Hi ptillisch,
Thanks for your reply. I tried, however PowerShell seems to have a problem with the Space ' ' between Arduino and IDE. Anyways: The regular Console with autocomplete by Tab did the trick and I hope the below output helps you identify the problem.
(And OMG, are there a lot of unneccessary language packs...)
C:\Program Files\Arduino IDE2>
Arduino IDE 2.0.3
Starting backend process. PID: 1408
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/User/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-02-17T20:12:23.587Z root INFO Backend Object.initialize: 4.1 ms [Finished 1.292 s after backend start]
2023-02-17T20:12:23.587Z root INFO Backend Object.configure: 3.5 ms [Finished 1.292 s after backend start]
2023-02-17T20:12:23.588Z root INFO Backend MessagingContribution.onStart: 1.2 ms [Finished 1.292 s after backend start]
2023-02-17T20:12:23.588Z root INFO Backend OSBackendApplicationContribution.configure: 0.2 ms [Finished 1.327 s after backend start]
2023-02-17T20:12:23.589Z root INFO Backend DefaultWorkspaceServer.onStart: 0.2 ms [Finished 1.327 s after backend start]2023-02-17T20:12:23.589Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.1 ms [Finished 1.327 s after backend start]
2023-02-17T20:12:23.590Z root INFO Backend PluginLocalizationBackendContribution.initialize: 35.3 ms [Finished 1.328 s after backend start]
2023-02-17T20:12:23.590Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 1.328 s after backend start]
2023-02-17T20:12:23.591Z root INFO Backend ElectronTokenBackendContribution.configure: 0.9 ms [Finished 1.328 s after backend start]
2023-02-17T20:12:23.591Z root INFO Backend PluginDeployerContribution.initialize: 0.3 ms [Finished 1.329 s after backend start]
2023-02-17T20:12:23.591Z root INFO Backend ConfigServiceImpl.onStart: 0.5 ms [Finished 1.329 s after backend start]
2023-02-17T20:12:23.592Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.3 ms [Finished 1.330 s after backend start]
2023-02-17T20:12:23.592Z root INFO Backend ArduinoDaemonImpl.onStart: 0.8 ms [Finished 1.330 s after backend start]
2023-02-17T20:12:23.592Z root INFO Backend NodeFileUploadService.configure: 1.4 ms [Finished 1.330 s after backend start]
2023-02-17T20:12:23.593Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE2\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-02-17T20:12:23.593Z discovery-log INFO start
2023-02-17T20:12:23.593Z discovery-log INFO start new deferred
2023-02-17T20:12:23.594Z root INFO Backend HostedPluginLocalizationService.initialize: 0.3 ms [Finished 1.331 s after backend start]
2023-02-17T20:12:23.594Z root INFO Backend BoardDiscovery.onStart: 0.6 ms [Finished 1.331 s after backend start]
2023-02-17T20:12:23.594Z root INFO Backend FileDownloadEndpoint.configure: 0.6 ms [Finished 1.332 s after backend start]2023-02-17T20:12:23.594Z root INFO Backend AuthenticationServiceImpl.onStart: 0.3 ms [Finished 1.333 s after backend start]
2023-02-17T20:12:23.595Z root INFO Backend PluginApiContribution.configure: 0.4 ms [Finished 1.333 s after backend start]
2023-02-17T20:12:23.596Z root INFO Backend HostedPluginReader.configure: 0.8 ms [Finished 1.334 s after backend start]
2023-02-17T20:12:23.596Z root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 1.335 s after backend start]
2023-02-17T20:12:23.596Z root INFO Backend PlotterBackendContribution.configure: 1.0 ms [Finished 1.336 s after backend start]
2023-02-17T20:12:23.599Z root INFO Theia app listening on http://localhost:51199.
