#ifdef is ignored
I am using Serial for debug only (or I thought I was) but I find that my #ifdef conditionals are being ignored and on opening a serial monitor the 'debug' Serial commands are being compiled.
Here is a short test example:
//#define SERIAL
#ifdef SERIAL
#endif
#ifdef SERIAL
  Serial.println("Hello");
#endif
Note that "#define SERIAL" is commented, but the serial monitor displays Hello
Hello
Is it me, or is the compiler broken?
IDE 1.8.16 running on Linux.
Maybe you're demonstrating that SERIAL is already a define, somewhere in the Arduino setup itself prior to your code? Maybe, use SERL instead of a very commonly used word like SERIAL?
Just a suggestion, as I have no time to test this. Gotta Run!
C
Thanks!
I purposely used all upper case to hopefully avoid any 'reserved' words, but you are correct, using 'SER' instead of SERIAL has resolved the issue.
If you uncomment the #define, you will get a warning
C:\Users\sterretje\AppData\Local\Temp\arduino_modified_sketch_825645\sketch_jul22a.ino:3:0: warning: "SERIAL" redefined
 #define SERIAL
In file included from sketch\sketch_jul22a.ino.cpp:1:0:
C:\Users\sterretje\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.4\cores\arduino/Arduino.h:54:0: note: this is the location of the previous definition
 #define SERIAL  0x0
You get a warning, but I don't. If I had seen a warning I would have realized the cause.
There is no warning even with verbose set in preferences.
Full verbose output below:
/home/baz/Downloads/arduino-1.8.16/arduino-builder -dump-prefs -logger=machine -hardware /home/baz/Downloads/arduino-1.8.16/hardware -tools /home/baz/Downloads/arduino-1.8.16/tools-builder -tools /home/baz/Downloads/arduino-1.8.16/hardware/tools/avr -built-in-libraries /home/baz/Downloads/arduino-1.8.16/libraries -libraries /home/baz/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10816 -build-path /tmp/arduino_build_232300 -warnings=none -build-cache /tmp/arduino_cache_408604 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr -verbose /home/baz/Arduino/sketch_jul23a/sketch_jul23a.ino
/home/baz/Downloads/arduino-1.8.16/arduino-builder -compile -logger=machine -hardware /home/baz/Downloads/arduino-1.8.16/hardware -tools /home/baz/Downloads/arduino-1.8.16/tools-builder -tools /home/baz/Downloads/arduino-1.8.16/hardware/tools/avr -built-in-libraries /home/baz/Downloads/arduino-1.8.16/libraries -libraries /home/baz/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10816 -build-path /tmp/arduino_build_232300 -warnings=none -build-cache /tmp/arduino_cache_408604 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr -verbose /home/baz/Arduino/sketch_jul23a/sketch_jul23a.ino
Using board 'nano' from platform in folder: /home/baz/Downloads/arduino-1.8.16/hardware/arduino/avr
Using core 'arduino' from platform in folder: /home/baz/Downloads/arduino-1.8.16/hardware/arduino/avr
Detecting libraries used...
/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/baz/Downloads/arduino-1.8.16/hardware/arduino/avr/cores/arduino -I/home/baz/Downloads/arduino-1.8.16/hardware/arduino/avr/variants/eightanaloginputs /tmp/arduino_build_232300/sketch/sketch_jul23a.ino.cpp -o /dev/null
Generating function prototypes...
/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/baz/Downloads/arduino-1.8.16/hardware/arduino/avr/cores/arduino -I/home/baz/Downloads/arduino-1.8.16/hardware/arduino/avr/variants/eightanaloginputs /tmp/arduino_build_232300/sketch/sketch_jul23a.ino.cpp -o /tmp/arduino_build_232300/preproc/ctags_target_for_gcc_minus_e.cpp
/home/baz/Downloads/arduino-1.8.16/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_232300/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/baz/Downloads/arduino-1.8.16/hardware/arduino/avr/cores/arduino -I/home/baz/Downloads/arduino-1.8.16/hardware/arduino/avr/variants/eightanaloginputs /tmp/arduino_build_232300/sketch/sketch_jul23a.ino.cpp -o /tmp/arduino_build_232300/sketch/sketch_jul23a.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /tmp/arduino_cache_408604/core/core_arduino_avr_nano_cpu_atmega328_000dab1d32415a24d3b364a02571d0fb.a
Linking everything together...
/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /tmp/arduino_build_232300/sketch_jul23a.ino.elf /tmp/arduino_build_232300/sketch/sketch_jul23a.ino.cpp.o /tmp/arduino_build_232300/../arduino_cache_408604/core/core_arduino_avr_nano_cpu_atmega328_000dab1d32415a24d3b364a02571d0fb.a -L/tmp/arduino_build_232300 -lm
/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/arduino_build_232300/sketch_jul23a.ino.elf /tmp/arduino_build_232300/sketch_jul23a.ino.eep
/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom /tmp/arduino_build_232300/sketch_jul23a.ino.elf /tmp/arduino_build_232300/sketch_jul23a.ino.hex
/home/baz/Downloads/arduino-1.8.16/hardware/tools/avr/bin/avr-size -A /tmp/arduino_build_232300/sketch_jul23a.ino.elf
Sketch uses 1522 bytes (4%) of program storage space. Maximum is 30720 bytes.
Global variables use 194 bytes (9%) of dynamic memory, leaving 1854 bytes for local variables. Maximum is 2048 bytes.
Setting warnings to ALL should work better.
Right. Thanks!
I never noticed that check box, crazy that it is not the default!
I'm not used to using a graphical IDE for this sort of job which is usually done in CLI.
I find the extra GUI layer confusing.
