If statements with time condition
I am new to the programming and I have a question about the if statements. Is it possible to check a condition for a certain amount before deciding true or false?
For example
If (x=0) {
digitalWrite(13, high)
In this code, even if the x is 0 for a milisecond , it runs the code. What I want the program to do is to run the code if the condition(x=0 in this case) is true for 2 seconds.
I hope I could express myself well. Thank you.
Mmarya:
If (x=0) {
First issue is single “=“ should be “==“.
Your getting there, just rethink what you want done to how your going to code it.
The goal is X == 0 for 2 seconds then do something.
If (x != 0) CheckX == false;
If (x == 0 && CheckX == false ){
CheckX = true;
TimeXwastrue = millis();
Checkingmills = millis();
If ( CheckX && Checkingmills - TimeXwasTrue >= 2000 ) {
digitalWrite(13, high);
Thats basically how I would code it.
Check out this file "elaspedMillis.h" found at Arduino Playground - elapsedMillis Library
This is another way.
Usage
#include <elapsedMillis.h>
elapsedMillis timeElapsed; //declare global if you don't want it reset every time loop runs
// Pin 13 has an LED connected on most Arduino boards.
int led = 13;
// delay in milliseconds between blinks of the LED
unsigned int interval = 2000;
// state of the LED = LOW is off, HIGH is on
boolean ledState = LOW;
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
if (timeElapsed > interval)
ledState = HIGH;
digitalWrite(led, ledState);
If you want to make as sure as possible that a certain condition is true for an x amount of time such as a pin input either you need to use an interrupt (which is probably a tad more than you will want to do as a beginner) or not run an aSync task so creating a function like
  if (checkTwoSeconds(switchpin)) {
    // do whatever
bool checkTwoSeconds(int8_t pin) {
  uint32_t start=millis();
  while(digitalRead(pin)){  //
    if(millis()>start+2000) return true;
  return false;
(corrected for nonsense my bad..sorry)
Mmarya:
The short answer is YES. However the details depend on exactly what you want to achieve. We need more information.
The demo Several Things at a Time illustrates the use of millis() to manage timing without blocking. It may help with understanding the technique.
Have a look at Using millis() for timing. A beginners guide if you need more explanation.
...R
Mmarya:
What I want the program to do is to run the code if the condition(x==0 in this case) is true for 2 seconds.
I find that the easiest way is to restart a timer every time the condition is false. If the timer reaches the desired interval then the condition has been true for that long:
unsigned long LastTimeConditionWasFalse;
  if (x != 0)
    LastTimeConditionWasFalse = millis();
  if (millis() - LastTimeConditionWasFalse >= 2000)
    // Condition (x==0) has been true for two seconds
    // Put your code here
If you want it to trigger only after the condition has been false at least once:
unsigned long LastTimeConditionWasFalse = 0;
  if (x != 0)
  if (LastTimeConditionWasFalse != 0 && millis() - LastTimeConditionWasFalse >= 2000)
    LastTimeConditionWasFalse = 0;  // Prevent re-triggering until the condition goes false again