2023-02-17T20:12:23.599Z root INFO Finished starting backend application: 5.6 ms [Finished 1.339 s after backend start]
2023-02-17T20:12:23.600Z root WARN The local plugin referenced by local-dir:/c%3A/Users/User/.arduinoIDE/plugins does not exist.
2023-02-17T20:12:23.600Z root WARN The local plugin referenced by local-dir:/c%3A/Users/User/.arduinoIDE/extensions does not exist.
2023-02-17T20:12:23.601Z root WARN The local plugin referenced by local-dir:C:\Users\User\.arduinoProIDE\plugins does not exist.
2023-02-17T20:12:23.630Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-17T20:12:23.630Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-02-17T20:12:23.631Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-17T20:12:23.631Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.5" with engines:
2023-02-17T20:12:23.631Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-02-17T20:12:23.632Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-17T20:12:23.632Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-02-17T20:12:23.633Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-02-17T20:12:23.633Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-17T20:12:23.633Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-02-17T20:12:23.634Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-02-17T20:12:23.634Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-17T20:12:23.634Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-02-17T20:12:23.635Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-17T20:12:23.635Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-02-17T20:12:23.635Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-02-17T20:12:23.636Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-17T20:12:23.636Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-02-17T20:12:23.637Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-02-17T20:12:23.637Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-17T20:12:23.637Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-02-17T20:12:23.638Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-02-17T20:12:23.638Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-17T20:12:23.638Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-02-17T20:12:23.639Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-17T20:12:23.639Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-02-17T20:12:23.639Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-02-17T20:12:23.640Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-17T20:12:23.640Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-02-17T20:12:23.640Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-02-17T20:12:23.641Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-17T20:12:23.641Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-02-17T20:12:23.642Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-02-17T20:12:23.657Z root INFO Resolve plugins list: 65.1 ms [Finished 1.397 s after backend start]
Restoring workspace roots: c:\Users\User\Documents\Arduino\Duo_N3.34
2023-02-17T20:12:23.660Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Program Files\Arduino IDE2\resources\app\plugins\cortex-debug\extension\dist\extension.js": 3.6 ms [Finished 1.401 s after backend start]
isTempSketch: false. Input was c:\Users\User\Documents\Arduino\Duo_N3.34\Duo_N3.34.ino
2023-02-17T20:12:23.663Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.5" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 2.5 ms [Finished 1.403 s after backend start]
2023-02-17T20:12:23.675Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-builtin-cpp\extension": 11.7 ms [Finished 1.415 s after backend start]
2023-02-17T20:12:23.677Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-builtin-json\extension": 2.1 ms [Finished 1.417 s after backend start]
2023-02-17T20:12:23.677Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 0.3 ms [Finished 1.418 s after backend start]
2023-02-17T20:12:23.910Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-language-pack-bg\extension": 232.9 ms [Finished 1.650 s after backend start]
2023-02-17T20:12:24.087Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-language-pack-cs\extension": 176.5 ms [Finished 1.827 s after backend start]
2023-02-17T20:12:24.100Z daemon INFO INFO[0000] Using config file: c:\Users\User\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.29.0
INFO[0000] Executing `arduino-cli daemon`
{"IP":"127.0.0.1","Port":"60223"}
2023-02-17T20:12:24.101Z daemon INFO Daemon is running.
