Hello people, I hope you are all well.
I am new to Arduino and electronics/coding in general and i am learning as i go. So any thoughts, suggestions, tips, etc outside of my question would go a long way to helping me improve and i thank you in advance!
I am attempting to build a temperature controlled environment using peltier plates controlled by an uno. In the near future, I would like to add a push button that switches a screen on for 3 seconds. I would like to delay my code for temperature monitoring/changing the state of the peltier plates( i.e peltier plate HIGH or LOW), however i became aware that using the "delay" function pauses the whole loop and would cause problems for monitoring the push button state. Which is where i found "millis". I just cant get my head around it. Here is my current code with the bare bones of the millis function. If you could point me in the right direction on how to implement millis or another, better way of delaying a section of the loop that would be fantastic.
/* An Arduino controlled ciruit that maintains a tempreture range, either by heating the environment or cooling the environment using peltier plates, which are
represented by a red LED and a blue LED as circuits.io doesn't have peltier plates in the components list. It will also use a fan to maximise the environment control*/
//Assign pins their names
//these integers will remain the same i.e constant
const int fan = 3; //pin3 has a fan attached to it
const int cold = 4; //pin 4 has a peltier that cools attached to it
const int hot = 5; //pin 5 has a peltier that heats attached to it
const int therm = A1; //analog pin A1 has a thermometer attached to it
const long interval = 120000 //pause for 2 minutes /*using long as an integer cannot store the
value of time as it will get too large*/
//these integers will change
int thermValue = 0; //integer to store the thermometer value
unsigned long previousMillis = 0;
pinMode(fan, OUTPUT); //set fan pin to output
pinMode(cold, OUTPUT); //set cold pin to output
pinMode(hot, OUTPUT); //set hot pin to output
Serial.begin(9600); //start serial connection
} //close setup
void loop(){
int thermValue = analogRead(therm); //read the value of the thermometer at pin A1
//display the thermometer value in serial view as a celsius value
float mv = (thermValue/1024.0)*5000;
float cel = mv/10;
Serial.print("TEMPRETURE =");
Serial.print(cel);
Serial.print("*C");
//if the tempreture reported by the thermometer in celsius goes above 20 turn on the cooling peltier else remain off
if (cel > 20)
digitalWrite(cold, HIGH);
} //close if statement
digitalWrite(cold, LOW);
}//close else statement
//if the tempreture reported by the thermometer in celsius goes below 15 turn on the fan else remain off
if (cel < 15)
digitalWrite(hot, HIGH);
} //close else statement
digitalWrite(hot, LOW);
} //close the else statement
//if the tempreture reported by the thermometer in celsius goes above 25 turn the fan on else remain off
if (cel > 25)
digitalWrite(fan, HIGH);
} //close the if statement
digitalWrite(fan, LOW);
//if the tempreture reported by the thermometer goes below 10 turn the fan on else remain off
if (cel < 10)
/*commented out the delay as it pauses the whole code. I want to add an
lcd screen with a button that switches on the lcd for a certain ammount
of time and delay would casue problems with monitoring the button state*\
//delay(10000); //delay 10 seconds to stop the constant switching of peltier plates at seesaw tempretres.
} //close loop
Thank you very much!! And i do appreciate any help.
Hey LarryD and evanmars, thanks for the quick reply and apologies for my slow one.
I will have a read and give that code a go later today and let you know the outcome.
Try these mods, should give you a 5 second display update and the 1 degree hysteresis should cut down on the frequent ON / OFF switching.
/* An Arduino controlled circuit that maintains a temperature range, either by heating the environment or cooling the environment using peltier plates, which are
represented by a red LED and a blue LED as circuits.io doesn't have peltier plates in the components list. It will also use a fan to maximize the environment control*/
//these integers will remain the same i.e, constant
const long interval = 120000; //pause for 2 minutes using long as an integer cannot store the
//value of time as it will get too large
int displayUpDate = 5000;
} //close setup
void loop(){
float cel = mv/10;
if(millis() - previousMillis > displayUpDate) // timer has expired
Serial.print("TEMPERATURE = ");
Serial.print(cel);
Serial.print("*C");
previousMillis = millis(); // reset timer
//if the temperature reported by the thermometer in celsius goes above 20 turn on the cooling peltier else remain off
if (cel > 20)
else if(cel < 19)
//if the temperature reported by the thermometer in celsius goes below 15 turn on the fan else remain off
if (cel < 15)
else if(cel > 16)
//if the temperature reported by the thermometer in celsius goes above 25 turn the fan on else remain off
if (cel > 25)
else if(cel < 24)
//if the temperature reported by the thermometer goes below 10 turn the fan on else remain off
if (cel < 10)
else if(cel > 11)
lcd screen with a button that switches on the lcd for a certain amount
of time and delay would cause problems with monitoring the button state*\
//delay(10000); //delay 10 seconds to stop the constant switching of peltier plates at seesaw temperatures.
You may still have a problem with ADC jitter making the temperature reading jump around, if so, report back and we'll work on that.
Hi Robin, I know, I am sorry for my awful reply times, I have been working away in the middle of nowhere and wifi etc were hard to come by. I am now back at home.
Ok, i have tried the new code, and it does work. However. When the temp drops below 10c the fan spins at <1RPM, but when the temp is above 25c the fan spins at over 1000RPM.
Im not sure why.
I'm not sure if i have mentioned but i am using circuits.io to simulate the arduino, could that have something to do it?
Thanks again, and once again i am sorry for my poor replies and thanks for sticking with me!
const int fan = 8; //pin3 has a fan attached to it
const int cold = 6; //pin 4 has a peltier that cools attached to it
const int hot = 7; //pin 5 has a peltier that heats attached to it
bool delayActive = 0;
int displayUpDate = 10;
} //close setup
void loop(){
float cel = mv/10;
Serial.print(cel);
Serial.print("*C");
if (delayActive == 0) {
if (cel > 20)
else if(cel < 19)
if (cel < 15)
else if(cel > 16)
if (cel > 25)
else if(cel < 24)
if (cel < 10)
else if(cel > 11)
delayActive = 1;
if (millis() - previousMillis > 10) {
delayActive = 0;
No.. The read deal is you are assuming that once you find a choice the machine won't check all the other choices as well. You need/should restructure your decision code to be more straight forward.
Think of temp as a line and you check different regions for actions.
(cel>15 && cel<20) See? This is a temp segment that can't be mixed up with (cel>0 && cel<11)
You are looking t open ended things (cel>0) and they will always overlap.
OK, i think i understand let me do some googling and come back.
Would i be right in saying i need to set the range i don't want the fan on, and some how say if the temperature is outside the range turn the fan on.
