IDE hangs on startup: "mkdir /Users/user: permission denied"
Hello, i've read already a lot about this, but couldn't find any solution. My arduino still won't open and is just stuck on the opening logo:/ Please help me, i need to work with this for University.
Hi @purplerainsss. I'm going to ask you to provide some additional information that might help us to identify the problem.
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Close all Arduino IDE windows if the IDE is already running.
  2. Open macOS Launchpad.
  3. Type terminal in the "Search" field.
  4. Click on the "Terminal" icon.
    A "zsh" window will open.
  5. Type the following command in the zsh window:
    "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
  6. Press the Enter key.
  7. Wait until you are sure the IDE startup has gone into the hang state
    (as indicated by no additional output being printed to the Terminal window).
  8. Switch back to the Terminal window if the Arduino IDE window took the focus.
  9. Press the Command+A keyboard shortcut.
    This will select all the text in the Terminal window.
  10. Press the Command+C keyboard shortcut.
    This will copy the selected text to the clipboard.
  11. Open a forum reply here by clicking the "Reply" button.
  12. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the output is correctly formatted.
    Code block icon on toolbar
  13. Press the Command+V keyboard shortcut.
    This will paste the output into the code block.
  14. Move the cursor outside of the code block markup before you add any additional text to your reply.
  15. Click the "Reply" button to post the output.
Please let me know if you have any questions or problems while following those instructions.
Hello, thanks for helping me. So i am waiting now for almost 20 minutes and the code won't stop making itself. I started to insert it here, but my laptop froze, so this is an excerpt now. I think its too big maybe? Like its ten times as big as this i guess
Last login: Fri May 17 15:14:52 on ttys000
The default interactive shell is now zsh.
To update your account to use zsh, please run `chsh -s /bin/zsh`.
For more details, please visit https://support.apple.com/kb/HT208050.
MacBook-Pro:~ Lynn$ "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/electron-main.js, destination 'package.json': /Applications/Arduino IDE.app/Contents/Resources/app/package.json
2024-05-17 15:25:49.085 Arduino IDE[86583:781128] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T09:57:46.613Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T09:57:46.613Z"}
Starting backend process. PID: 86605
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///Users/Lynn/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-05-17T13:25:49.692Z root INFO Backend Object.initialize: 2.9 ms [Finished 0.492 s after backend start]
2024-05-17T13:25:49.693Z root INFO Backend Object.configure: 2.2 ms [Finished 0.492 s after backend start]
2024-05-17T13:25:49.693Z root INFO Backend s.onStart: 1.3 ms [Finished 0.492 s after backend start]
2024-05-17T13:25:49.693Z root INFO Backend s.configure: 0.3 ms [Finished 0.515 s after backend start]
2024-05-17T13:25:49.694Z root INFO Backend d.onStart: 0.2 ms [Finished 0.515 s after backend start]
2024-05-17T13:25:49.695Z root INFO Backend d.configure: 0.1 ms [Finished 0.515 s after backend start]
2024-05-17T13:25:49.695Z root INFO Backend d.initialize: 22.6 ms [Finished 0.515 s after backend start]
2024-05-17T13:25:49.695Z root INFO Backend c.onStart: 0.2 ms [Finished 0.515 s after backend start]
2024-05-17T13:25:49.696Z root INFO Backend a.configure: 1.2 ms [Finished 0.516 s after backend start]
2024-05-17T13:25:49.697Z config INFO >>> Initializing CLI configuration...
2024-05-17T13:25:49.697Z root INFO Backend c.initialize: 0.7 ms [Finished 0.517 s after backend start]
2024-05-17T13:25:49.697Z root INFO Backend R.onStart: 0.8 ms [Finished 0.517 s after backend start]
2024-05-17T13:25:49.698Z config INFO Loading CLI configuration from /Users/Lynn/.arduinoIDE/arduino-cli.yaml...
