Incorporating a push button to toggle LED effects in pre-existing code
Hello, I'm using an Arduino Mega 2560 for an LED array of 16 and two 74HC595 and I found some code that has quite a few effects that I absolutely love. I was wondering if there was a way to make it so that the code stays repeating one effect and switches to the next effect when a push button is pressed. Is this feasible to do? Below is my code:
int dataPin = 4;
int latchPin = 3;
int clockPin = 2;
int outputEnable = 5;
#define t1 10
#define t2 100
#define t3  50
//How many of the shift registers - change this
#define number_of_74hc595s 2
//do not touch
#define numOfRegisterPins number_of_74hc595s * 8
boolean registers[numOfRegisterPins];
  pinMode(dataPin, OUTPUT);
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(outputEnable, OUTPUT);
  clearLed(0);
  turnOutputsOn();
  effect_1(1);
  clearLed(0);
  effect_2(2);
  clearLed(0);
  effect_3(2);
  clearLed(0);
  effect_4(4);
  clearLed(0);
  effect_5(2);
  clearLed(0);
  effect_6(1);
  clearLed(0);
  effect_7(2);
  clearLed(0);
  effect_8(2);
  clearLed(0);
  effect_9(1);
  clearLed(0);
  effect_10(1);
  clearLed(0);
  effect_11(2);
  clearLed(0);
  effect_12(1);
  clearLed(0);
  effect_13(1);
  clearLed(0);
  effect_14(1);
  clearLed(0);
  effect_15(4);
  clearLed(0);
  effect_16(1);
  clearLed(0);
  effect_17(1);
  clearLed(0);
  effect_18(4);
  clearLed(0);
  effect_4(4);
//////////////////////////////////////////////////////////// Effect 1
void effect_1(int effectcount) {
  for (int i = 1; i <= effectcount; i++) {
    for (int i = 0; i < 4; i++) {
      registersWrite(i, HIGH);
      delay(200);
    clearLed(10);
    for (int i = 4; i < 7; i++) {
      delay(200);
    clearLed(10);
    for (int i = 7; i < 10; i++) {
      delay(200);
    clearLed(10);
    for (int i = 10; i < 13; i++) {
      delay(200);
    clearLed(10);
    for (int i = 13; i < 16; i++) {
      delay(200);
    clearLed(10);
/////////////////////////////////////////////////////////////Effect 2
void effect_2(int effectcount) {
    for (int i = 0; i < 16; i++) {
      delay(t1);
      registersWrite(i + 1, HIGH);
      delay(t1);
      registersWrite(i + 2, HIGH);
      delay(t1);
      registersWrite(i + 3, HIGH);
      delay(t1);
      registersWrite(i, LOW);
      delay(t1);
      registersWrite(i + 1, LOW);
      delay(t1);
    clearLed(0);
    for (int i = 15; i >= 0; i--) {
      delay(t1);
      registersWrite(i - 1, HIGH);
      delay(t1);
      registersWrite(i - 2, HIGH);
      delay(t1);
      registersWrite(i - 3, HIGH);
      delay(t1);
      delay(t1);
      registersWrite(i - 1, LOW);
      delay(t1);
////////////////////////////////////////////////////////Effect 3
void effect_3(int effectcount) {
  for (int j = 1; j <= effectcount; j++) {
      delay(50);
      delay(50);
//////////////////////////////////////////////////////////Effect 4
void effect_4(int effectcount) {
    byte led = 0b10101010;
    byte led1 = 0b10101010;
    digitalWrite(latchPin, LOW);
    shiftOut(dataPin, clockPin, MSBFIRST, led);
    shiftOut(dataPin, clockPin, LSBFIRST, led1);
    digitalWrite(latchPin, HIGH);
    delay(100);
    byte led2 = 0b01010101;
    byte led3 = 0b01010101;
    shiftOut(dataPin, clockPin, MSBFIRST, led2);
    shiftOut(dataPin, clockPin, LSBFIRST, led3);
    delay(100);
/////////////////////////////////////////////////////////Effect 5
void effect_5(int effectcount) {
    byte led = 0b11111111;
    byte led1 = 0b11111111;
    turnOutputsOn();
    delay(100);
    turnOutputsOff();
    delay(100);
/////////////////////////////////////////////////////////Effect 6
void effect_6(int effectcount) {
    int count = 16;
      clearLed(0);
