Hello! I just installed Arduino IDE 2.3.2 on Win 11 and when I run the application, I can see only the starting page with the logo on a white background.
I looked at a few discussions and opened the installation folder > Opened the PowerShell window (Shift + Right Click) and wrote the command & ".\Arduino IDE". This is what I got:
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Users\inalya1\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\inalya1\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 29252
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/inalya1/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-05-17T07:05:51.149Z root INFO Backend Object.initialize: 5.3 ms [Finished 0.618 s after backend start]
2024-05-17T07:05:51.151Z root INFO Backend Object.configure: 4.6 ms [Finished 0.618 s after backend start]
2024-05-17T07:05:51.151Z root INFO Backend s.onStart: 3.0 ms [Finished 0.618 s after backend start]
2024-05-17T07:05:51.152Z root INFO Backend s.configure: 0.3 ms [Finished 0.646 s after backend start]
2024-05-17T07:05:51.153Z root INFO Backend d.onStart: 0.3 ms [Finished 0.646 s after backend start]
2024-05-17T07:05:51.154Z root INFO Backend d.configure: 0.1 ms [Finished 0.646 s after backend start]
2024-05-17T07:05:51.155Z root INFO Backend d.initialize: 27.0 ms [Finished 0.646 s after backend start]
2024-05-17T07:05:51.155Z root INFO Backend c.onStart: 0.3 ms [Finished 0.646 s after backend start]
2024-05-17T07:05:51.156Z root INFO Backend a.configure: 2.3 ms [Finished 0.648 s after backend start]
2024-05-17T07:05:51.158Z config INFO >>> Initializing CLI configuration...
2024-05-17T07:05:51.158Z root INFO Backend c.initialize: 0.9 ms [Finished 0.649 s after backend start]
2024-05-17T07:05:51.158Z root INFO Backend R.onStart: 1.3 ms [Finished 0.650 s after backend start]
2024-05-17T07:05:51.159Z config INFO Loading CLI configuration from c:\Users\inalya1\.arduinoIDE\arduino-cli.yaml...
2024-05-17T07:05:51.159Z daemon INFO Starting daemon from C:\Users\inalya1\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-17T07:05:51.159Z root INFO Backend a.initialize: 0.5 ms [Finished 0.651 s after backend start]
2024-05-17T07:05:51.159Z root INFO Backend w.onStart: 1.4 ms [Finished 0.652 s after backend start]
2024-05-17T07:05:51.159Z root INFO Backend r.configure: 2.3 ms [Finished 0.652 s after backend start]
2024-05-17T07:05:51.159Z discovery-log INFO start
2024-05-17T07:05:51.159Z discovery-log INFO start new deferred
2024-05-17T07:05:51.159Z root INFO Backend d.initialize: 0.7 ms [Finished 0.653 s after backend start]
2024-05-17T07:05:51.159Z root INFO Backend y.onStart: 2.3 ms [Finished 0.654 s after backend start]
2024-05-17T07:05:51.159Z root INFO Backend r.configure: 1.8 ms [Finished 0.655 s after backend start]
2024-05-17T07:05:51.160Z root INFO Backend a.onStart: 0.5 ms [Finished 0.656 s after backend start]
2024-05-17T07:05:51.160Z root INFO Backend h.configure: 0.3 ms [Finished 0.656 s after backend start]
2024-05-17T07:05:51.160Z root INFO Backend s.configure: 0.1 ms [Finished 0.656 s after backend start]
2024-05-17T07:05:51.160Z root INFO Backend l.configure: 0.1 ms [Finished 0.656 s after backend start]
2024-05-17T07:05:51.863Z root INFO Theia app listening on http://127.0.0.1:56853.
2024-05-17T07:05:51.864Z root INFO Finished starting backend application: 704.1 ms [Finished 1.360 s after backend start]
2024-05-17T07:05:51.875Z root WARN The local plugin referenced by local-dir:/c%3A/Users/inalya1/.arduinoIDE/plugins does not exist.
2024-05-17T07:05:51.875Z root WARN The local plugin referenced by local-dir:/c%3A/Users/inalya1/.arduinoIDE/extensions does not exist.
2024-05-17T07:05:51.875Z root WARN The local plugin referenced by local-dir:C:\Users\inalya1\.arduinoIDE\plugins does not exist.
2024-05-17T07:05:51.881Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\inalya1\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\inalya1\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\inalya1\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-05-17T07:05:51.882Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-05-17T07:05:51.882Z config INFO Loaded the CLI configuration.
2024-05-17T07:05:51.890Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/inalya1/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/inalya1/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-05-17T07:05:51.890Z config INFO Validating the CLI configuration...