2024-05-17T13:25:49.698Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:49.698Z root INFO Backend a.initialize: 0.4 ms [Finished 0.518 s after backend start]
2024-05-17T13:25:49.698Z root INFO Backend w.onStart: 1.0 ms [Finished 0.519 s after backend start]
2024-05-17T13:25:49.698Z root INFO Backend r.configure: 1.6 ms [Finished 0.519 s after backend start]
2024-05-17T13:25:49.698Z discovery-log INFO start
2024-05-17T13:25:49.698Z discovery-log INFO start new deferred
2024-05-17T13:25:49.698Z root INFO Backend d.initialize: 0.3 ms [Finished 0.519 s after backend start]
2024-05-17T13:25:49.698Z root INFO Backend y.onStart: 1.4 ms [Finished 0.520 s after backend start]
2024-05-17T13:25:49.698Z root INFO Backend r.configure: 1.2 ms [Finished 0.520 s after backend start]
2024-05-17T13:25:49.698Z root INFO Backend a.onStart: 0.5 ms [Finished 0.522 s after backend start]
2024-05-17T13:25:49.698Z root INFO Backend h.configure: 0.4 ms [Finished 0.522 s after backend start]
2024-05-17T13:25:49.698Z root INFO Backend s.configure: 0.1 ms [Finished 0.522 s after backend start]
2024-05-17T13:25:49.698Z root INFO Backend l.configure: 0.1 ms [Finished 0.522 s after backend start]
2024-05-17T13:25:49.700Z root INFO Theia app listening on http://127.0.0.1:58579.
2024-05-17T13:25:49.700Z root INFO Finished starting backend application: 2.2 ms [Finished 0.524 s after backend start]
2024-05-17T13:25:49.701Z root WARN The local plugin referenced by local-dir:/Users/Lynn/.arduinoIDE/plugins does not exist.
2024-05-17T13:25:49.701Z root WARN The local plugin referenced by local-dir:/Users/Lynn/.arduinoIDE/extensions does not exist.
2024-05-17T13:25:49.705Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"/Users/user/Library/Arduino15","downloads":"/Users/user/Library/Arduino15/staging","user":"/Users/user/Documents/Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-05-17T13:25:49.705Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-05-17T13:25:49.705Z config INFO Loaded the CLI configuration.
2024-05-17T13:25:49.712Z config WARN Could not ensure user directory existence: /Users/user/Documents/Arduino Error: EACCES: permission denied, mkdir '/Users/user'
2024-05-17T13:25:49.712Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///Users/user/Library/Arduino15","sketchDirUri":"file:///Users/user/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-05-17T13:25:49.712Z config INFO Validating the CLI configuration...
2024-05-17T13:25:49.712Z root ERROR Check accessible failed for input: /Users/user/Documents/Arduino Error: ENOENT: no such file or directory, scandir '/Users/user/Documents/Arduino'
2024-05-17T13:25:49.712Z config ERROR Failed to initialize the CLI configuration. Error: InvalidConfigError:
 - Could not access the sketchbook location at '/Users/user/Documents/Arduino': Error: ENOENT: no such file or directory, scandir '/Users/user/Documents/Arduino'
    at R.validateCliConfig (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:615965)
    at async R.initConfig (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:613784)
2024-05-17T13:25:49.726Z root INFO Resolve plugins list: 28.1 ms [Finished 0.549 s after backend start]
2024-05-17T13:25:49.731Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:49.731Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
    at Socket.<anonymous> (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:42907)
    at Socket.emit (node:events:514:28)
    at addChunk (node:internal/streams/readable:324:12)
    at readableAddChunk (node:internal/streams/readable:297:9)
    at Socket.push (node:internal/streams/readable:234:10)
    at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
2024-05-17T13:25:49.731Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:49.731Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:49.761Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:49.761Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:49.761Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:49.761Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:49.858Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:49.858Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:49.858Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:49.859Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:49.903Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:49.903Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:49.903Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:49.904Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:49.949Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:49.949Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:49.949Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:49.949Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:49.997Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:49.997Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:49.997Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:49.998Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.025Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.025Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.026Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.026Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.067Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.067Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.067Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.067Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.112Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.112Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.112Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.113Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.157Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.157Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.157Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.157Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.206Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.206Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.206Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.206Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.251Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.252Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.252Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.252Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.288Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.288Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.288Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.288Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.398Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.398Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.398Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.398Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.426Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.426Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.427Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.427Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.472Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.472Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.472Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.472Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.516Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.516Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.516Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.516Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.531Z root INFO Deploy plugins list: 28.1 ms [Finished 1.354 s after backend start]
2024-05-17T13:25:50.539Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.539Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.539Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.541Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.560Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.560Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.560Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.562Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.578Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.578Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.578Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.580Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.598Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.598Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.598Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.599Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.616Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.617Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.617Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.618Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.636Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.636Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.636Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.638Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.656Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.656Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.656Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.657Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.674Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.675Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.675Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.676Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.693Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.693Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.693Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.695Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.715Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.715Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.715Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.717Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.734Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.734Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.734Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.736Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.756Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.756Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.756Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.757Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.785Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.785Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.785Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.786Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.805Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.805Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.805Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.806Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.823Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.823Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.823Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.824Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.842Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.842Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.842Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.844Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.860Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.860Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.860Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.862Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.880Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.880Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.880Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.882Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.902Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.902Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.902Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.904Z daemon INFO Daemon exited with exit code: 7.
