IDE hangs on startup: "discovery builtin:serial-discovery not found"
I've gone through a lot of forum posts but still cannot resolve this. The IDE hangs on startup during the splash screen. I've tried fixing the read only issues. I think those may still persist, but I can't change some security settings because this is a corporate system. I will post the log info below. It may just be an issue that has to go to company IT, but I want to cover all options before going to them.
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 23604
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/mpasquar/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-03-14T14:09:41.844Z root INFO Backend Object.initialize: 5.6 ms [Finished 0.669 s after backend start]
2024-03-14T14:09:41.845Z root INFO Backend Object.configure: 4.7 ms [Finished 0.669 s after backend start]
2024-03-14T14:09:41.845Z root INFO Backend s.onStart: 2.5 ms [Finished 0.669 s after backend start]
2024-03-14T14:09:41.846Z root INFO Backend s.configure: 0.4 ms [Finished 0.698 s after backend start]
2024-03-14T14:09:41.847Z root INFO Backend d.onStart: 0.3 ms [Finished 0.698 s after backend start]
2024-03-14T14:09:41.847Z root INFO Backend d.configure: 0.1 ms [Finished 0.698 s after backend start]
2024-03-14T14:09:41.849Z root INFO Backend d.initialize: 28.9 ms [Finished 0.698 s after backend start]
2024-03-14T14:09:41.849Z root INFO Backend c.onStart: 0.3 ms [Finished 0.698 s after backend start]
2024-03-14T14:09:41.849Z root INFO Backend a.configure: 1.8 ms [Finished 0.700 s after backend start]
2024-03-14T14:09:41.851Z config INFO >>> Initializing CLI configuration...
2024-03-14T14:09:41.851Z root INFO Backend c.initialize: 0.7 ms [Finished 0.701 s after backend start]
2024-03-14T14:09:41.852Z root INFO Backend R.onStart: 0.8 ms [Finished 0.701 s after backend start]
2024-03-14T14:09:41.852Z config INFO Loading CLI configuration from c:\Users\mpasquar\.arduinoIDE\arduino-cli.yaml...
2024-03-14T14:09:41.853Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-14T14:09:41.853Z root INFO Backend a.initialize: 0.4 ms [Finished 0.702 s after backend start]
2024-03-14T14:09:41.853Z root INFO Backend w.onStart: 1.4 ms [Finished 0.703 s after backend start]
2024-03-14T14:09:41.853Z root INFO Backend r.configure: 2.2 ms [Finished 0.703 s after backend start]
2024-03-14T14:09:41.853Z discovery-log INFO start
2024-03-14T14:09:41.853Z discovery-log INFO start new deferred
2024-03-14T14:09:41.854Z root INFO Backend d.initialize: 0.5 ms [Finished 0.704 s after backend start]
2024-03-14T14:09:41.854Z root INFO Backend y.onStart: 2.4 ms [Finished 0.706 s after backend start]
2024-03-14T14:09:41.854Z root INFO Backend r.configure: 2.2 ms [Finished 0.706 s after backend start]
2024-03-14T14:09:41.854Z root INFO Backend a.onStart: 0.8 ms [Finished 0.708 s after backend start]
2024-03-14T14:09:41.854Z root INFO Backend h.configure: 0.7 ms [Finished 0.708 s after backend start]
2024-03-14T14:09:41.854Z root INFO Backend s.configure: 0.2 ms [Finished 0.708 s after backend start]
2024-03-14T14:09:41.854Z root INFO Backend l.configure: 0.1 ms [Finished 0.708 s after backend start]
2024-03-14T14:09:41.858Z root INFO Theia app listening on http://127.0.0.1:52495.
2024-03-14T14:09:41.858Z root INFO Finished starting backend application: 4.1 ms [Finished 0.712 s after backend start]
2024-03-14T14:09:42.021Z root WARN The local plugin referenced by local-dir:/c%3A/Users/mpasquar/.arduinoIDE/plugins does not exist.
2024-03-14T14:09:42.021Z root WARN The local plugin referenced by local-dir:/c%3A/Users/mpasquar/.arduinoIDE/extensions does not exist.
2024-03-14T14:09:42.021Z root WARN The local plugin referenced by local-dir:C:\Users\mpasquar\.arduinoIDE\plugins does not exist.
2024-03-14T14:09:42.028Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\mpasquar\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\mpasquar\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\mpasquar\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-03-14T14:09:42.028Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-03-14T14:09:42.028Z config INFO Loaded the CLI configuration.
2024-03-14T14:09:42.033Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/mpasquar/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/mpasquar/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-03-14T14:09:42.033Z config INFO Validating the CLI configuration...
2024-03-14T14:09:42.035Z config INFO The CLI config is valid.
