IDE does not work on COM1, I have CH340 installed. I have the latest IDE version.
Hi @mikemarcu. Please perform this experiment to verify that COM1 is your Arduino board:
- Disconnect the USB cable of the Arduino board from your computer.
- Select Tools > Port from the Arduino IDE menus.
- Take note of the ports (if any) listed in the menu.
- Close the Tools menu.
The ports list is only updated when the Tools menu is re-opened, so this step is essential. - Connect the Arduino board to your computer with a USB cable.
- Select Tools > Port from the Arduino IDE menus. - If a new port is listed in the menu, that is the port of your Arduino board.
If you saw a new port appear at the last step, select that port from the Tools > Port menu and try uploading again.
If this doesn't solve the problem, please reply here on this forum topic with the answers to the following questions:
- While following those instructions, did you see a port in the Tools > Port menu at step (6) that was not present at step (3)?
- If you did see a new port, was the upload successful after you selected that port?
I changed the USB cable that worked yesterday evening, (you buy China, you China quality) and now it seems to work. And YES, I see more COM ports, I'll keep you posted. Thanks,
