IDE hangs on startup: "wsarecv: A connection attempt failed ..."
PS C:\Users\kira\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
PS C:\Users\kira\AppData\Local\Programs\Arduino IDE> Arduino IDE 2.3.4
Checking for frontend application configuration customizations. Module path: C:\Users\kira\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\kira\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.4" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.1.1" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-12-03T10:03:03.490Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.4","cliVersion":"1.1.1","buildDate":"2024-12-03T10:03:03.490Z"}
Starting backend process. PID: 12916
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/kira/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-02-24T20:56:31.537Z root INFO Backend Object.initialize: 5.7 ms [Finished 0.764 s after backend start]
2025-02-24T20:56:31.538Z root INFO Backend Object.configure: 4.9 ms [Finished 0.764 s after backend start]
2025-02-24T20:56:31.538Z root INFO Backend s.onStart: 2.8 ms [Finished 0.764 s after backend start]
2025-02-24T20:56:31.539Z root INFO Backend s.configure: 0.4 ms [Finished 0.798 s after backend start]
2025-02-24T20:56:31.540Z root INFO Backend d.onStart: 0.3 ms [Finished 0.798 s after backend start]
2025-02-24T20:56:31.541Z root INFO Backend d.configure: 0.1 ms [Finished 0.799 s after backend start]
2025-02-24T20:56:31.543Z root INFO Backend d.initialize: 34.4 ms [Finished 0.799 s after backend start]
2025-02-24T20:56:31.543Z root INFO Backend c.onStart: 0.3 ms [Finished 0.799 s after backend start]
2025-02-24T20:56:31.544Z root INFO Backend a.configure: 1.7 ms [Finished 0.801 s after backend start]
2025-02-24T20:56:31.546Z config INFO >>> Initializing CLI configuration...
2025-02-24T20:56:31.546Z root INFO Backend c.initialize: 0.9 ms [Finished 0.801 s after backend start]
2025-02-24T20:56:31.546Z root INFO Backend x.onStart: 1.4 ms [Finished 0.802 s after backend start]
2025-02-24T20:56:31.547Z config INFO Loading CLI configuration from c:\Users\kira\.arduinoIDE\arduino-cli.yaml...
2025-02-24T20:56:31.548Z daemon INFO Starting daemon from C:\Users\kira\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-02-24T20:56:31.548Z root INFO Backend a.initialize: 0.5 ms [Finished 0.803 s after backend start]
2025-02-24T20:56:31.548Z root INFO Backend w.onStart: 1.6 ms [Finished 0.805 s after backend start]
2025-02-24T20:56:31.548Z root INFO Backend r.configure: 2.8 ms [Finished 0.805 s after backend start]
2025-02-24T20:56:31.548Z discovery-log INFO start
2025-02-24T20:56:31.548Z discovery-log INFO start new deferred
2025-02-24T20:56:31.548Z root INFO Backend d.initialize: 0.7 ms [Finished 0.806 s after backend start]
2025-02-24T20:56:31.549Z root INFO Backend y.onStart: 2.8 ms [Finished 0.808 s after backend start]
2025-02-24T20:56:31.549Z root INFO Backend r.configure: 2.2 ms [Finished 0.808 s after backend start]
2025-02-24T20:56:31.549Z root INFO Backend a.onStart: 0.7 ms [Finished 0.810 s after backend start]
2025-02-24T20:56:31.549Z root INFO Backend h.configure: 0.6 ms [Finished 0.810 s after backend start]
2025-02-24T20:56:31.549Z root INFO Backend s.configure: 0.2 ms [Finished 0.811 s after backend start]
2025-02-24T20:56:31.549Z root INFO Backend l.configure: 0.1 ms [Finished 0.811 s after backend start]
2025-02-24T20:56:31.555Z root INFO Theia app listening on http://127.0.0.1:2573.
2025-02-24T20:56:31.556Z root INFO Finished starting backend application: 6.8 ms [Finished 0.817 s after backend start]
2025-02-24T20:56:31.569Z root WARN The local plugin referenced by local-dir:/c%3A/Users/kira/.arduinoIDE/plugins does not exist.
2025-02-24T20:56:31.570Z root WARN The local plugin referenced by local-dir:/c%3A/Users/kira/.arduinoIDE/extensions does not exist.
2025-02-24T20:56:31.570Z root WARN The local plugin referenced by local-dir:C:\Users\kira\.arduinoIDE\plugins does not exist.