2024-03-14T14:09:42.036Z config INFO <<< Initialized the CLI configuration.
2024-03-14T14:09:42.062Z root INFO Resolve plugins list: 209.4 ms [Finished 0.916 s after backend start]
2024-03-14T14:09:42.442Z daemon INFO time="2024-03-14T10:09:42-04:00" level=info msg="Using config file: c:\\Users\\mpasquar\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-14T10:09:42-04:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-03-14T10:09:42-04:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-14T14:09:42.459Z daemon INFO Daemon is now listening on 127.0.0.1:52497
{"IP":"127.0.0.1","Port":"52497"}
2024-03-14T14:09:42.459Z daemon INFO Daemon is running.
2024-03-14T14:09:42.514Z daemon INFO time="2024-03-14T10:09:42-04:00" level=info msg="Updating libraries index"
2024-03-14T14:09:42.528Z daemon INFO time="2024-03-14T10:09:42-04:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-03-14T14:09:42.562Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc: no such host
2024-03-14T14:09:42.563Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\mpasquar\AppData\Local\Arduino15\package_index.json: open C:\Users\mpasquar\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-03-14T14:09:42.563Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-03-14T14:09:42.563Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-03-14T14:09:42.563Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\mpasquar\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-03-14T14:09:42.568Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Loading index file: loading json index file C:\Users\mpasquar\AppData\Local\Arduino15\package_index.json: open C:\Users\mpasquar\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\mpasquar\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-03-14T14:09:42.568Z daemon INFO time="2024-03-14T10:09:42-04:00" level=info msg="Loading hardware from: C:\\Users\\mpasquar\\AppData\\Local\\Arduino15\\packages"
time="2024-03-14T10:09:42-04:00" level=info msg="Loading libraries index file" index="C:\\Users\\mpasquar\\AppData\\Local\\Arduino15\\library_index.json"
time="2024-03-14T10:09:42-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\mpasquar\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-03-14T10:09:42-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\mpasquar\\Documents\\Arduino\\libraries" location=user
2024-03-14T14:09:42.569Z daemon INFO time="2024-03-14T10:09:42-04:00" level=info msg="Updating libraries index"
time="2024-03-14T10:09:42-04:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-03-14T14:09:42.581Z daemon INFO time="2024-03-14T10:09:42-04:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-03-14T14:09:42.582Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-03-14T14:09:42.583Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-03-14T14:09:42.585Z root ERROR Failed to update platform, library indexes. Error: 13 INTERNAL: Some indexes could not be updated.
    at t.callErrorFromStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:763461)
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:791078)
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:784102)
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:870224
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
    at s.makeServerStreamRequest (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:790845)
    at s.updateIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:855121)
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:623733
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:624081
    at new Promise (<anonymous>)
    at E.doUpdateIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:624060)
    at E.updatePlatformIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:623705)
    at E.updateIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:623073)
    at E.initInstanceWithFallback (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:621317)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2024-03-14T14:09:42.588Z daemon INFO time="2024-03-14T10:09:42-04:00" level=info msg="Updating libraries index"
2024-03-14T14:09:42.597Z daemon INFO time="2024-03-14T10:09:42-04:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-03-14T14:09:42.598Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc: no such host
2024-03-14T14:09:42.599Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\mpasquar\AppData\Local\Arduino15\package_index.json: open C:\Users\mpasquar\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-03-14T14:09:42.599Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-03-14T14:09:42.599Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-03-14T14:09:42.599Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\mpasquar\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-03-14T14:09:42.601Z root ERROR Uncaught Exception:  Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-03-14T14:09:42.601Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622877
    at E.evaluateErrorStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622893)
    at async a.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622563)
2024-03-14T14:09:42.937Z root INFO Deploy plugins list: 209.4 ms [Finished 1.791 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-03-14T14:09:44.801Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 967.7 ms [Finished 2.789 s after frontend start]
2024-03-14T14:09:44.813Z root WARN A command editor.action.toggleStickyScroll is already registered.
Hi @cpark128. I see the problem here:
On the first run after a fresh installation, Arduino IDE downloads some additional essential components from the Internet and installs them. If it can't install those components then the startup fails. So the computer and the IDE application must have access to the Internet on the first startup.
The errors indicate Arduino IDE is not able to access the Internet, as is further indicated by this error:
(Note the "dial tcp: lookup downloads.arduino.cc: no such host")
If it is not already, please connect your computer to the Internet and make sure the IDE application's access to the Internet is not blocked by the firewall and other security software. After that, close the Arduino IDE window and start Arduino IDE again. This time it should start up successfully.
After that first run, an Internet connection is not required. However, there are some supplemental features such as "Library Manager" that have an inherent dependency on the Internet. Those features will not be usable while your computer is offline. But the essential functionality of editing, compiling, and uploading sketches will be available even without an Internet connection.
