If Else statements for dot matrix severely slow gyro readings
I'm using the MPU-6050 gyro and an LED dot matrix (MAX2719). To visualise gyro readings, i've created a function that i've called in the loop which essentially should light up certain leds if the gyro roll output is below a certain value (using if else statement). Calling this in the loop severely slows down gyro readings. I've recorded a short clip here of the serial monitor where I rotate the gyro to 90deg without that function in the loop, and with it in the loop after. It doesn't even go to 90 the second time. Should the if else statement be this slow? Or have I implemented it wrong? I've attached my code, and the dot matrix function is the very last. The dot matrix does light up properly btw.
#include <Wire.h>
#include "LedControl.h"
//Declaring some global variables
int gyro_x, gyro_y, gyro_z;
long gyro_x_cal, gyro_y_cal, gyro_z_cal;
boolean set_gyro_angles;
long acc_x, acc_y, acc_z, acc_total_vector;
float angle_roll_acc, angle_pitch_acc;
float angle_pitch, angle_roll;
int angle_pitch_buffer, angle_roll_buffer;
float angle_pitch_output, angle_roll_output;
long loop_timer;
int temp;
LedControl lc=LedControl(12,10,11,3);
#define period 500
void setLED() {
   The MAX72XX is in power-saving mode on startup,
   we have to do a wakeup call
  lc.shutdown(0,false);
  /* Set the brightness to a medium values */
  lc.setIntensity(0,1);
  /* and clear the display */
  lc.clearDisplay(0);
  setLED();
  Wire.begin();                                                        //Start I2C as master
  setup_mpu_6050_registers();                                          //Setup the registers of the MPU-6050
  for (int cal_int = 0; cal_int < 1000 ; cal_int ++){                  //Read the raw acc and gyro data from the MPU-6050 for 1000 times
    read_mpu_6050_data();
    gyro_x_cal += gyro_x;                                              //Add the gyro x offset to the gyro_x_cal variable
    gyro_y_cal += gyro_y;                                              //Add the gyro y offset to the gyro_y_cal variable
    gyro_z_cal += gyro_z;                                              //Add the gyro z offset to the gyro_z_cal variable
    delay(3);                                                          //Delay 3us to have 250Hz for-loop
  // divide by 1000 to get avarage offset
  gyro_x_cal /= 1000;
  gyro_y_cal /= 1000;
  gyro_z_cal /= 1000;
  loop_timer = micros();                                               //Reset the loop timer
void loop(){
 //Subtract the offset values from the raw gyro values
  gyro_x -= gyro_x_cal;
  gyro_y -= gyro_y_cal;
  gyro_z -= gyro_z_cal;
  //Gyro angle calculations....
  //Accelerometer angle calculations....
  angle_pitch_acc -= 0.0;                                              //Accelerometer calibration value for pitch
  angle_roll_acc -= 0.0;                                               //Accelerometer calibration value for roll
  if(set_gyro_angles){                                                 //If the IMU is already started
    angle_pitch = angle_pitch * 0.9996 + angle_pitch_acc * 0.0004;     //Correct the drift of the gyro pitch angle with the accelerometer pitch angle
    angle_roll = angle_roll * 0.9996 + angle_roll_acc * 0.0004;        //Correct the drift of the gyro roll angle with the accelerometer roll angle
  else{        //At first start
    angle_pitch = angle_pitch_acc;                                     //Set the gyro pitch angle equal to the accelerometer pitch angle
    angle_roll = angle_roll_acc;                                       //Set the gyro roll angle equal to the accelerometer roll angle
    set_gyro_angles = true;                                            //Set the IMU started flag
  //To dampen the pitch and roll angles a complementary filter is used
  angle_pitch_output = angle_pitch_output * 0.9 + angle_pitch * 0.1;   //Take 90% of the output pitch value and add 10% of the raw pitch value
  angle_roll_output = angle_roll_output * 0.9 + angle_roll * 0.1;      //Take 90% of the output roll value and add 10% of the raw roll value
  Serial.print(" | Angle  = "); Serial.println(angle_pitch_output);
  writeArduinoOnMatrix();
while(micros() - loop_timer < 4000);                                 //Wait until the loop_timer reaches 4000us (250Hz) before starting the next loop
loop_timer = micros();//Reset the loop timer
void setup_mpu_6050_registers(){
  //Activate the MPU-6050
  Wire.beginTransmission(0x68);                                        //Start communicating with the MPU-6050
  Wire.write(0x6B);                                                    //Send the requested starting register
  Wire.write(0x00);                                                    //Set the requested starting register
  Wire.endTransmission();
  //Configure the accelerometer (+/-8g)
  Wire.write(0x1C);                                                    //Send the requested starting register
  Wire.write(0x10);                                                    //Set the requested starting register
  //Configure the gyro (500dps full scale)
  Wire.write(0x1B);                                                    //Send the requested starting register
  Wire.write(0x08);                                                    //Set the requested starting register
void read_mpu_6050_data(){                                             //Subroutine for reading the raw gyro and accelerometer data
  Wire.write(0x3B);                                                    //Send the requested starting register
  Wire.endTransmission();                                              //End the transmission
  Wire.requestFrom(0x68,14);                                           //Request 14 bytes from the MPU-6050
  while(Wire.available() < 14);                                        //Wait until all the bytes are received
  acc_x = Wire.read()<<8|Wire.read();
  acc_y = Wire.read()<<8|Wire.read();
  acc_z = Wire.read()<<8|Wire.read();
  temp = Wire.read()<<8|Wire.read();
  gyro_x = Wire.read()<<8|Wire.read();
  gyro_y = Wire.read()<<8|Wire.read();
  gyro_z = Wire.read()<<8|Wire.read();
void writeArduinoOnMatrix() {
if  (angle_pitch_output<=45){
byte a[8]={B11110000,B11110000,B11110000,B11110000,B11110000,B11110000,B11110000,B11110000};
  /* now display them one by one with a small delay */
  lc.setRow(0,0,a[0]);
  lc.setRow(0,1,a[1]);
  lc.setRow(0,2,a[2]);
  lc.setRow(0,3,a[3]);
  lc.setRow(0,4,a[4]);
  lc.setRow(0,5,a[5]);
  lc.setRow(0,6,a[6]);
  lc.setRow(0,7,a[7]);
  lc.setRow(0,8,a[8]);
else {
   byte a[8]={B00001111,B00001111,B00001111,B00001111,B00001111,B00001111,B00001111,B00001111};
No, these statements are quite fast, but setting the LED rows need some time. As you set them eight times in that function this might slow the code down noticeably.