2023-02-17T20:12:24.226Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-language-pack-de\extension": 138.9 ms [Finished 1.966 s after backend start]
2023-02-17T20:12:24.230Z daemon INFO INFO[0000] Loading hardware from: c:\Users\User\AppData\Local\Arduino15\packages
2023-02-17T20:12:24.327Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-language-pack-es\extension": 101.1 ms [Finished 2.067 s after backend start]
2023-02-17T20:12:24.327Z daemon INFO INFO[0000] Loading package arduino from: C:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware
INFO[0000] Checking signature error="opening signature file: open C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: Das System kann die angegebene Datei nicht finden." index="C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json" signatureFile="C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig"
INFO[0000] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0000] Loaded platform platform="arduino:avr@1.8.6"
INFO[0000] Checking signature error="opening signature file: open C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\installed.json.sig: Das System kann die angegebene Datei nicht finden." index="C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\installed.json" signatureFile="C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\installed.json.sig"
INFO[0000] Loaded platform platform="arduino:megaavr@1.8.8"
INFO[0000] Checking existence of 'tools' path: C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loading tools from dir: C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loaded tool tool="arduino:arduinoOTA@1.3.0"
INFO[0000] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino5"
INFO[0000] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0000] Loaded tool tool="arduino:avrdude@6.3.0-arduino17"
INFO[0000] Loading package builtin from: C:\Users\User\AppData\Local\Arduino15\packages\builtin
INFO[0000] Checking existence of 'tools' path: C:\Users\User\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loading tools from dir: C:\Users\User\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loaded tool tool="builtin:ctags@5.8-arduino11"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.6"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.8"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.3.3"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.3.5"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.4.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.12.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.13.0"
INFO[0000] Checking signature index="c:\\Users\\User\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\User\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
INFO[0000] Adding libraries dir dir="C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\libraries" location=platform
INFO[0000] Adding libraries dir dir="C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
INFO[0000] Loading libraries index file index="c:\\Users\\User\\AppData\\Local\\Arduino15\\library_index.json"
2023-02-17T20:12:24.420Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-language-pack-fr\extension": 93.3 ms [Finished 2.161 s after backend start]
2023-02-17T20:12:24.422Z daemon INFO INFO[0000] Adding libraries dir dir="C:\\Users\\User\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0000] Adding libraries dir dir="c:\\Users\\User\\Documents\\Arduino\\libraries" location=user
2023-02-17T20:12:24.473Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-language-pack-hu\extension": 53.2 ms [Finished 2.214 s after backend start]
2023-02-17T20:12:24.549Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-language-pack-it\extension": 75.1 ms [Finished 2.289 s after backend start]
2023-02-17T20:12:24.627Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-language-pack-ja\extension": 77.9 ms [Finished 2.367 s after backend start]
2023-02-17T20:12:24.628Z discovery-log INFO start request start watch
2023-02-17T20:12:24.629Z discovery-log INFO start requested start watch
2023-02-17T20:12:24.629Z discovery-log INFO start resolved watching
2023-02-17T20:12:24.631Z daemon INFO INFO[0000] starting discovery builtin:mdns-discovery process
INFO[0000] starting discovery builtin:serial-discovery process
2023-02-17T20:12:24.631Z daemon INFO ERRO[0000] Discovery builtin:serial-discovery failed to run: discovery builtin:serial-discovery process not started: exec: "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\serial-discovery\\1.4.0\\serial-discovery": file does not exist
2023-02-17T20:12:24.708Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-language-pack-ko\extension": 81.9 ms [Finished 2.449 s after backend start]
2023-02-17T20:12:24.747Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-language-pack-nl\extension": 38.3 ms [Finished 2.487 s after backend start]
2023-02-17T20:12:24.829Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-language-pack-pl\extension": 81.9 ms [Finished 2.569 s after backend start]
2023-02-17T20:12:24.928Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-language-pack-pt-BR\extension": 99.0 ms [Finished 2.668 s after backend start]
2023-02-17T20:12:25.030Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-language-pack-ru\extension": 101.2 ms [Finished 2.770 s after backend start]
2023-02-17T20:12:25.031Z daemon INFO INFO[0001] started discovery builtin:mdns-discovery process
INFO[0001] sending command HELLO 1 "arduino-cli 0.29.0" to discovery builtin:mdns-discovery
INFO[0001] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
INFO[0001] sending command START_SYNC to discovery builtin:mdns-discovery
INFO[0001] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
2023-02-17T20:12:25.104Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-language-pack-tr\extension": 73.2 ms [Finished 2.844 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
2023-02-17T20:12:25.153Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-language-pack-uk\extension": 49.4 ms [Finished 2.893 s after backend start]
Opening channel for service path '/services/ide-updater'.