2025-02-24T20:56:31.599Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]}}
2025-02-24T20:56:31.599Z config INFO Loading fallback CLI configuration to get 'directories.data' and 'directories.user'
2025-02-24T20:56:31.677Z root INFO Resolve plugins list: 126.4 ms [Finished 0.935 s after backend start]
2025-02-24T20:56:32.032Z daemon INFO time="2025-02-25T09:56:31+13:00" level=info msg="arduino-cli version 1.1.1"
time="2025-02-25T09:56:31+13:00" level=info msg="Using config file: c:\\Users\\kira\\.arduinoIDE\\arduino-cli.yaml"
time="2025-02-25T09:56:31+13:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:2574
{"IP":"127.0.0.1","Port":"2574"}
2025-02-24T20:56:32.032Z daemon INFO Daemon is running.
2025-02-24T20:56:32.192Z config INFO Loaded fallback CLI configuration: {"directories":{"user":"C:\\Users\\kira\\Documents\\Arduino","data":"C:\\Users\\kira\\AppData\\Local\\Arduino15"}}
2025-02-24T20:56:32.192Z config INFO Merged CLI configuration with the fallback: {"directories":{"user":"C:\\Users\\kira\\Documents\\Arduino","data":"C:\\Users\\kira\\AppData\\Local\\Arduino15"},"board_manager":{"additional_urls":[]}}
2025-02-24T20:56:32.192Z config INFO Loaded the CLI configuration.
2025-02-24T20:56:32.207Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/kira/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/kira/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2025-02-24T20:56:32.207Z config INFO Validating the CLI configuration...
2025-02-24T20:56:32.219Z config INFO The CLI config is valid.
2025-02-24T20:56:32.225Z config INFO <<< Initialized the CLI configuration.
2025-02-24T20:56:32.234Z daemon INFO time="2025-02-25T09:56:32+13:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2025-02-24T20:56:33.581Z root INFO Deploy plugins list: 126.4 ms [Finished 2.843 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2025-02-24T20:56:35.376Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 245.3 ms [Finished 3.403 s after frontend start]
2025-02-24T20:56:35.376Z root WARN A command editor.action.toggleStickyScroll is already registered.
2025-02-24T20:56:35.376Z root WARN Frontend commands.onStart took longer than the expected maximum 100 milliseconds: 202.1 ms [Finished 3.608 s after frontend start]
2025-02-24T20:56:35.480Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 175.6 ms [Finished 3.784 s after frontend start]
2025-02-24T20:56:35.803Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 236.2 ms [Finished 4.128 s after frontend start]
2025-02-24T21:05:22.750Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': read tcp 192.168.50.39:2579->104.18.11.21:443: wsarecv: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2025-02-24T21:05:22.753Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\kira\AppData\Local\Arduino15\package_index.json: open C:\Users\kira\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2025-02-24T21:05:22.753Z daemon INFO time="2025-02-25T10:05:22+13:00" level=info msg="Loading hardware from: C:\\Users\\kira\\AppData\\Local\\Arduino15\\packages"
2025-02-24T21:05:22.777Z daemon INFO time="2025-02-25T10:05:22+13:00" level=info msg="Loading libraries index file" index="C:\\Users\\kira\\AppData\\Local\\Arduino15\\library_index.json"
2025-02-24T21:05:22.778Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2025-02-24T21:05:22.779Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2025-02-24T21:05:22.780Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\kira\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2025-02-24T21:05:22.780Z daemon INFO time="2025-02-25T10:05:22+13:00" level=info msg="Adding libraries dir" dir="C:\\Users\\kira\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-02-24T21:05:22.781Z daemon INFO time="2025-02-25T10:05:22+13:00" level=info msg="Adding libraries dir" dir="C:\\Users\\kira\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-02-24T21:05:22.802Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Loading index file: loading json index file C:\Users\kira\AppData\Local\Arduino15\package_index.json: open C:\Users\kira\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\kira\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
2025-02-24T21:05:22.803Z daemon INFO time="2025-02-25T10:05:22+13:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2025-02-24T21:05:22.806Z daemon INFO time="2025-02-25T10:05:22+13:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
time="2025-02-25T10:05:22+13:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2025-02-24T21:05:22.809Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2025-02-24T21:05:22.811Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2025-02-24T21:14:25.471Z daemon INFO time="2025-02-25T10:14:25+13:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
Hi @kirubelf.
On the first run after a fresh installation, Arduino IDE downloads some additional essential components from the Internet and installs them. If it can't install those components then the startup fails. So the computer must have access to the Internet on the first startup.
The errors indicate Arduino IDE was not able to download the required files via the Internet. If it is not already, please connect your computer to the Internet, close the Arduino IDE window, then start Arduino IDE again. This time it should start up successfully.
After that first run, an Internet connection is not required. However, there are some supplemental features such as "Library Manager" that have an inherent dependency on the Internet. Those features will not be usable while your computer is offline. But the essential functionality of editing, compiling, and uploading sketches will be available even without an Internet connection.