2024-05-17T07:05:51.891Z config INFO The CLI config is valid.
2024-05-17T07:05:51.891Z config INFO <<< Initialized the CLI configuration.
2024-05-17T07:05:51.923Z root INFO Resolve plugins list: 764.4 ms [Finished 1.419 s after backend start]
2024-05-17T07:05:52.288Z daemon INFO time="2024-05-17T12:35:52+05:30" level=info msg="Using config file: c:\\Users\\inalya1\\.arduinoIDE\\arduino-cli.yaml"
time="2024-05-17T12:35:52+05:30" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-05-17T12:35:52+05:30" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:56857
{"IP":"127.0.0.1","Port":"56857"}
2024-05-17T07:05:52.288Z daemon INFO Daemon is running.
2024-05-17T07:05:52.318Z daemon INFO time="2024-05-17T12:35:52+05:30" level=info msg="Updating libraries index"
time="2024-05-17T12:35:52+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-05-17T07:05:52.678Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc: getaddrinfow: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
2024-05-17T07:05:52.679Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\inalya1\AppData\Local\Arduino15\package_index.json: open C:\Users\inalya1\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-05-17T07:05:52.679Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-05-17T07:05:52.680Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-05-17T07:05:52.680Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\inalya1\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-05-17T07:05:52.689Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Loading index file: loading json index file C:\Users\inalya1\AppData\Local\Arduino15\package_index.json: open C:\Users\inalya1\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\inalya1\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-05-17T07:05:52.690Z daemon INFO time="2024-05-17T12:35:52+05:30" level=info msg="Loading hardware from: C:\\Users\\inalya1\\AppData\\Local\\Arduino15\\packages"
time="2024-05-17T12:35:52+05:30" level=info msg="Loading libraries index file" index="C:\\Users\\inalya1\\AppData\\Local\\Arduino15\\library_index.json"
time="2024-05-17T12:35:52+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\inalya1\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-05-17T12:35:52+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\inalya1\\Documents\\Arduino\\libraries" location=user
time="2024-05-17T12:35:52+05:30" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-05-17T07:05:52.711Z daemon INFO time="2024-05-17T12:35:52+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-05-17T07:05:52.725Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-05-17T07:05:52.726Z root ERROR Failed to update platform, library indexes. Error: 13 INTERNAL: Some indexes could not be updated.
at t.callErrorFromStatus (C:\Users\inalya1\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:763461)
at Object.onReceiveStatus (C:\Users\inalya1\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:791078)
at Object.onReceiveStatus (C:\Users\inalya1\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:784102)
at C:\Users\inalya1\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:870224
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
at s.makeServerStreamRequest (C:\Users\inalya1\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:790845)
at s.updateIndex (C:\Users\inalya1\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:855121)
at C:\Users\inalya1\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:623733
at C:\Users\inalya1\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:624081
at new Promise (<anonymous>)
at E.doUpdateIndex (C:\Users\inalya1\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:624060)
at E.updatePlatformIndex (C:\Users\inalya1\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:623705)
at E.updateIndex (C:\Users\inalya1\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:623073)
at E.initInstanceWithFallback (C:\Users\inalya1\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:621317)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2024-05-17T07:05:52.727Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-05-17T07:05:52.736Z daemon INFO time="2024-05-17T12:35:52+05:30" level=info msg="Updating libraries index"
2024-05-17T07:05:52.737Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc: getaddrinfow: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
2024-05-17T07:05:52.738Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\inalya1\AppData\Local\Arduino15\package_index.json: open C:\Users\inalya1\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2024-05-17T07:05:52.738Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2024-05-17T07:05:52.738Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2024-05-17T07:05:52.739Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\inalya1\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2024-05-17T07:05:52.788Z daemon INFO time="2024-05-17T12:35:52+05:30" level=info msg="Loading libraries index file" index="C:\\Users\\inalya1\\AppData\\Local\\Arduino15\\library_index.json"
2024-05-17T07:05:52.789Z root ERROR Uncaught Exception: Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-05-17T07:05:52.789Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
at C:\Users\inalya1\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:622877
at E.evaluateErrorStatus (C:\Users\inalya1\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:622893)
at async a.<anonymous> (C:\Users\inalya1\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:622563)
2024-05-17T07:05:53.208Z root INFO Deploy plugins list: 764.4 ms [Finished 2.704 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-05-17T07:05:54.294Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 212.6 ms [Finished 2.259 s after frontend start]
2024-05-17T07:05:54.295Z root WARN A command editor.action.toggleStickyScroll is already registered.
I am not sure as to what the issue is and how I can rectify it.
Can someone help? Thanks!
