Why is there no official support for the ATmega328PB in the Arduino IDE? The processor is a typical AVR!
There are several packages (Pololu, Watterot, MiniCore, ...) with which the IDE is actually unnecessarily inflated!
I have a Nano clone with the ATmega328PB from China, it works as a "normal" Nano, but without being able to use its extended functions.
Do 'Arduino' make any boards that use the ATmega328PB ?
Good question! I remember a wish to replace the 328P with the newer 328 PB. This could give the "old" Nano another push.
There are at least three 328PB cores
by Pololu https://files.pololu.com/arduino/package_pololu_index.json
by AVR Home · AtmelUniversityFrance/atmel-avr-xmini-boardmanagermodule Wiki · GitHub.
All companies sell 328PB Arduino compatible boards, The AVR one is cheap (if available)
Don't forget the best of all (already mentioned in passing by @RudolfAtRTC):
it is simple to use a custom board with existing official boards package:
https://arduino.stackexchange.com/questions/54484/adding-a-custom-board-to-the-arduino-ide/
My experiance with MiniCore: It compiles, but the upload fails with all offered Programmer variants
In order to gather more information that might help us to troubleshoot your problem, I'm going to ask you to post the full output from the upload when in verbose mode.
Please do this:
- Select File > Preferences from the Arduino IDE's menus.
- Uncheck the checkbox next to Show verbose output during: [] compilation
- Check the checkbox next to Show verbose output during: [] upload.
- Click the OK button.
- Attempt an upload, as you did before.
- After the upload fails, copy the full text of the black console pane at the bottom of the Arduino IDE window and paste it in reply here.
To in0: A little late answer. I've done this many times. The output doesn't help me. I hope you see something ...
This is the full output from Arduino IDE 2.0.0 RC:
*Using board '328' from platform in folder: C:\Users\Rudol\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3*
*Using core 'MCUdude_corefiles' from platform in folder: C:\Users\Rudol\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3*
*Detecting libraries used...*
*"C:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR "-IC:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\pb-variant" "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD\\sketch\\ReadSignature.ino.cpp" -o nul*
*Alternatives for FileProperties.h: [FileProperties]*
*ResolveLibrary(FileProperties.h)*
* -> candidates: [FileProperties]*
*"C:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR "-IC:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\pb-variant" "-Id:\\Arduino\\libraries\\FileProperties" "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD\\sketch\\ReadSignature.ino.cpp" -o nul*
*Alternatives for LEDWrapper.h: [LEDWrapper]*
*ResolveLibrary(LEDWrapper.h)*
* -> candidates: [LEDWrapper]*
*"C:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR "-IC:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\pb-variant" "-Id:\\Arduino\\libraries\\FileProperties" "-Id:\\Arduino\\libraries\\LEDWrapper" "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD\\sketch\\ReadSignature.ino.cpp" -o nul*
*Using cached library dependencies for file: d:\Arduino\libraries\FileProperties\FileProperties.cpp*
*Using cached library dependencies for file: d:\Arduino\libraries\LEDWrapper\LEDWrapper.cpp*
*Generating function prototypes...*
*"C:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR "-IC:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\pb-variant" "-Id:\\Arduino\\libraries\\FileProperties" "-Id:\\Arduino\\libraries\\LEDWrapper" "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD\\sketch\\ReadSignature.ino.cpp" -o "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD\\preproc\\ctags_target_for_gcc_minus_e.cpp"*
*"C:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD\\preproc\\ctags_target_for_gcc_minus_e.cpp"*
*Compiling sketch...*
*"C:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR "-IC:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\pb-variant" "-Id:\\Arduino\\libraries\\FileProperties" "-Id:\\Arduino\\libraries\\LEDWrapper" "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD\\sketch\\ReadSignature.ino.cpp" -o "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD\\sketch\\ReadSignature.ino.cpp.o"*
*Compiling libraries...*
*Compiling library "FileProperties"*
*Using previously compiled file: C:\Users\Rudol\AppData\Local\Temp\arduino-sketch-97050FF78089F6E83E848D928F4AACAD\libraries\FileProperties\FileProperties.cpp.o*
*Compiling library "LEDWrapper"*
*Using previously compiled file: C:\Users\Rudol\AppData\Local\Temp\arduino-sketch-97050FF78089F6E83E848D928F4AACAD\libraries\LEDWrapper\LEDWrapper.cpp.o*
*Compiling core...*
*Using precompiled core: C:\Users\Rudol\AppData\Local\Temp\arduino-core-cache\core_bf8e19ac29e478b82e90056febb52153.a*
*Linking everything together...*
*"C:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -Wl,--gc-sections -mmcu=atmega328pb -o "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD/ReadSignature.ino.elf" "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD\\sketch\\ReadSignature.ino.cpp.o" "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD\\libraries\\FileProperties\\FileProperties.cpp.o" "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD\\libraries\\LEDWrapper\\LEDWrapper.cpp.o" "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD/..\\arduino-core-cache\\core_bf8e19ac29e478b82e90056febb52153.a" "-LC:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD" -lm*
*"C:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD/ReadSignature.ino.elf" "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD/ReadSignature.ino.eep"*
*"C:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD/ReadSignature.ino.elf" "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD/ReadSignature.ino.hex"*
*cmd /C "C:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objdump" --disassemble --source --line-numbers --demangle --section=.text "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD/ReadSignature.ino.elf" > "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD/ReadSignature.ino_atmega328pb_16000000L.lst"*
