:51.985Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-02-02T12:16:51.985Z root INFO Backend a.initialize: 0.5 ms [Finished 0.852 s after backend start]
2025-02-02T12:16:51.985Z root INFO Backend w.onStart: 1.7 ms [Finished 0.853 s after backend start]
2025-02-02T12:16:51.985Z root INFO Backend r.configure: 2.7 ms [Finished 0.853 s after backend start]
2025-02-02T12:16:51.985Z discovery-log INFO start
2025-02-02T12:16:51.985Z discovery-log INFO start new deferred
2025-02-02T12:16:51.985Z root INFO Backend d.initialize: 0.6 ms [Finished 0.854 s after backend start]
2025-02-02T12:16:51.985Z root INFO Backend y.onStart: 2.8 ms [Finished 0.856 s after backend start]
2025-02-02T12:16:51.985Z root INFO Backend r.configure: 2.4 ms [Finished 0.856 s after backend start]
2025-02-02T12:16:51.986Z root INFO Backend a.onStart: 0.9 ms [Finished 0.858 s after backend start]
2025-02-02T12:16:51.986Z root INFO Backend h.configure: 0.6 ms [Finished 0.858 s after backend start]
2025-02-02T12:16:51.986Z root INFO Backend s.configure: 0.2 ms [Finished 0.858 s after backend start]
2025-02-02T12:16:51.986Z root INFO Backend l.configure: 0.1 ms [Finished 0.859 s after backend start]
2025-02-02T12:16:51.994Z root INFO Theia app listening on http://127.0.0.1:51450.
2025-02-02T12:16:51.994Z root INFO Finished starting backend application: 9.0 ms [Finished 0.867 s after backend start]
2025-02-02T12:16:52.013Z root WARN The local plugin referenced by local-dir:/c%3A/Users/arias/.arduinoIDE/plugins does not exist.
2025-02-02T12:16:52.014Z root WARN The local plugin referenced by local-dir:/c%3A/Users/arias/.arduinoIDE/extensions does not exist.
2025-02-02T12:16:52.014Z root WARN The local plugin referenced by local-dir:C:\Users\arias\.arduinoIDE\plugins does not exist.
2025-02-02T12:16:52.046Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]}}
2025-02-02T12:16:52.046Z config INFO Loading fallback CLI configuration to get 'directories.data' and 'directories.user'
2025-02-02T12:16:52.127Z root INFO Resolve plugins list: 142.2 ms [Finished 0.998 s after backend start]
2025-02-02T12:16:52.294Z daemon INFO time="2025-02-02T20:16:52+08:00" level=info msg="arduino-cli version 1.1.1"
time="2025-02-02T20:16:52+08:00" level=info msg="Using config file: c:\\Users\\arias\\.arduinoIDE\\arduino-cli.yaml"
time="2025-02-02T20:16:52+08:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:51451
{"IP":"127.0.0.1","Port":"51451"}
2025-02-02T12:16:52.294Z daemon INFO Daemon is running.
2025-02-02T12:16:52.296Z config INFO Loaded fallback CLI configuration: {"directories":{"user":"C:\\Users\\arias\\Documents\\Arduino","data":"C:\\Users\\arias\\AppData\\Local\\Arduino15"}}
2025-02-02T12:16:52.296Z config INFO Merged CLI configuration with the fallback: {"directories":{"user":"C:\\Users\\arias\\Documents\\Arduino","data":"C:\\Users\\arias\\AppData\\Local\\Arduino15"},"board_manager":{"additional_urls":[]}}
2025-02-02T12:16:52.296Z config INFO Loaded the CLI configuration.
2025-02-02T12:16:52.321Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/arias/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/arias/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2025-02-02T12:16:52.321Z config INFO Validating the CLI configuration...
2025-02-02T12:16:52.337Z config INFO The CLI config is valid.
2025-02-02T12:16:52.337Z config INFO <<< Initialized the CLI configuration.
2025-02-02T12:16:52.463Z daemon INFO time="2025-02-02T20:16:52+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2025-02-02T12:16:53.694Z root INFO Deploy plugins list: 142.2 ms [Finished 2.567 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2025-02-02T12:16:55.253Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 282.7 ms [Finished 2.921 s after frontend start]
2025-02-02T12:16:55.253Z root WARN A command editor.action.toggleStickyScroll is already registered.
2025-02-02T12:16:55.529Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 117.8 ms [Finished 3.272 s after frontend start]
2025-02-02T12:17:00.251Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error verifying signature: signature expired: is your system clock set correctly?