2023-02-17T20:12:25.241Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-language-pack-zh-hans\extension": 88.2 ms [Finished 2.982 s after backend start]
2023-02-17T20:12:25.242Z root INFO Deploy plugins list: 65.1 ms [Finished 2.982 s after backend start]
2023-02-17T20:12:25.439Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 164.8 ms [Finished 1.523 s after frontend start]
2023-02-17T20:12:25.521Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <c:\Users\User\Documents\Arduino\Duo_N3.34\Duo_N3.34.ino>, response: <c:\Users\User\Documents\Arduino\Duo_N3.34>.
2023-02-17T20:12:25.693Z root INFO Start frontend contributions: 385.8 ms [Finished 1.656 s after frontend start]
2023-02-17T20:12:25.693Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-02-17T20:12:25.694Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2023-02-17T20:12:25.694Z root INFO >>> Restoring the layout state...
2023-02-17T20:12:25.695Z root INFO ------- SERIALIZED LAYOUT DATA -------
2023-02-17T20:12:25.695Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/User/Documents/Arduino/Duo_N3.34/Duo_N3.34.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":211,\"column\":2},\"position\":{\"lineNumber\":211,\"column\":2}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":289,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"},{"constructionOptions":{"factoryId":"serial-monitor"}}],"currentIndex":0}},"pinned":[false,false],"size":501,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":248},"rightPanel":{"type":"sidepanel","items":[]}}
2023-02-17T20:12:25.696Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2023-02-17T20:12:25.715Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49] Waiting for backend deployment: 161.1 ms [Finished 1.815 s after frontend start]
2023-02-17T20:12:25.972Z sketches-service WARN Mismatching sketch file <Duo_02.ino> and sketch folder name <Duo_01>. Skipping
2023-02-17T20:12:25.973Z sketches-service WARN Mismatching sketch file <Duo_03.ino> and sketch folder name <Duo_01>. Skipping
2023-02-17T20:12:25.973Z sketches-service WARN Mismatching sketch file <Duo_04.ino> and sketch folder name <Duo_01>. Skipping
2023-02-17T20:12:25.974Z sketches-service WARN Mismatching sketch file <Duo_05.ino> and sketch folder name <Duo_01>. Skipping
2023-02-17T20:12:25.974Z sketches-service WARN Mismatching sketch file <Duo_06.ino> and sketch folder name <Duo_01>. Skipping
2023-02-17T20:12:26.075Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768) starting instance
2023-02-17T20:12:26.226Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49] Sync of 21 plugins: 518.1 ms [Finished 2.333 s after frontend start]
2023-02-17T20:12:26.524Z root INFO <<< The layout has been successfully restored.
2023-02-17T20:12:26.585Z root INFO Initialize the workbench layout: 944.0 ms [Finished 2.631 s after frontend start]
2023-02-17T20:12:26.586Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2023-02-17T20:12:26.587Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][marus25.cortex-debug]: Loaded contributions.
2023-02-17T20:12:26.587Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][arduino.vscode-arduino-tools]: Loaded contributions.
2023-02-17T20:12:26.588Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][vscode.cpp]: Loaded contributions.
2023-02-17T20:12:26.588Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][vscode.json]: Loaded contributions.
2023-02-17T20:12:26.589Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][vscode.json-language-features]: Loaded contributions.
2023-02-17T20:12:26.589Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-bg]: Loaded contributions.
2023-02-17T20:12:26.589Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
2023-02-17T20:12:26.590Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
2023-02-17T20:12:26.590Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
2023-02-17T20:12:26.590Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
2023-02-17T20:12:26.591Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-hu]: Loaded contributions.
2023-02-17T20:12:26.591Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
2023-02-17T20:12:26.591Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
2023-02-17T20:12:26.591Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-ko]: Loaded contributions.
2023-02-17T20:12:26.592Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
2023-02-17T20:12:26.592Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-pl]: Loaded contributions.
