I cannot find a way of making the LED go high from the readString .
#include <SPI.h>
#include <String.h>
#include <Ethernet.h>
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = {
192,168,1,9 }; // ip in lan
byte gateway[] = {
192, 168, 1, 1 }; // internet access via router
byte subnet[] = {
255, 255, 255, 0 }; //subnet mask
Server server(80); //server port
int ledPin = 4; // LED pin
char link[]="http://www.google.co.uk"; //link data
// char c[10];
String readString = String(30); //string for fetching data from address
boolean LEDON = false; //LED status flag
//String String2 = "L=1";
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
//Set pin 4 to output
pinMode(ledPin, OUTPUT);
//enable serial datada print
// Create a client connection
Client client = server.available();
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 30) {
//store characters to string
readString +(c); ///changed from" readString.append(c);"
//output chars to serial port
Serial.print(c);
//delay(100);
//if HTTP request has ended
if (c == '\n')
// check if LED should be lighted
if(readString.contains("L=1"))///heres the problem, giving error: 'class string' has no member named 'contains'.
//I've inexpertly tried using indexOf
//led has to be turned ON
digitalWrite(ledPin, HIGH); // set the LED on
//delay(1000);
LEDON = true;
Serial.println( "ON");
//led has to be turned OFF
digitalWrite(ledPin, LOW); // set the LED OFF
Serial.println ("off");
LEDON = false;
// now output HTML data starting with standart header
client.println("Content-Type: text/html");
client.println();
//set background to yellow
client.print("<body style=background-color:grey>");
//send first heading
client.println("<font color='red'><h1> WEB ARDUINO TEST</font></h1>");
client.println("<hr />");
//controlling led via checkbox
client.println("<h1>LED control</h1>");
//address will look like http://192.168.1.110/?L=1 when submited
//client.println("<form method=get name=LED><input type=checkbox name=L value=1>LED
<input type=submit value=submit></form>");
client.println("
//printing LED status
client.print("<font size='5[ch8242]>LED status: ");
if (LEDON)
client.println("<font color='green' size='5[ch8242]>ON");
client.println("<font color='grey' size='5[ch8242]>OFF");
client.println("</body></html>");
//clearing string for next read
readString="";
//stopping client
client.stop();
Any answers or hints or clues would be most gratefully received-Im finding it hard to visualise how the readString is behaving.
many thanx
mmj
thanks, I've amended the code and am now trying to get a consequence from the LED "on" URL.. the old code had it like this:
LEDON = true;
}else{
LEDON = false;
but it seems that doesnt wash anymore
thanks again for your help
Hi
Ive used the length function with success, though its a bit blunt..Now ive got a working system I can tweak it till its better
#include <SPI.h>
#include <String.h>
byte mac[] = {
byte ip[] = {
byte gateway[] = {
byte subnet[] = {
// char c[10];
//start Ethernet
if (client) {
readString += c;
//Serial.print(c);
delay(100);
Serial.println ( readString);
//delay(100);
if (c == '\n')
if (readString.length() >19) // this works but seems rather inelegant:)
//delay(1000);
LEDON = true;
LEDON = false;
client.println();
client.println("
if (LEDON)
readString="";
//stopping client
client.stop();
any input is really welcome, and thanks again for your help
mmj
it was to check that the readString was getting filled. it results in:
3
G
GE
GET
GET
GET /
GET /?
GET /?
GET /? H
GET /? HT
GET /? HTT
GET /? HTTP
GET /? HTTP/
GET /? HTTP/1
GET /? HTTP/1.
GET /? HTTP/1.1
GET /? HTTP/1.1
GET /? HTTP/1.1
off
G
GE
GET
GET
GET /
GET /?
GET /?L
GET /?L=
GET /?L=1
GET /?L=1
GET /?L=1 H
GET /?L=1 HT
GET /?L=1 HTT
GET /?L=1 HTTP
GET /?L=1 HTTP/
GET /?L=1 HTTP/1
GET /?L=1 HTTP/1.
GET /?L=1 HTTP/1.1
GET /?L=1 HTTP/1.1
GET /?L=1 HTTP/1.1
ON
so I then used the length method and found the tipping point number by trial and error :-[
Why? You notice (or perhaps you didn't) that the message ends with a carriage return. So, terminate reading when a carriage return is detected, and don't add that to the string.
Suppose the string had been "GET /?L=0 HTTP/1.1". Would you still turn the LED on?
Turning the LED on because you have read 19 characters is by no means the correct thing to do.
Now that you are getting a complete string (although not quite correctly), it's time to learn how to properly parse the string. The indexOf function will tell you where the ? is in the string. Create a substring from the next character on ("L=0 HTTP/1.1"). Then, use indexOf on that string to find the space. Create a substring up to that position ("L=0"). Then, parse this string the same way to get the L and the 0 or 1. Decide whether to turn the LED on or off intelligently.
#include <SPI.h>
#include <String.h>
byte mac[] = {
byte ip[] = {
192,168,2,2 }; // ip in lan
byte gateway[] = {
//192, 168, 1, 1 };// internet access via router
192,168,2,1 }; // internet access via ethernet connection on mac
byte subnet[] = {
//start Ethernet
//enable serial data print
if (client) {
readString += c; //store characters to string
if (c == '\n')
int locateQuestionmark = readString.indexOf('?');
Serial.println (readString);
Serial.println ("The index of the ? in the string " + readString + " is " + locateQuestionmark);
if (readString.substring(6,9) == "L=1")
//delay(1000);
LEDON = true;
LEDON = false;
client.println();
client.println("
if (LEDON)
readString="";
//stopping client
client.stop();
next stage is to find out how to take this off my LAN and accessible via the www.
You probably don't need to use the #include <String.h> with the latest IDE. Also, if you want to make the arduino accessable from the outside, if you use a router, in the router port foward port 80 to the arduino IP address on your lan, and then use a dynamic IP address service like you.no-ip.com to connect from the net.
