I have the same problem:
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 13300
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/ramis/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-03-16T18:44:13.875Z root INFO Backend Object.initialize: 13.4 ms [Finished 1.948 s after backend start]
2024-03-16T18:44:13.878Z root INFO Backend Object.configure: 10.6 ms [Finished 1.949 s after backend start]
2024-03-16T18:44:13.878Z root INFO Backend s.onStart: 5.6 ms [Finished 1.949 s after backend start]
2024-03-16T18:44:13.880Z root INFO Backend s.configure: 0.8 ms [Finished 2.020 s after backend start]
2024-03-16T18:44:13.882Z root INFO Backend d.onStart: 0.6 ms [Finished 2.020 s after backend start]
2024-03-16T18:44:13.884Z root INFO Backend d.configure: 0.3 ms [Finished 2.021 s after backend start]
2024-03-16T18:44:13.887Z root WARN Backend d.initialize took longer than the expected maximum 50 milliseconds: 71.4 ms [Finished 2.021 s after backend start]
2024-03-16T18:44:13.887Z root INFO Backend c.onStart: 0.8 ms [Finished 2.021 s after backend start]
2024-03-16T18:44:13.889Z root INFO Backend a.configure: 3.9 ms [Finished 2.025 s after backend start]
2024-03-16T18:44:13.894Z config INFO >>> Initializing CLI configuration...
2024-03-16T18:44:13.894Z root INFO Backend c.initialize: 1.6 ms [Finished 2.026 s after backend start]
2024-03-16T18:44:13.894Z root INFO Backend R.onStart: 2.4 ms [Finished 2.028 s after backend start]
2024-03-16T18:44:13.896Z config INFO Loading CLI configuration from c:\Users\ramis\.arduinoIDE\arduino-cli.yaml...
2024-03-16T18:44:13.898Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-16T18:44:13.898Z root INFO Backend a.initialize: 1.2 ms [Finished 2.031 s after backend start]
2024-03-16T18:44:13.898Z root INFO Backend w.onStart: 3.6 ms [Finished 2.033 s after backend start]
2024-03-16T18:44:13.898Z root INFO Backend r.configure: 5.6 ms [Finished 2.034 s after backend start]
2024-03-16T18:44:13.899Z discovery-log INFO start
2024-03-16T18:44:13.899Z discovery-log INFO start new deferred
2024-03-16T18:44:13.899Z root INFO Backend d.initialize: 1.3 ms [Finished 2.035 s after backend start]
2024-03-16T18:44:13.899Z root INFO Backend y.onStart: 6.2 ms [Finished 2.040 s after backend start]
2024-03-16T18:44:13.899Z root INFO Backend r.configure: 5.4 ms [Finished 2.041 s after backend start]
2024-03-16T18:44:13.899Z root INFO Backend a.onStart: 1.6 ms [Finished 2.045 s after backend start]
2024-03-16T18:44:13.899Z root INFO Backend h.configure: 1.4 ms [Finished 2.045 s after backend start]
2024-03-16T18:44:13.899Z root INFO Backend s.configure: 0.4 ms [Finished 2.045 s after backend start]
2024-03-16T18:44:13.899Z root INFO Backend l.configure: 0.2 ms [Finished 2.046 s after backend start]
2024-03-16T18:44:13.907Z root INFO Theia app listening on http://127.0.0.1:56988.
2024-03-16T18:44:13.907Z root INFO Finished starting backend application: 8.0 ms [Finished 2.053 s after backend start]
2024-03-16T18:44:13.930Z root WARN The local plugin referenced by local-dir:/c%3A/Users/ramis/.arduinoIDE/plugins does not exist.
2024-03-16T18:44:13.930Z root WARN The local plugin referenced by local-dir:/c%3A/Users/ramis/.arduinoIDE/extensions does not exist.
2024-03-16T18:44:13.930Z root WARN The local plugin referenced by local-dir:C:\Users\ramis\.arduinoIDE\plugins does not exist.
2024-03-16T18:44:13.955Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\user\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\user\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\user\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-03-16T18:44:13.956Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-03-16T18:44:13.956Z config INFO Loaded the CLI configuration.
2024-03-16T18:44:14.045Z config WARN Could not ensure user directory existence: C:\Users\user\Documents\Arduino Error: EPERM: operation not permitted, mkdir 'C:\Users\user'
2024-03-16T18:44:14.045Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/user/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/user/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-03-16T18:44:14.045Z config INFO Validating the CLI configuration...
2024-03-16T18:44:14.046Z root ERROR Check accessible failed for input: C:\Users\user\Documents\Arduino Error: ENOENT: no such file or directory, scandir 'C:\Users\user\Documents\Arduino'
2024-03-16T18:44:14.047Z config ERROR Failed to initialize the CLI configuration. Error: InvalidConfigError:
- Could not access the sketchbook location at 'C:\Users\user\Documents\Arduino': Error: ENOENT: no such file or directory, scandir 'C:\Users\user\Documents\Arduino'
at R.validateCliConfig (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:616109)
at async R.initConfig (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:613928)
2024-03-16T18:44:14.087Z daemon INFO Error: invalid path creating config dir: C:\Users\user\AppData\Local\Arduino15 error: mkdir C:\Users\user: Access is denied.
2024-03-16T18:44:14.088Z daemon ERROR Error: Error: invalid path creating config dir: C:\Users\user\AppData\Local\Arduino15 error: mkdir C:\Users\user: Access is denied.
at Socket.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:43051)
at Socket.emit (node:events:514:28)
at addChunk (node:internal/streams/readable:324:12)
at readableAddChunk (node:internal/streams/readable:297:9)
at Socket.push (node:internal/streams/readable:234:10)
at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
2024-03-16T18:44:14.088Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-16T18:44:14.105Z daemon INFO Daemon exited with exit code: 7.
2024-03-16T18:44:14.116Z root INFO Resolve plugins list: 220.2 ms [Finished 2.261 s after backend start]
2024-03-16T18:44:14.259Z daemon INFO Error: invalid path creating config dir: C:\Users\user\AppData\Local\Arduino15 error: mkdir C:\Users\user: Access is denied.
2024-03-16T18:44:14.259Z daemon ERROR Error: Error: invalid path creating config dir: C:\Users\user\AppData\Local\Arduino15 error: mkdir C:\Users\user: Access is denied.
2024-03-16T18:44:14.259Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