*Using library FileProperties in folder: D:\Arduino\libraries\FileProperties (legacy)*
*Using library LEDWrapper in folder: D:\Arduino\libraries\LEDWrapper (legacy)*
*"C:\\Users\\Rudol\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\Rudol\\AppData\\Local\\Temp\\arduino-sketch-97050FF78089F6E83E848D928F4AACAD/ReadSignature.ino.elf"*
*Sketch uses 5486 bytes (17%) of program storage space. Maximum is 32256 bytes.*
*Global variables use 533 bytes (26%) of dynamic memory, leaving 1515 bytes for local variables. Maximum is 2048 bytes.*
*Compilation complete.*
*"C:\Users\Rudol\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18/bin/avrdude" "-CC:\Users\Rudol\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3/avrdude.conf" -v -patmega328pb -carduino -PCOM3 -b115200 -D "-Uflash:w:C:\Users\Rudol\AppData\Local\Temp\arduino-sketch-97050FF78089F6E83E848D928F4AACAD/ReadSignature.ino.hex:i"*
*avrdude: Version 6.3-20201216*
* Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/*
* Copyright (c) 2007-2014 Joerg Wunsch*
* System wide configuration file is "C:\Users\Rudol\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3/avrdude.conf"*
* Using Port : COM3*
* Using Programmer : arduino*
* Overriding Baud Rate : 115200*
*avrdude: stk500_recv(): programmer is not responding*
*avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x02*
*avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x02*
*avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x02*
*avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x02*
*avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x02*
*avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x02*
*avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x02*
*avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x02*
*avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x02*
*avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x02*
*avrdude done. Thank you.*
*Upload error: Failed uploading: uploading error: exit status 1*
Compiling with the "old" IDE type 1.8.16 gives almost the same result, only the "resp" of avrdude is different.
C:\Users\Rudol\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18/bin/avrdude -CC:\Users\Rudol\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3/avrdude.conf -v -V -patmega328pb -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Rudol\AppData\Local\Temp\arduino_build_879656/ReadSignature.ino.hex:i
Using Port : COM3
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe9
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe9
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
ATmega328PB is not a drop-in replacement for ATmega328 variants, but a new device. However, the functions are backward compatible with the existing ATmega328 functions. Existing code for these devices will work in the new devices without changing existing configuration or enabling new functions.
In a world where there are ample 8-bit microcontrollers, I can understand why Arduino does not produce a -328PM model; there is unlikely market drivers to make such a board a profit for Arduino who is constantly in competition with clone manufactory. Perhaps a re-spin of the UNO formfactor due to a large commercial purchase (school, colleges, etc.) would provide a break-even opportunity.
SOAPBOX OPINION:
I read numerous forum posts and a very large numbed of posters are using clones primarily because they are less costly. Of course they are, they are copies or near replicas. Some companies do produce original "compatible" products BUT do they provide a costly forum to discuss problems and issues? Hosting is not free and with increase scrutiny on energy consumption due to global warming, electrical & cooling costs are going to increase.
Hobbyist have always been cost-conscious and prone to buy discounted in order to play at the hobby. Everyone understands to a degree buying clones - but, may I suggest that all design efforts and published/public projects use an Original Arduino. When it comes to replicating a working template for friends and family, cheap clones are inevitably prudent. Your initial purchase of all models of interest from Arduino will provide two important components:
- Increase sales by Arduino to defer operating costs;
- Focus on issues in these forums to concern regarding "real" hardware and not issues from 3rd party clone sloppiness or lack of Quality Assurance.
Regards,
Ray
This is the revenge of "open source"!
Again at In0; After a small change in the "boards.txt" file, the feedback from the upload was completely different.
The change (speed from 115200 to 57600):
328.menu.clock.20MHz_external=External 20 MHz
328.menu.clock.20MHz_external.upload.speed=57600
#328.menu.clock.20MHz_external.upload.speed=115200
Very strange: avrdude sees "0x1e950f" as the signature, every sketch "readsignature.ino" shows "Your AVR signature is 1E 95 16". Who is right now?
The display of the upload:
Sketch uses 5450 bytes (16%) of program storage space. Maximum is 32256 bytes.
Global variables use 526 bytes (25%) of dynamic memory, leaving 1522 bytes for local variables. Maximum is 2048 bytes.
C:\Users\Rudol\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18/bin/avrdude -CC:\Users\Rudol\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3/avrdude.conf -v -V -patmega328pb -carduino -PCOM3 -b57600 -D -Uflash:w:C:\Users\Rudol\AppData\Local\Temp\arduino_build_402180/ReadSignature.ino.hex:i
Using Port : COM3
Overriding Baud Rate : 57600
AVR Part : ATmega328PB
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
An error occurred while uploading the sketch
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: Expected signature for ATmega328PB is 1E 95 16
Double check chip, or use -F to override this check.
Have you burned the MiniCore bootloader to the atmega328PB? The original (old) Nano bootloader used 57600 baud.
to david_2018: That was exactly the right question. I've finally burned the bootloader and everything works. Thank you!
