I'm experiencing inconsistent behavior when moving the SPI transaction code from the .ino file to a source .cpp.
An Arduino Nano Every (Master) controlling a small PCB (Slave) with a 74HC595 that manages a 7-segment display.
┌── B ──┐ 7-segment display diagram
A C for explanation purposes
├── G ──┤
F D
└── E ──┘ DP
Case A: everything in a single file.
// 7-segment.ino
SPI.begin();
pinMode(6, OUTPUT);
digitalWrite(6, HIGH);
digitalWrite(6, LOW);
SPI.transfer(0b11111110);
delay(200);
SPI.transfer(0b11111111);
delay(200);
Result: Consistent blinking of segment F no matter how roughly the hardware is handled.
Case B: code split between source and header.
// 7-segment.ino
#include "ExCU_gear.h"
ExCU_Gear gearIndicator = ExCU_Gear(6);
gearIndicator.begin();
gearIndicator.sendRaw(0b11111110, true);
delay(200);
gearIndicator.sendRaw(0b11111111, true);
delay(200);
// ExCU_Gear.h
#ifndef ExCU_Gear_h
#define ExCU_Gear_h
#pragma once
#include <Arduino.h>
#include <SPI.h>
class ExCU_Gear
private:
uint8_t latchPin;
uint8_t last = NULL;
public:
ExCU_Gear(uint8_t latch_pin);
void begin();
bool sendRaw(uint8_t data, bool force = false);
#endif
// ExCU_Gear.cpp
ExCU_Gear::ExCU_Gear(uint8_t latch_pin)
latchPin = latchPin;
void ExCU_Gear::begin()
SPI.begin();
pinMode(latchPin, OUTPUT);
digitalWrite(latchPin, HIGH);
bool ExCU_Gear::sendRaw(uint8_t data, bool force)
if (data == last && !force)
return false;
digitalWrite(latchPin, LOW);
SPI.transfer(data);
last = data;
return true;
Result: Segment B blinks inconsistently (a second segment sparingly flashes at random) and everything breaks down when the cables are touched.
- Pads 1 through 5 connect to the Nano pins via cables
- VCC provided by external regulator (GND shared with Nano)
I have also tried using beginTransaction() instead of begin() with no success.
