My serial always returns ""No message sent", apparently my function does not work, if I try to force send a function through "else" ESP crash, could someone help me?
example code. It contains a lot of other information that I don't think is going into question.
#include <ESPAsyncWebServer.h>
const char* input_color = "value";
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
<meta name="viewport" content="width=device-width, initial-scale=1">
<title>ESP32</title>
</head>
<body>
<h2>FAN 125 PRO</h2>
<input type="color" id="valuecolor" onchange="colorled(this)" value="%COLOR%">
<p><span id="textcolorled">%COLOR%</span></p>
<script>
function corlorled(element) {
var colorled = document.getElementById("valuecolor").value;
document.getElementById("textcolorled").innerHTML = colorled;
console.log(colorled);
var xhm = new XMLHttpRequest();
xhm.open("GET", "/valuecolor"+colorled, true);
xhm.send();
</script>
</body>
</html>
)rawliteral";
String processor(const String& var){
if (var == "COLOR"){
return colorled;
return String();
void setup(){
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/html", index_html, processor);
server.on("/valuecolor", HTTP_GET, [] (AsyncWebServerRequest *request) {
String sms;
if (request->hasParam(input_color)) {
sms = request->getParam(input_color)->value();
colorled = sms;
else {
sms = "No message sent"; // my serial always returns ""No message sent", when I make a color change
/////////////////if I try to force send a function through "else" ESP crash
Serial.println(sms);
request->send(200, "text/plain", "OK");
server.begin();
J-M-L
November 12, 2022, 9:36pm
2
what's colorled ?? show us the full code
colorled is a string that stores the value to return the void setNeoColor .
#include <analogWrite.h>
#define NeoPIN 4 //D4 is 2
#define NUM_LEDS 30 //define number of leds in your strip, mine is 6
int brightness = 100;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, NeoPIN, NEO_RGB + NEO_KHZ800);
const int led = 21;
AsyncWebServer server(80);
const int led_pin = 13;
String colorled = "#ff0000";
<head>
<style>
</style>
</head>
<body>
<script>
<script>
var colorled = document.getElementById("valordacor").value;
xhm.open("GET", "/valuecor"+colorled, true);
xhm.send();
</script>
</body>
</html>
)rawliteral";
return colorled;
return String();
void setup(){
strip.setBrightness(brightness);
strip.begin();
strip.show();
pinMode (led, OUTPUT );
digitalWrite (led, 1 );
setNeoColor(colorled);
String sms;
colorled = sms;
else {
server.begin();
void setNeoColor(String value){
Serial.print("Setting Neopixel...");
// converting Hex to Int
int number = (int) strtol( &value[1], NULL, 16);
// splitting into three parts
int r = number >> 16;
int g = number >> 8 & 0xFF;
int b = number & 0xFF;
// DEBUG
Serial.print("RGB: ");
Serial.print(r, DEC);
Serial.print(" ");
Serial.print(g, DEC);
Serial.print(" ");
Serial.print(b, DEC);
Serial.println(" ");
// setting whole strip to the given color
for(int i=0; i < NUM_LEDS; i++) {
strip.setPixelColor(i, strip.Color( g, r, b ) );
// init
strip.show();
Serial.println("on.");
J-M-L
November 13, 2022, 8:25am
4
wifi is not configured, how can this work?
the HTML is full of spelling mistakes for variables
J-M-L
November 13, 2022, 9:31am
5
I did not look at how the NeoPIN should be defined but I did clean up the HTML and javascript mess, try this
#include <Arduino.h>
#ifdef ESP32
#include <WiFi.h>
#include <AsyncTCP.h>
#elif defined(ESP8266)
#include <ESP8266WiFi.h>
#include <ESPAsyncTCP.h>
#endif
const char* ssid = "XXX";
const char* password = "XXX";
const int led = 21;
String stripRGBColor = "FF0000"; // full red
<head>
<style></style>
<script>
function changeColor() {
var choosenColor = document.getElementById("colorPickerID").value;
console.log("new color chosen : " + choosenColor);
document.getElementById("colorTextID").innerHTML = choosenColor;
var httpRequest = new XMLHttpRequest();
httpRequest.open("GET", "/setColor?color=" + choosenColor.slice(1), true);
httpRequest.send(null);
</script>
</head>
<body>
<input type="color" id="colorPickerID" onchange="changeColor()" value="%COLOR%"> (<span id="colorTextID">%COLOR%</span>)</p>
</body></html>
)rawliteral";
void setNeoColor(String& value) { // parameter is a color as "RRGGBB"
unsigned long colorValue = strtoul(value.c_str(), NULL, 16); // we get the color as "RRGGBB" in HEX
int r = (colorValue >> 16) & 0xFF;
int g = (colorValue >> 8 ) & 0xFF;
int b = colorValue & 0xFF;
for (int i = 0; i < NUM_LEDS; i++) {
strip.setPixelColor(i, strip.Color( g, r, b ) ); // would likely work passing directly colorValue
strip.show();
Serial.print("Set strip color to 0x");
if (r < 0x10) Serial.write('0');
Serial.print(r, HEX);
if (g < 0x10) Serial.write('0');
Serial.print(g, HEX);
if (b < 0x10) Serial.write('0');
Serial.println(b, HEX);
String processor(const String& var) {
if (var == "COLOR") {
return String("#") + stripRGBColor;
return var;
void notFound(AsyncWebServerRequest *request) {
request->send(404, "text/plain", "Not found");
digitalWrite (led, HIGH );
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
if (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.printf("WiFi Failed!\n");
while (true) yield();
Serial.print("Open URL http://"); Serial.println(WiFi.localIP());
server.on("/", HTTP_GET, [](AsyncWebServerRequest * request) {
server.on("/setColor", HTTP_GET, [] (AsyncWebServerRequest * request) {
if (request->hasParam("color")) {
stripRGBColor = request->getParam("color")->value();
setNeoColor(stripRGBColor);
Serial.println("URL error");;
// error
server.onNotFound(notFound);
strip.begin();
server.begin();
void loop() {}
(note that passing a parameter starting with # does not get decoded correctly so I send the color without the # in the URL)
excuse the ignorance, I ended up not sending the server settings, wifi etc.
the HTML was not complete sorry
it works!!, you are amazing i love you.
system
Closed
May 12, 2023, 4:48pm
9
