So I have a setup where I've got the nano 33 ble sense connected to an OV7670 camera with these connections :
- 3.3 connected to 3.3
- GND connected GND
- SIOC connected to A5
- SIOD connected to A4
- VSYNC connected to 8
- HREF connected to A1
- PCLK connected to A0
- XCLK connected to 9
- D7 connected to 4
- D6 connected to 6
- D5 connected to 5
- D4 connected to 3
- D3 connected to 2
- D2 connected to 0 / RX
- D1 connected to 1 / TX
- D0 connected to 10
- Reset connected to A2
- PWDN connected to A3
and the nano is hooked up to an arduino due with UART as per this image :
and the arduino due is attached to a tft shield meant for the uno.
The code is as follows :
Nano -
UART NewSerial(digitalPinToPinName(11), digitalPinToPinName(12), NC, NC);
#include <Arduino_OV767X.h>
int bytesPerFrame;
byte data[176 * 144 * 2];
pinMode(A2, OUTPUT);
pinMode(A3, OUTPUT);
digitalWrite(A2, HIGH);
digitalWrite(A3, LOW);
NewSerial.begin(115200);
if (!Camera.begin(QCIF, RGB565, 1)) {
NewSerial.println("Failed to initialize camera!");
while (1);
bytesPerFrame = Camera.width() * Camera.height() * Camera.bytesPerPixel();
Camera.readFrame(data);
NewSerial.write(data, bytesPerFrame);
Due -
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
int x , y , i , c;
Serial1.begin(115200);
uint16_t ID = tft.readID();
if (ID == 0xD3) ID = 0x9481;
tft.begin(ID);
tft.setRotation(1);
Serial1.readBytes(data, 50688);
i = 0;
for (y = 0; y <= 144; y++) {
for (x = 0; x <= 176; x++) {
c = data[i];
c = c << 8;
c = c | data[i + 1];
tft.fillRect(x * 2, y * 2, 2, 2, c);
i = i + 2;
So it is working ok..
But there is one problem :
As we can see the image is divided in half..
Is this because of the horrible connectors I am using?
Do I have to change the baud rate?
Is there a problem with my math?
I am not qualified enough to solve such a problem so please guide me on the path towards getting a perfect image feed.
Edit : I forgot to mention that the due's 5v pin is connected to the nano's vin pin and both boards' ground pins are connected.
Also..
The black pixels at the bottom of the image feed are always present..
A few of them are coloured and I can think of no logical reasons for their appearance.
I need an explanation for this..
Thanks in advance for your help!
