I'm trying to make a PID with many other logics along with that. But due to some reasons my relay is turning off and not turning on again. Please can u check the code and help me with it!!
#include <Keypad.h>
#include <max6675.h>
#include <FlowSensor.h>
#include <FlowSensor_Type.h>
#define Relay_Pin1 9 // Relay Heater
#define Relay_Pin2 10 // Realy Pump
#define Relay_Pin3 11 // Relay Valve
const int Start_Pin = 12;
int button_state = 0;
float v1;
float setTemp1 = 40.00;
int thermoSCK = 2;
int thermoCS = 3;
int thermoSO = 4;
MAX6675 thermocouple1(thermoSCK, thermoCS, thermoSO);
uint8_t degree[8] = {140,146,146,140,128,128,128,128};
const int Flow_sensor_Pin = 8;
float thresholdFlowRate = 0.0;
volatile int count;
LiquidCrystal_I2C lcd1(0x27, 16, 2); // LCD 1
LiquidCrystal_I2C lcd2(0x26, 16, 2); // LCD 2
pinMode(Relay_Pin1, OUTPUT);
pinMode(Start_Pin, INPUT_PULLUP); // Assuming Start_Pin is pulled up internally
// Initialize the LCDs
lcd1.begin();
lcd2.begin();
lcd1.backlight();
lcd2.backlight();
lcd1.createChar(0, degree);
pinMode(Flow_sensor_Pin, INPUT);
v1 = thermocouple1.readCelsius();
{ if (v1 < setTemp1) {
digitalWrite(Relay_Pin1, HIGH);}
else if (v1 >= setTemp1) {
digitalWrite(Relay_Pin1, LOW);}
delay(2000);
lcd1.clear();
lcd1.setCursor(0, 0);
lcd1.print("SV OIL_HEAT PV");
lcd1.setCursor(0,1);
lcd1.print("40.00C");
lcd1.setCursor(9,1);
lcd1.print(thermocouple1.readCelsius());
#if ARDUINO >= 100
lcd1.write((byte)0);
#else
lcd1.print(0, BYTE);
#endif
lcd1.print('C');
JCA34F
July 22, 2024, 4:57am
2
Try:
else if (v1 >= setTemp1 + 1.0) {
Thanks for ur suggestion. Sorted..
can anyone please explain this error.
void FlowSensor::begin(void (*userFunc)(void), bool pullup = false)
In file included from C:\Users\Kiran\Documents\Arduino\libraries\FlowSensor-Arduino-master\src\FlowSensor.cpp:13:0:
C:\Users\Kiran\Documents\Arduino\libraries\FlowSensor-Arduino-master\src\FlowSensor.h:38:7: error: candidate is: void FlowSensor::begin(void (*)())
void begin(void (*userFunc)(void));
exit status 1
Error compiling for board Arduino Uno.
this program I'm working with
#include <Wire.h>
const int thermo1CLK = 2; // MAX6675 CLK pin sensor1
const int thermo1CS = 3; // MAX6675 CS (Chip Select) pin sensor1
const int thermo1DO = 4; // MAX6675 DO (Data Out) pin sensor1
const int thermo2CLK = 5; // MAX6675 CLK pin sensor2
const int thermo2CS = 6; // MAX6675 CS (Chip Select) pin sensor2
const int thermo2DO = 7; // MAX6675 DO (Data Out) pin sensor2
const int relayPin1 = 9; // Heater pin connected to the relay
const int relayPin2 = 10; // Pump pin connected to the relay
const int relayPin3 = 11; // solinoid valve pin connected to the relay
const int start_pin = 12;
MAX6675 thermocouple1(thermo1CLK, thermo1CS, thermo1DO);
const float TEMPERATURE_THRESHOLD = 40.0; // Adjust as needed
MAX6675 thermocouple2(thermo2CLK, thermo2CS, thermo2DO);
#define type YFS201
unsigned char Flow_sensor_Pin = 8;
volatile int pulseCount; // Flow meter pulse counter
float flowrate = 450; // Number of pulses per milliliter
float totalVolume = 0.0; // Total volume accumulated
float setVolume = 1.0; // Example set volume in liters
void pulseCounter() {
pulseCount++;
pinMode(relayPin1, OUTPUT);
digitalWrite(relayPin1, LOW); // Initialize relay OFF
pinMode(start_pin, INPUT_PULLUP); // Assuming Start_Pin is pulled up internally
lcd1.begin();
lcd2.begin();
lcd1.backlight();
lcd2.backlight();
digitalWrite(Flow_sensor_Pin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(Flow_sensor_Pin), pulseCounter, FALLING);
pulseCount = 0;
lcd2.setCursor(0, 0);
lcd2.print("Given Value: 1L");
lcd2.setCursor(0, 1);
lcd2.print("Present:");
float temperature1 = thermocouple1.readCelsius();
lcd1.clear();
#if ARDUINO >= 100
#else
#endif
lcd1.print('C');
delay(2500);
lcd1.clear();
lcd1.print("Body_Oil_Temp PV");
lcd1.print(thermocouple2.readCelsius());
#if ARDUINO >= 100
#else
#endif
lcd1.print('C');
delay(2500); // Adjust the delay as needed
if (temperature1 > TEMPERATURE_THRESHOLD) {
digitalWrite(relayPin1, HIGH); // Turn the relay ON
digitalWrite(relayPin1, LOW); // Turn the relay OFF
detachInterrupt(digitalPinToInterrupt(Flow_sensor_Pin));
//flowrate = pulseCount / 450; // Replace
if (pulseCount >= 1) { // Only increment volume if there are pulses
flowrate += (pulseCount / flowrate);
// Add current flow to total volume
totalVolume = flowrate;
// Display total volume on LCD
lcd2.setCursor(10, 1);
lcd2.print(totalVolume, 1);
lcd2.print("L");
pulseCount = 0;
// Compare total volume with set volume and display result
if (totalVolume >= setVolume) {
delay(100);
system
Closed
January 20, 2025, 4:34pm
9
