IDE does not start: "EADDRNOTAVAIL: address not available"
Describe the problem
IDE starts, but does not present the main window
jin@Joy-MBP ~> "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
Arduino IDE 2.3.3
Checking for frontend application configuration customizations. Module path: /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/electron-main.js, destination 'package.json': /Applications/Arduino IDE.app/Contents/Resources/app/package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.3" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.0.4" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-09-25T09:35:36.798Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.3","cliVersion":"1.0.4","buildDate":"2024-09-25T09:35:36.798Z"}
Starting backend process. PID: 5292
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///Users/jin/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-10-22T01:52:38.564Z root INFO Backend Object.initialize: 1.9 ms [Finished 0.273 s after backend start]
2024-10-22T01:52:38.564Z root INFO Backend Object.configure: 1.4 ms [Finished 0.273 s after backend start]
2024-10-22T01:52:38.564Z root INFO Backend a.onStart: 0.7 ms [Finished 0.273 s after backend start]
2024-10-22T01:52:38.565Z root INFO Backend a.configure: 0.1 ms [Finished 0.286 s after backend start]
2024-10-22T01:52:38.565Z root INFO Backend d.onStart: 0.1 ms [Finished 0.286 s after backend start]
2024-10-22T01:52:38.566Z root INFO Backend d.configure: 0.1 ms [Finished 0.286 s after backend start]
2024-10-22T01:52:38.566Z root INFO Backend d.initialize: 13.0 ms [Finished 0.286 s after backend start]
2024-10-22T01:52:38.566Z root INFO Backend c.onStart: 0.1 ms [Finished 0.286 s after backend start]
2024-10-22T01:52:38.566Z root INFO Backend s.configure: 0.5 ms [Finished 0.287 s after backend start]
2024-10-22T01:52:38.567Z config INFO >>> Initializing CLI configuration...
2024-10-22T01:52:38.567Z root INFO Backend c.initialize: 0.2 ms [Finished 0.287 s after backend start]
2024-10-22T01:52:38.567Z root INFO Backend x.onStart: 0.4 ms [Finished 0.287 s after backend start]
2024-10-22T01:52:38.567Z config INFO Loading CLI configuration from /Users/jin/.arduinoIDE/arduino-cli.yaml...
2024-10-22T01:52:38.567Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-10-22T01:52:38.567Z root INFO Backend s.initialize: 0.2 ms [Finished 0.288 s after backend start]
2024-10-22T01:52:38.567Z root INFO Backend w.onStart: 0.5 ms [Finished 0.288 s after backend start]
2024-10-22T01:52:38.567Z root INFO Backend r.configure: 0.9 ms [Finished 0.288 s after backend start]
2024-10-22T01:52:38.567Z discovery-log INFO start
2024-10-22T01:52:38.567Z discovery-log INFO start new deferred
2024-10-22T01:52:38.567Z root INFO Backend d.initialize: 0.2 ms [Finished 0.288 s after backend start]
2024-10-22T01:52:38.567Z root INFO Backend y.onStart: 0.8 ms [Finished 0.289 s after backend start]
2024-10-22T01:52:38.567Z root INFO Backend r.configure: 0.7 ms [Finished 0.289 s after backend start]
2024-10-22T01:52:38.567Z root INFO Backend s.onStart: 0.2 ms [Finished 0.289 s after backend start]
2024-10-22T01:52:38.567Z root INFO Backend h.configure: 0.2 ms [Finished 0.289 s after backend start]
2024-10-22T01:52:38.567Z root INFO Backend a.configure: 0.0 ms [Finished 0.289 s after backend start]
2024-10-22T01:52:38.567Z root INFO Backend l.configure: 0.0 ms [Finished 0.290 s after backend start]
2024-10-22T01:52:38.569Z root ERROR Failed to start the backend application:
2024-10-22T01:52:38.569Z root ERROR Error: listen EADDRNOTAVAIL: address not available 10.53.146.123
    at Server.setupListenHandle [as _listen2] (node:net:1734:21)
    at listenInCluster (node:net:1799:12)
    at GetAddrInfoReqWrap.doListen [as callback] (node:net:1948:7)
    at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:110:8)
2024-10-22T01:52:38.569Z root ERROR Uncaught Exception:  Error: listen EADDRNOTAVAIL: address not available 10.53.146.123
2024-10-22T01:52:38.571Z root WARN The local plugin referenced by local-dir:/Users/jin/.arduinoIDE/plugins does not exist.
2024-10-22T01:52:38.571Z root WARN The local plugin referenced by local-dir:/Users/jin/.arduinoIDE/extensions does not exist.
^CStored workspaces roots:
No sketches were scheduled for deletion.
Could not terminate the backend process. It was not running.