2023-02-17T20:12:26.592Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
2023-02-17T20:12:26.593Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
2023-02-17T20:12:26.593Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
2023-02-17T20:12:26.593Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-uk]: Loaded contributions.
2023-02-17T20:12:26.594Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
2023-02-17T20:12:26.594Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49] Load contributions of 21 plugins: 58.9 ms [Finished 2.691 s after frontend start]
2023-02-17T20:12:26.648Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2023-02-17T20:12:26.648Z root WARN a registered grammar configuration for 'cpp' language is overridden
2023-02-17T20:12:26.970Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): PluginManagerExtImpl/init()
2023-02-17T20:12:26.972Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(cortex-debug@1.5.1 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:26.976Z root INFO [hosted-plugin: 23768] Debugger contribution has been registered: cortex-debug
2023-02-17T20:12:26.977Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(vscode-arduino-tools@0.0.2-beta.5 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)2023-02-17T20:12:26.977Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(cpp@1.52.1 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:26.978Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(json@1.46.1 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:26.978Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(json-language-features@1.46.1 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:26.978Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(vscode-language-pack-bg@1.48.3 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:26.979Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(vscode-language-pack-cs@1.53.2 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:26.979Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(vscode-language-pack-de@1.53.2 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:26.980Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(vscode-language-pack-es@1.53.2 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:26.980Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(vscode-language-pack-fr@1.53.2 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:26.981Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(vscode-language-pack-hu@1.48.3 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:26.981Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(vscode-language-pack-it@1.53.2 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:26.981Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(vscode-language-pack-ja@1.53.2 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:26.982Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(vscode-language-pack-ko@1.53.2 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:26.982Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:26.982Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(vscode-language-pack-pl@1.53.2 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:26.983Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(vscode-language-pack-pt-BR@1.53.2 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)2023-02-17T20:12:26.983Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(vscode-language-pack-ru@1.53.2 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:26.983Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(vscode-language-pack-tr@1.53.2 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:26.984Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(vscode-language-pack-uk@1.48.3 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:26.984Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): initializing(vscode-language-pack-zh-hans@1.53.2 with C:\Program Files\Arduino IDE2\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-02-17T20:12:27.049Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2023-02-17T20:12:27.129Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE2\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
2023-02-17T20:12:27.147Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][marus25.cortex-debug]: Started plugin.
2023-02-17T20:12:27.148Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][arduino.vscode-arduino-tools]: Started plugin.2023-02-17T20:12:27.148Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][vscode.cpp]: Started plugin.
2023-02-17T20:12:27.148Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][vscode.json]: Started plugin.
2023-02-17T20:12:27.149Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][vscode.json-language-features]: Started plugin.
2023-02-17T20:12:27.150Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-bg]: Started plugin.
2023-02-17T20:12:27.150Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-cs]: Started plugin.
2023-02-17T20:12:27.150Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-de]: Started plugin.
2023-02-17T20:12:27.150Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-es]: Started plugin.
2023-02-17T20:12:27.151Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-fr]: Started plugin.
2023-02-17T20:12:27.151Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-hu]: Started plugin.
2023-02-17T20:12:27.151Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-it]: Started plugin.
2023-02-17T20:12:27.152Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-ja]: Started plugin.
2023-02-17T20:12:27.152Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-ko]: Started plugin.
2023-02-17T20:12:27.152Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-nl]: Started plugin.
2023-02-17T20:12:27.153Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-pl]: Started plugin.
2023-02-17T20:12:27.153Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
2023-02-17T20:12:27.153Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-ru]: Started plugin.
2023-02-17T20:12:27.153Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-tr]: Started plugin.
2023-02-17T20:12:27.155Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-uk]: Started plugin.
