currentTime = String(hour()) + ":" + minute() + ":" + second();
if ((currentTime >= "17:20:0") && (currentTime <= "17:20:5"))
do something...
is this gonna work properly?
do something...
Don't post snippets (Snippets R Us!)
and no it won't because you can't expect that alphabetical order is like mathematical order (eg like 17:20:5 and 17:20:50)
if you want. to compare time, the easiest way is to built a mathematical representation of your moment in the day for example number of seconds since midnight
unsigned long currentTime = 3600ul * hour() + 60ul * minute() + second();
this would let you compare moment of the same day
yep i want it run between 17:20:00 and 17:20:05
as discussed don't use text to do math, use numbers...
you create a function like this
inline uint32_t secondsSinceMidnight(uint8_t h, uint8_t m, uint8_t s) {
return 3600ul * h + 60ul * m + s;
then in your code you do
if (secondsSinceMidnight(hour(), minute(), second()) >= secondsSinceMidnight(17,20,5)) {
// on or after 17:20:05
// before 17:20:05
I think so. But it may fail with different times. Find out yourself.
yeah
String t1 = "17:20:5";
String t2 = "17:20:30";
if (t1 > t2) {
Serial.print(t1 + " is greater than " + t2); // crappy code with String
Serial.print(t1 + " is not greater than " + t2); // crappy code with String
void loop() {}
➜ you'll get 17:20:5 is greater than 17:20:30
you would need to have all the times on 2 digits
thanks alot