lc.setRow(0,8,a[8]); ?
@AWOL: The LedControl library fortunately catches that but accessing an array outside it's limits is nevertheless bad and should be corrected.
Hi. Have you tried running the sketch without Serial.print every loop? sometimes the serial port is really slow even at high baud rates...A solid way to check timing is like:
#define USER_TIME_RES	millis()
//uncomment for 4us resolution
//#define USER_TIME_RES	micros()
const uint16_t testcounter;
uint32_t timecheck;
void testFunction(){
	//function to test here
void setup(){
	Serial.println("starting...");
//make a note of time test starts
	timecheck=USER_TIME_RES;
//run testcounter loops
	for(uint16_t i=0; i<testcounter; i++) testFunction;
//check time finished and print difference
	uint32_t temp = USER_TIME_RES - timecheck;
	Serial.println(temp);
void loop(){}
Hope this helps!
Gyro code by itself works perfectly but when I call other functions in the loop for things like LCD and LEDs, the gyro reading is severely limited. For instance, now when its turned to 90deg, instead of displaying 90 it displays 12deg and starts to slowly creep up to 90deg. How can I go about fixing that? Do you have to structure the loop in a certain way so that calling functions doesn't slow down the reading?
#include <Wire.h>
boolean flag = true;
const int refreshrate = 250;
unsigned long currentMillis = 0;
long loop_timer;
int temp;
LedControl lc=LedControl(12,10,11,1);
#define period 0
LiquidCrystal_I2C lcd(0x3f,16,2);
void setLED() {
  lc.clearDisplay(0);
    lcd.init();                      // initialize the lcd
  lcd.init();
  // Print a message to the LCD.
  lcd.backlight();
  setLED();
  Wire.setClock(400000L);
    //delay(3);                                                          //Delay 3us to have 250Hz for-loop
  gyro_x_cal /= 1000;
  gyro_y_cal /= 1000;
  gyro_z_cal /= 1000;
void loop(){
  updateSensor();
  writeLCD();
void updateSensor(){
  //Gyro angle calculations . Note 0.0000611 = 1 / (250Hz x 65.5)
  angle_pitch += gyro_x * 0.0000611;                                   //Calculate the traveled pitch angle and add this to the angle_pitch variable
  angle_roll += gyro_y * 0.0000611;                                    //Calculate the traveled roll angle and add this to the angle_roll variable
  //0.000001066 = 0.0000611 * (3.142(PI) / 180degr) The Arduino sin function is in radians
  angle_pitch += angle_roll * sin(gyro_z * 0.000001066);               //If the IMU has yawed transfer the roll angle to the pitch angel
  angle_roll -= angle_pitch * sin(gyro_z * 0.000001066);               //If the IMU has yawed transfer the pitch angle to the roll angel
  acc_total_vector = sqrt((acc_x*acc_x)+(acc_y*acc_y)+(acc_z*acc_z));  //Calculate the total accelerometer vector
  //57.296 = 1 / (3.142 / 180) The Arduino asin function is in radians
  angle_pitch_acc = asin((float)acc_y/acc_total_vector)* 57.296;       //Calculate the pitch angle
  angle_roll_acc = asin((float)acc_x/acc_total_vector)* -57.296;       //Calculate the roll angle
    if  (-90 <= angle_pitch_output && angle_pitch_output <= 0){
      lc.setLed(0,0,7,false);
    else if (1 <= angle_pitch_output && angle_pitch_output <= 90){
      lc.setLed(0,0,7,true);
void writeLCD() {
    lcd.setCursor(1,1);
    lcd.print(angle_pitch_output);
    lcd.setCursor(11,1);
    lcd.print(angle_roll_output);
What are these mysterious functions doing ?
Please post your full program
Did you Read this before posting a programming question
Sorry was initially thinking it may be a known issue so could have a generic answer, but posted entire sketch now.
I have a function to read the gyro data, and two other now simplified functions to display on LCD and LED dot matrix displays, it seems that when I call the dot matrix function, the gyro works fine but when I also call the LCD the gyro reading is severely impacted as shown here
@dully737
TOPIC MERGED.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
It will help you get the best out of the forum.
Thanks for the merge I couldn't see my previous post for some reason so thought it got removed.
@Luckyfish13 got rid of the Serial.print and it doesn't seem to do much. For the timing function I seem to be getting 0, but on timing - how do you utilise that in the loops? Would you time how long functions takes and then use that in the loop?
Would appreciate some links that help explain this more as I think that's the key for me here
I2C LCD updates are, in my limited experience, very slow, because they're typically 4 bit interfaces, implemented on eight bit port extenders.