2025-02-02T12:17:00.270Z daemon INFO time="2025-02-02T20:17:00+08:00" level=info msg="Checking signature" index="C:\\Users\\arias\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\arias\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2025-02-02T12:17:00.273Z daemon INFO time="2025-02-02T20:17:00+08:00" level=info msg="Loading hardware from: C:\\Users\\arias\\AppData\\Local\\Arduino15\\packages"
2025-02-02T12:17:00.275Z daemon INFO time="2025-02-02T20:17:00+08:00" level=info msg="Loading package builtin from: C:\\Users\\arias\\AppData\\Local\\Arduino15\\packages\\builtin"
2025-02-02T12:17:00.275Z daemon INFO time="2025-02-02T20:17:00+08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\arias\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2025-02-02T12:17:00.275Z daemon INFO time="2025-02-02T20:17:00+08:00" level=info msg="Loading tools from dir: C:\\Users\\arias\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2025-02-02T12:17:00.277Z daemon INFO time="2025-02-02T20:17:00+08:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2025-02-02T12:17:00.277Z daemon INFO time="2025-02-02T20:17:00+08:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2025-02-02T12:17:00.278Z daemon INFO time="2025-02-02T20:17:00+08:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2025-02-02T12:17:00.278Z daemon INFO time="2025-02-02T20:17:00+08:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
2025-02-02T12:17:00.278Z daemon INFO time="2025-02-02T20:17:00+08:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2025-02-02T12:17:00.295Z daemon INFO time="2025-02-02T20:17:00+08:00" level=info msg="Loading libraries index file" index="C:\\Users\\arias\\AppData\\Local\\Arduino15\\library_index.json"
2025-02-02T12:17:00.298Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\arias\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2025-02-02T12:17:00.307Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\arias\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2025-02-02T12:17:00.308Z daemon INFO time="2025-02-02T20:17:00+08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\arias\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2025-02-02T20:17:00+08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\arias\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-02-02T12:17:00.309Z daemon INFO time="2025-02-02T20:17:00+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2025-02-02T12:17:00.312Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2025-02-02T12:17:07.164Z daemon INFO time="2025-02-02T20:17:07+08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2025-02-02T12:17:14.269Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error verifying signature: signature expired: is your system clock set correctly?
2025-02-02T12:17:14.279Z daemon INFO time="2025-02-02T20:17:14+08:00" level=info msg="Checking signature" index="C:\\Users\\arias\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\arias\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2025-02-02T12:17:14.280Z daemon INFO time="2025-02-02T20:17:14+08:00" level=info msg="Loading hardware from: C:\\Users\\arias\\AppData\\Local\\Arduino15\\packages"
2025-02-02T12:17:14.284Z daemon INFO time="2025-02-02T20:17:14+08:00" level=info msg="Loading package builtin from: C:\\Users\\arias\\AppData\\Local\\Arduino15\\packages\\builtin"
2025-02-02T12:17:14.284Z daemon INFO time="2025-02-02T20:17:14+08:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\arias\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2025-02-02T20:17:14+08:00" level=info msg="Loading tools from dir: C:\\Users\\arias\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2025-02-02T12:17:14.284Z daemon INFO time="2025-02-02T20:17:14+08:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2025-02-02T12:17:14.284Z daemon INFO time="2025-02-02T20:17:14+08:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2025-02-02T12:17:14.285Z daemon INFO time="2025-02-02T20:17:14+08:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2025-02-02T12:17:14.285Z daemon INFO time="2025-02-02T20:17:14+08:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
2025-02-02T12:17:14.285Z daemon INFO time="2025-02-02T20:17:14+08:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2025-02-02T12:17:14.303Z daemon INFO time="2025-02-02T20:17:14+08:00" level=info msg="Loading libraries index file" index="C:\\Users\\arias\\AppData\\Local\\Arduino15\\library_index.json"
time="2025-02-02T20:17:14+08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\arias\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2025-02-02T20:17:14+08:00" level=info msg="Adding libraries dir" dir="C:\\Users\\arias\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-02-02T12:17:14.303Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\arias\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2025-02-02T12:17:14.306Z root ERROR Uncaught Exception: Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2025-02-02T12:17:14.306Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:777546
at v.evaluateErrorStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:777562)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async a.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:777232)
Closing channel on service path '/services/electron-window'.
Closing channel on service path '/services/ide-updater'.
Stored workspaces roots:
No sketches were scheduled for deletion.