Opening channel for service path '/services/electron-window'.
2024-05-17T13:25:50.923Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.923Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.923Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.924Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.944Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.944Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.944Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.947Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:50.967Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.967Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.967Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.969Z daemon INFO Daemon exited with exit code: 7.
Opening channel for service path '/services/ide-updater'.
2024-05-17T13:25:50.988Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.988Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:50.988Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:50.988Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.011Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.011Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.011Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.014Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.030Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.030Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.030Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.032Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.056Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.056Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.056Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.057Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.082Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.082Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.082Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.083Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.108Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.108Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.108Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.110Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.129Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.129Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.129Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.131Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.149Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.149Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.149Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.150Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.167Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.167Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.167Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.168Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.184Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.184Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.184Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.187Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.214Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.214Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.214Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.214Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.237Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.237Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.237Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.239Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.240Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 211.1 ms [Finished 1.446 s after frontend start]
2024-05-17T13:25:51.285Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-05-17T13:25:51.287Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.287Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.287Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.287Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.314Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.314Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.314Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.315Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.335Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.335Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.335Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.336Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.356Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.356Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.356Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.357Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.379Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.379Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.380Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.380Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.401Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.401Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.401Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.403Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.419Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.420Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.420Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.422Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.438Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.438Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.438Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.440Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.461Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.461Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.461Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.462Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.493Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.493Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.493Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.494Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.514Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.515Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.515Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.516Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.532Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.532Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.532Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.534Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.551Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.551Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.551Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.552Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.569Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.569Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.569Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.570Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.586Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.586Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.586Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.588Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.604Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.604Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.604Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.606Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.622Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.622Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.622Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.624Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.640Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.640Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.640Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.641Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.658Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.658Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.658Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.660Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.676Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.677Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.677Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.677Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.694Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.694Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.694Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-17T13:25:51.696Z daemon INFO Daemon exited with exit code: 7.
2024-05-17T13:25:51.712Z daemon INFO Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
2024-05-17T13:25:51.712Z daemon ERROR Error: Error: invalid path creating config dir: /Users/user/Library/Arduino15 error: mkdir /Users/user: permission denied
It looks this was caused by your macOS username changing from "user" to "Lynn" since the time you installed Arduino IDE.
The first time you run Arduino IDE, it generates a configuration file that defines the paths to several folders used by the IDE. The default locations of these folders are under your home folder, which means the username is part of the path. When you change your username it makes the paths in the configuration file outdated. When the IDE attempts to access the old path, the operating system does not allow it, which causes the startup to hang.
I think the easiest solution will be to simply delete the configuration file. Arduino IDE will automatically generate a new file on startup with the correct paths.
I'll provide instructions you can follow to do that:
  1. Select Arduino IDE > Quit Arduino IDE from the Arduino IDE menus if it is running.
    All Arduino IDE windows will close.
  2. Delete the file at the following path:
    /Users/<username>/.arduinoIDE/arduino-cli.yaml
    (where <username> is your macOS username)
    :exclamation: The .arduinoIDE folder is hidden by default. You can make it visible by pressing the Command+Shift+. keyboard shortcut.
    :warning: Please be careful when deleting things from your computer. When in doubt, back up!
  3. Start Arduino IDE.
Arduino IDE should now start up fully and be functional as usual.
Note that the file you deleted is used to store some of your IDE preferences. These will all have been reset to the default values. If you had customized either the "Sketchbook location" or "Additional Boards Manager URLs" preferences before, you'll need to select Arduino IDE > Settings... from the Arduino IDE menus and then set those preferences once again after performing the instructions I provided above.
