I've read multiple posts with similar issues, but none have helped me fix this. Initially this happened in 2.3.2.
Steps I've taken:
- Remove .arduinoIDE
- Remove ../Library/Arduino15
- Remove App and reinstall
- Install 2.3.1
It never gets past the splash screen.
Logs:
Arduino IDE 2.3.1
Checking for frontend application configuration customizations. Module path: /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/electron-main.js, destination 'package.json': /Applications/Arduino IDE.app/Contents/Resources/app/package.json
2024-05-12 22:40:34.799 Arduino IDE[4611:29501] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.1" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.2" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-15T08:50:42.951Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.1","cliVersion":"0.35.2","buildDate":"2024-02-15T08:50:42.951Z"}
Starting backend process. PID: 5053
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///Users/username/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-05-12T20:40:35.114Z root INFO Backend Object.initialize: 2.0 ms [Finished 0.257 s after backend start]
2024-05-12T20:40:35.115Z root INFO Backend Object.configure: 1.5 ms [Finished 0.257 s after backend start]
2024-05-12T20:40:35.115Z root INFO Backend s.onStart: 0.7 ms [Finished 0.257 s after backend start]
2024-05-12T20:40:35.115Z root INFO Backend s.configure: 0.2 ms [Finished 0.273 s after backend start]
2024-05-12T20:40:35.115Z root INFO Backend d.onStart: 0.1 ms [Finished 0.273 s after backend start]
2024-05-12T20:40:35.116Z root INFO Backend d.configure: 0.1 ms [Finished 0.273 s after backend start]
2024-05-12T20:40:35.116Z root INFO Backend d.initialize: 16.0 ms [Finished 0.273 s after backend start]
2024-05-12T20:40:35.116Z root INFO Backend c.onStart: 0.2 ms [Finished 0.273 s after backend start]
2024-05-12T20:40:35.116Z root INFO Backend a.configure: 0.6 ms [Finished 0.274 s after backend start]
2024-05-12T20:40:35.117Z config INFO >>> Initializing CLI configuration...
2024-05-12T20:40:35.117Z root INFO Backend c.initialize: 0.2 ms [Finished 0.274 s after backend start]
2024-05-12T20:40:35.117Z root INFO Backend R.onStart: 0.4 ms [Finished 0.274 s after backend start]
2024-05-12T20:40:35.117Z config INFO Loading CLI configuration from /Users/username/.arduinoIDE/arduino-cli.yaml...
2024-05-12T20:40:35.117Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-05-12T20:40:35.117Z root INFO Backend a.initialize: 0.2 ms [Finished 0.275 s after backend start]
2024-05-12T20:40:35.117Z root INFO Backend w.onStart: 0.5 ms [Finished 0.275 s after backend start]
2024-05-12T20:40:35.117Z root INFO Backend r.configure: 0.7 ms [Finished 0.275 s after backend start]
2024-05-12T20:40:35.117Z discovery-log INFO start
2024-05-12T20:40:35.117Z discovery-log INFO start new deferred
2024-05-12T20:40:35.117Z root INFO Backend d.initialize: 0.2 ms [Finished 0.275 s after backend start]
2024-05-12T20:40:35.117Z root INFO Backend y.onStart: 0.8 ms [Finished 0.276 s after backend start]
2024-05-12T20:40:35.118Z root INFO Backend r.configure: 0.7 ms [Finished 0.276 s after backend start]
2024-05-12T20:40:35.118Z root INFO Backend a.onStart: 0.2 ms [Finished 0.276 s after backend start]
2024-05-12T20:40:35.118Z root INFO Backend h.configure: 0.2 ms [Finished 0.276 s after backend start]
2024-05-12T20:40:35.118Z root INFO Backend s.configure: 0.0 ms [Finished 0.276 s after backend start]
2024-05-12T20:40:35.118Z root INFO Backend l.configure: 0.0 ms [Finished 0.276 s after backend start]
2024-05-12T20:40:35.119Z root INFO Theia app listening on http://127.0.0.1:49425.
2024-05-12T20:40:35.119Z root INFO Finished starting backend application: 1.2 ms [Finished 0.277 s after backend start]
2024-05-12T20:40:35.121Z root WARN The local plugin referenced by local-dir:/Users/username/.arduinoIDE/plugins does not exist.
2024-05-12T20:40:35.121Z root WARN The local plugin referenced by local-dir:/Users/username/.arduinoIDE/extensions does not exist.
2024-05-12T20:40:35.125Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"/Users/username/Library/Arduino15","downloads":"/Users/username/Library/Arduino15/staging","user":"/Users/username/Documents/Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-05-12T20:40:35.125Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-05-12T20:40:35.125Z config INFO Loaded the CLI configuration.
2024-05-12T20:40:35.127Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///Users/username/Library/Arduino15","sketchDirUri":"file:///Users/username/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-05-12T20:40:35.127Z config INFO Validating the CLI configuration...
2024-05-12T20:40:35.132Z daemon INFO time="2024-05-12T22:40:35+02:00" level=info msg="Using config file: /Users/username/.arduinoIDE/arduino-cli.yaml"
time="2024-05-12T22:40:35+02:00" level=info msg="arduino-cli version 0.35.2"
time="2024-05-12T22:40:35+02:00" level=info msg="Executing `arduino-cli daemon`"
2024-05-12T20:40:35.135Z daemon INFO Daemon is now listening on 127.0.0.1:49426
{"IP":"127.0.0.1","Port":"49426"}
2024-05-12T20:40:35.135Z daemon INFO Daemon is running.
2024-05-12T20:40:35.143Z root INFO Resolve plugins list: 26.0 ms [Finished 0.302 s after backend start]
2024-05-12T20:40:35.150Z daemon INFO time="2024-05-12T22:40:35+02:00" level=info msg="Checking signature" index=/Users/username/Library/Arduino15/package_index.json signatureFile=/Users/username/Library/Arduino15/package_index.json.sig trusted=true
2024-05-12T20:40:35.151Z daemon INFO time="2024-05-12T22:40:35+02:00" level=info msg="Loading hardware from: /Users/username/Library/Arduino15/packages"
time="2024-05-12T22:40:35+02:00" level=info msg="Loading package builtin from: /Users/username/Library/Arduino15/packages/builtin"
time="2024-05-12T22:40:35+02:00" level=info msg="Checking existence of 'tools' path: /Users/username/Library/Arduino15/packages/builtin/tools"
time="2024-05-12T22:40:35+02:00" level=info msg="Loading tools from dir: /Users/username/Library/Arduino15/packages/builtin/tools"
time="2024-05-12T22:40:35+02:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-05-12T22:40:35+02:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-05-12T22:40:35+02:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-05-12T22:40:35+02:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2024-05-12T22:40:35+02:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-05-12T22:40:35+02:00" level=info msg="Loading libraries index file" index=/Users/username/Library/Arduino15/library_index.json
2024-05-12T20:40:35.274Z daemon INFO time="2024-05-12T22:40:35+02:00" level=info msg="Adding libraries dir" dir=/Users/username/Library/Arduino15/libraries location=ide
time="2024-05-12T22:40:35+02:00" level=info msg="Adding libraries dir" dir=/Users/username/Documents/Arduino/libraries location=user
2024-05-12T20:40:35.571Z root INFO Deploy plugins list: 26.0 ms [Finished 0.730 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-05-12T20:40:36.194Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-05-12T20:40:36.210Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 194.1 ms [Finished 0.901 s after frontend start]
I had it running yesterday without any issues.
Anyone have a clue how to get this working again?