2023-02-17T20:12:27.155Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
2023-02-17T20:12:27.157Z root INFO [hosted-plugin: 23768] PLUGIN_HOST(23768): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE2\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2023-02-17T20:12:27.180Z root INFO [hosted-plugin: 23768] Debug configuration provider has been registered: cortex-debug, trigger: 1
2023-02-17T20:12:27.182Z root INFO [hosted-plugin: 23768] GDB server console created
2023-02-17T20:12:27.191Z root INFO [f21a2ad5-935a-4be1-ba48-e026bcf6dd49] Start of 21 plugins: 601.9 ms [Finished 3.297 s after frontend start]
2023-02-17T20:12:27.669Z root INFO Replace loading indicator with ready workbench UI (animation): 856.6 ms [Finished 3.548 s after frontend start]
2023-02-17T20:12:27.670Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2023-02-17T20:12:27.670Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
2023-02-17T20:12:27.678Z root INFO Frontend application start: 2257.0 ms [Finished 5.408 s after backend start]
2023-02-17T20:12:27.706Z sketches-service WARN Mismatching sketch file <Duo_02.ino> and sketch folder name <Duo_01>. Skipping
2023-02-17T20:12:27.706Z sketches-service WARN Mismatching sketch file <Duo_03.ino> and sketch folder name <Duo_01>. Skipping
2023-02-17T20:12:27.707Z sketches-service WARN Mismatching sketch file <Duo_04.ino> and sketch folder name <Duo_01>. Skipping
2023-02-17T20:12:27.707Z sketches-service WARN Mismatching sketch file <Duo_05.ino> and sketch folder name <Duo_01>. Skipping
2023-02-17T20:12:27.707Z sketches-service WARN Mismatching sketch file <Duo_06.ino> and sketch folder name <Duo_01>. Skipping
Checking for update
2023-02-17T20:12:27.908Z root INFO Starting language server: arduino:megaavr:nona4809
Update for version 2.0.3 is not available (latest version: 2.0.3, downgrade is allowed).
2023-02-17T20:12:28.427Z root ERROR ---- !!!SLOW!!! DURATION: search took 540.657 ms. Args: [{"type":"Updatable"}] ----
2023-02-17T20:12:28.457Z daemon INFO INFO[0004] Searching tools required for board arduino:megaavr:nona4809
2023-02-17T20:12:28.457Z daemon INFO INFO[0004] Required tool tool="arduino:arduinoOTA@1.3.0"
INFO[0004] Required tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino5"
INFO[0004] Required tool tool="arduino:avrdude@6.3.0-arduino17"
INFO[0004] Adding libraries dir dir="C:\\Users\\User\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0004] Adding libraries dir dir="C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\libraries" location=platform
2023-02-17T20:12:28.458Z daemon INFO INFO[0004] Adding libraries dir dir="c:\\Users\\User\\Documents\\Arduino\\libraries" location=user
2023-02-17T20:12:28.646Z root WARN Widget was activated, but did not accept focus after 2000ms: serial-monitor
2023-02-17T20:12:28.699Z daemon INFO INFO[0004] Resolving include AS5600.h for arch megaavr
INFO[0004] found better lib lib=AS5600 prio=643
2023-02-17T20:12:28.760Z daemon INFO INFO[0004] Resolving include Wire.h for arch megaavr
INFO[0004] found better lib lib=Wire prio=64C
2023-02-17T20:12:28.823Z daemon INFO INFO[0004] Resolving include Bounce2.h for arch megaavr
INFO[0004] found better lib lib=Bounce2 prio=643
2023-02-17T20:12:28.885Z daemon INFO INFO[0005] Resolving include EEPROM.h for arch megaavr
INFO[0005] found better lib lib=EEPROM prio=64C
2023-02-17T20:12:29.866Z daemon INFO INFO[0006] Searching tools required for board arduino:megaavr:nona4809
INFO[0006] Required tool tool="arduino:arduinoOTA@1.3.0"
2023-02-17T20:12:29.867Z daemon INFO INFO[0006] Required tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino5"
INFO[0006] Required tool tool="arduino:avrdude@6.3.0-arduino17"
Arduino IDE.exeArduino IDE.exeArduino IDE.exe
