I have a basic program I’m testing to make it part of a larger project later. Everything works as it should. It measures temperature and turns a relay on/off at different temperatures.
I’m also trying to have an indication of when the fan is on or off.
The code at lines 113 to 119 always returns OFF. I’m pretty sure the problem is in line 113, I haven’t figured out how to say it.
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
// Addresses of 9 DS18B20s Change these to match temp sensors used
uint8_t sensor1[8] = { 0x28, 0x9F, 0x9D, 0x7A, 0x00, 0x00, 0x00, 0x63 }; //battery 1--#16
uint8_t sensor2[8] = { 0x28, 0xC9, 0xEF, 0x7C, 0x00, 0x00, 0x00, 0x18 }; //battery 2--#14
//uint8_t sensor3[8] = { 0x28, 0xFF, 0x5F, 0x98, 0xA1, 0x15, 0x04, 0x60 };//battery 3--#1
//uint8_t sensor4[8] = { 0x28, 0xFF, 0x11, 0x57, 0x73, 0x15, 0x01, 0xE1 };//battery 4--#12
//uint8_t sensor5[8] = { 0x28, 0xFF, 0x2E, 0x9F, 0x81, 0x15, 0x01, 0xED };//battery 5--#2
//uint8_t sensor6[8] = { 0x28, 0xFF, 0x1C, 0xB3, 0x61, 0x15, 0x01, 0x4F };//battery6--#5
//uint8_t sensor7[8] = { 0x28, 0xFF, 0x21, 0x43, 0x74, 0x15, 0x03, 0x95 };//cabin--#15
//uint8_t sensor8[8] = { 0x00, 0xC9, 0xEF, 0x7C, 0x00, 0x00, 0x00, 0x18 };//heater--#17
//uint8_t sensor9[8] = { 0x00, 0x9F, 0x9D, 0x7A, 0x00, 0x00, 0x00, 0x63 };//outside--#13
const int relay_1 = 7;
const int relay_2 = 3;
//const int relay_3 = 4;
//const int relay_4 = 5;
const int relay1_temp_below = 69;
const int relay1_temp_above = 70;
const int relay2_temp_below = 69;
const int relay2_temp_above = 70;
//const int relay3_temp_below = 45;
//const int relay3_temp_above = 50;
//const int relay4_temp_below = 45;
//const int relay4_temp_above = 50;
void setup(void) {
sensors.begin();
// Serial.println();
pinMode(relay_1, OUTPUT);
pinMode(relay_2, OUTPUT);
//pinMode(relay_3, OUTPUT);
//pinMode(relay_4, OUTPUT);
//all relays are set to off
digitalWrite(relay_1, LOW);
digitalWrite(relay_2, LOW);
//digitalWrite(relay_3, LOW);
//digitalWrite(relay_4, LOW);
void loop(void) {
sensors.requestTemperatures();
//++++++++++++++++++++++++++++Temperature
float temperature1 = sensors.getTempF(sensor1);
float temperature2 = sensors.getTempF(sensor2);
// float temperature3 = sensors.getTempF(sensor3);
//float temperature4 = sensors.getTempF(sensor4);
//float temperature5 = sensors.getTempF(sensor5);
//float temperature6 = sensors.getTempF(sensor6);
//float temperature7 = sensors.getTempF(sensor7);
//float temperature8 = sensors.getTempF(sensor8);
//float temperature9 = sensors.getTempF(sensor9);
Serial.print("Temp 1 ");
Serial.println(temperature1);
Serial.print("Temp 2 ");
Serial.println(temperature2);
//Serial.print ("Batt 3 temp ");
//Serial.println(temperature3);
//Serial.print ("Batt 4 temp ");
//Serial.println(temperature4);
//Serial.print ("Batt 5 temp ");
//Serial.println(temperature5);
//Serial.print ("Batt 6 temp ");
//Serial.println(temperature6);
//Serial.print ("Cabin temp ");
//Serial.println(temperature7);
//Serial.print ("Heat temp ");
//Serial.println(temperature8);
//Serial.print ("Outside temp ");
//Serial.println(temperature9);
Serial.println(" ");
// Cooling fan relay 1
if (temperature1 > relay1_temp_above) {
//Serial.println("Fan : ON");
digitalWrite(relay_1, HIGH);
if (temperature1 < relay1_temp_below) {
//Serial.println("Fan : OFF");
if (relay_1 == HIGH) {
else {Serial.println("Fan : OFF");
//relay 2
if (temperature2 > relay2_temp_above) {
Serial.println("Heat Relay: ON");
digitalWrite(relay_4, HIGH);
//delay(1000);
if (temperature2 < relay2_temp_below) {
Serial.println("Heat Relay: OFF");
//delay(1000);
Serial.println("*********************");
//refresh interval
delay(2500);
What am I doing wrong?
