I have a copper cylinder with a diameter of 7.79 cm, and it has a single hole on its surface with a 3 mm diameter. The cylinder is rotating on its axis with the help of stepper motor belt and pulley system. My goal is to locate the hole on the surface of the cylinder once the rotation stops. To achieve this, I plan to establish a feedback loop using a sensor capable of detecting the hole. This sensor will communicate with an Arduino to adjust the tube's position until the hole becomes visible to sensor. Which sensor should I use for detecting such a small hole/pit. I am new to arduino. Please suggest simple solutions, if possible.