To reproduce
Open the application
Expected behavior
Main window opens
Arduino IDE version
Lastest nightly build and lastest stable, also tested local compile (git head)
Operating system
macOS
Operating system version
12.6
Additional context
Tried removing ~/.arduinoIDE
ifconfig
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
	options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP>
	inet6 ::1 prefixlen 128
	inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
	nd6 options=201<PERFORMNUD,DAD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
anpi0: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
	options=400<CHANNEL_IO>
	ether 1a:8b:30:23:34:7c
	inet6 fe80::188b:30ff:fe23:347c%anpi0 prefixlen 64 scopeid 0x4
	media: none
	status: inactive
anpi2: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
	ether 1a:8b:30:23:34:7e
	inet6 fe80::188b:30ff:fe23:347e%anpi2 prefixlen 64 scopeid 0x5
	media: none
	status: inactive
anpi1: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
	ether 1a:8b:30:23:34:7d
	inet6 fe80::188b:30ff:fe23:347d%anpi1 prefixlen 64 scopeid 0x6
	media: none
	status: inactive
en4: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
	ether 1a:8b:30:23:34:5c
	media: none
	status: inactive
en5: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
	ether 1a:8b:30:23:34:5d
	media: none
	status: inactive
en6: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
	ether 1a:8b:30:23:34:5e
	media: none
	status: inactive
en1: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
	options=460<TSO4,TSO6,CHANNEL_IO>
	ether 36:42:ab:3f:93:80
	media: autoselect <full-duplex>
	status: inactive
en2: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
	ether 36:42:ab:3f:93:84
	status: inactive
en3: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
	ether 36:42:ab:3f:93:88
	status: inactive
ap1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
	ether f2:2f:4b:13:be:76
	media: autoselect
	status: inactive
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
	options=6463<RXCSUM,TXCSUM,TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM>
	ether f0:2f:4b:13:be:76
	inet6 fe80::1c9a:b0e9:e2da:85dd%en0 prefixlen 64 secured scopeid 0xf
	inet 10.53.20.82 netmask 0xffffe000 broadcast 10.53.31.255
	media: autoselect
	status: active
bridge0: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
	options=63<RXCSUM,TXCSUM,TSO4,TSO6>
	Configuration:
		id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
		maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
		root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
		ipfilter disabled flags 0x0
	member: en1 flags=3<LEARNING,DISCOVER>
	        ifmaxaddr 0 port 11 priority 0 path cost 0
	member: en2 flags=3<LEARNING,DISCOVER>
	        ifmaxaddr 0 port 12 priority 0 path cost 0
	member: en3 flags=3<LEARNING,DISCOVER>
	        ifmaxaddr 0 port 13 priority 0 path cost 0
	media: <unknown type>
	status: inactive
awdl0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
	ether de:69:b1:03:e3:bf
	inet6 fe80::dc69:b1ff:fe03:e3bf%awdl0 prefixlen 64 scopeid 0x11
	media: autoselect
	status: active
llw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
	inet6 fe80::dc69:b1ff:fe03:e3bf%llw0 prefixlen 64 scopeid 0x12
	media: autoselect
	status: active
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
	inet6 fe80::ad1b:2a7a:6faf:95dc%utun0 prefixlen 64 scopeid 0x13
utun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
	inet6 fe80::e0e8:68ab:1dc9:ce2f%utun1 prefixlen 64 scopeid 0x14
utun2: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1000
	inet6 fe80::ce81:b1c:bd2c:69e%utun2 prefixlen 64 scopeid 0x15
utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
	inet6 fe80::3365:a83d:1120:8c06%utun3 prefixlen 64 scopeid 0x18
utun4: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
	inet6 fe80::37e4:792f:210b:b2a0%utun4 prefixlen 64 scopeid 0x19
vmenet0: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
	ether 8e:f4:2e:cd:93:f9
	media: autoselect
	status: active
bridge100: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
	options=3<RXCSUM,TXCSUM>
	ether f2:2f:4b:31:9d:64
	inet 10.211.55.2 netmask 0xffffff00 broadcast 10.211.55.255
	inet6 fe80::f02f:4bff:fe31:9d64%bridge100 prefixlen 64 scopeid 0x1b
	inet6 fdb2:2c26:f4e4::1 prefixlen 64
	Configuration:
	member: vmenet0 flags=3<LEARNING,DISCOVER>
	        ifmaxaddr 0 port 26 priority 0 path cost 0
	media: autoselect
	status: active
vmenet1: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
	ether f2:df:68:29:46:08
	media: autoselect
	status: active
bridge101: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
	ether f2:2f:4b:31:9d:65
	inet 10.37.129.2 netmask 0xffffff00 broadcast 10.37.129.255
	inet6 fe80::f02f:4bff:fe31:9d65%bridge101 prefixlen 64 scopeid 0x1d
	inet6 fdb2:2c26:f4e4:1::1 prefixlen 64
	Configuration:
	member: vmenet1 flags=3<LEARNING,DISCOVER>
	        ifmaxaddr 0 port 28 priority 0 path cost 0
	media: autoselect
	status: active
en10: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
	ether d2:d1:71:23:09:95
	inet6 fe80::d0d1:71ff:fe23:995%en10 prefixlen 64 scopeid 0x7
	media: autoselect
	status: active
Issue checklist
  • [x] I searched for previous reports in the issue tracker
  • [x] I verified the problem still occurs when using the latest nightly build
  • [x] My report contains all necessary details
From @joyjin report of the problem in the Arduino IDE 2.x GitHub repository's issue tracker:
https://github.com/arduino/arduino-ide/issues/2536#issuecomment-2428087875
Just let it sit there for 10 minutes and it suddenly went through.
So it sounds like this resolved itself.
@joyjin please add a reply here on the forum thread if the problem comes back. Otherwise I think you are all set to go ahead with using Arduino IDE!
Hello,
This is commenting on the signing up for the forum. The issue is still there.
