I would like to improve my adc readings to its maximum capability, trying to understand if i'm there or not.
My code using ADC121C021:
#include <Wire.h>
#define ADDR_ADC121 0x50
#define V_REF 3.00
#define REG_ADDR_RESULT 0x00
#define REG_ADDR_ALERT 0x01
#define REG_ADDR_CONFIG 0x02
#define REG_ADDR_LIMITL 0x03
#define REG_ADDR_LIMITH 0x04
#define REG_ADDR_HYST 0x05
#define REG_ADDR_CONVL 0x06
#define REG_ADDR_CONVH 0x07
unsigned int getData;
float analogVal = 0;
Serial.println("ADC121C021");
Wire.begin(21, 22, 3400000);
init_adc();
read_adc();
void read_adc() {
Wire.beginTransmission(ADDR_ADC121); // transmit to device
Wire.write(REG_ADDR_RESULT); // get result
Wire.endTransmission();
Wire.requestFrom(ADDR_ADC121, 2); // request 2byte from device
if (Wire.available()) {
byte data = Wire.read(); // Read the received data
void init_adc() {
Wire.write(REG_ADDR_CONFIG); // Configuration Register
Wire.write(0x20);
I'm using 3.4Mhz for the i2c and according to datasheet ADC121C021 supports that. Why am I getting only 5kHz?
Using esp32(tiny pico) with this code gives me 18kHz:
#include <esp_adc_cal.h>
#define ADC1_CHANNEL_32 ADC1_CHANNEL_4 // GPIO32
#define ADC_WIDTH ADC_WIDTH_BIT_12 // ADC resolution
#define VREF_MV 3300 // Reference voltage in millivolts
esp_adc_cal_characteristics_t adc_chars;
uint32_t mic1Value;
adc1_config_width(ADC_WIDTH);
adc1_config_channel_atten(ADC1_CHANNEL_32, ADC_ATTEN_DB_11);
esp_adc_cal_value_t cal_type = esp_adc_cal_characterize(ADC_UNIT_1, ADC_ATTEN_DB_0, ADC_WIDTH, VREF_MV, &adc_chars);
mic1Value = adc1_get_raw(ADC1_CHANNEL_32);
Can I get better results?