      registersWrite(i, HIGH);  // chaser 1
      registersWrite(count, HIGH); // chaser 2
      count--;
/////////////////////////////////////////////////////////////Effect 7
void effect_7(int effectcount) {
    int count2 = 16;
      clearLed(0);
      registersWrite(count2, HIGH); // chaser 2
      registersWrite(count2 - 1, HIGH); // chaser 2
      count2--;
///////////////////////////////////////////////////////////////Effect 8
void effect_8(int effectcount) {
    unsigned int leds = 0B1111111111111111;
    turnOutputsOff();
    updateShiftRegister(leds);
    for (byte b = 255; b > 0; b--) {
      analogWrite(outputEnable, b);
      delay(8);
//////////////////////////////////////////////////////////////Effect 9
void effect_9(int effectcount) {
      for (int k = i; k < 16; k++) {
        registersWrite(k, HIGH);
        delay(100);
        registersWrite(k, LOW);
        delay(10);
      delay(20);
//////////////////////////////////////////////////////////////////Effect 10
void effect_10(int effectcount) {
      for (int k = 0; k < i; k++) {
        delay(20);
        delay(10);
      delay(20);
////////////////////////////////////////////////////////////Effect 11
void effect_11(int effectcount) {
      delay(30);
      registersWrite(i + 2, LOW);
      delay(30);
      registersWrite(i - 5, LOW);
    } clearLed(0);
      delay(30);
      registersWrite(i - 2, LOW);
      delay(30);
      registersWrite(i + 5, LOW);
///////////////////////////////////////////////////////////////Effect 12
void effect_12(int effectcount) {
    for (int i = 0; i < 8; i++) {
      for (int k = i; k < 8; k++)
        registersWrite(15 - k, HIGH);
        delay(20);
        registersWrite(15 - k, LOW);
        delay(20);
      registersWrite(15 - i, HIGH);
/////////////////////////////////////////////////////////////////Effect 13
void effect_13(int effectcount) {
    for (int i = 7; i >= 0; i--) {
      for (int k = 0; k <= i; k++)
        delay(20);
        delay(20);
////////////////////////////////////////////////////////////Effect 14
void effect_14(int effectcount) {
      delay(t3);
      delay(t3);
      delay(t3);
      delay(t3);
/////////////////////////////////////////////////////////////Effect 15
void effect_15(int effectcount) {
////////////////////////////////////////////////////////////Effect 16
void effect_16(int effectcount) {
      i = i + 1;
      delay(50);
    clearLed(20);
    for (int i = 17; i >= 0; i--) {
      int  j = i * 2;
      registersWrite(j, HIGH);
      delay(50);
      int  j = i * 2;
      registersWrite(j, LOW);
      delay(50);
////////////////////////////////////////////////////////////Effect 17
void effect_17(int effectcount) {
    unsigned int leds = 0B0101010101010101;
    turnOutputsOff();
    analogWrite ( outputEnable, 255 );
    for ( byte bright = 255; bright > 0; bright -= 5 ){
      analogWrite ( outputEnable, bright );
      delay ( 50 );
    analogWrite ( outputEnable, 0 );
    for ( byte bright = 0; bright < 255; bright += 5 ){
      delay ( 50 );
////////////////////////////////////////////////////////////Effect 18
void effect_18(int effectcount) {
      delay(10);
    for (int i = 16; i > 3; i--) {
void updateShiftRegister(unsigned int leds) {
  byte lowLED  = lowByte(leds);
  byte highLED = highByte(leds);
  shiftOut(dataPin, clockPin, MSBFIRST, highLED);
  shiftOut(dataPin, clockPin, MSBFIRST, lowLED);
void clearLed(int clearSpeed) {
    delay(clearSpeed);
void turnOutputsOn() {
  digitalWrite(outputEnable, LOW);
void turnOutputsOff() {
  digitalWrite(outputEnable, HIGH);
void registersWrite(int index, int value) {
  turnOutputsOn();
  for (int i = numOfRegisterPins - 1; i >=  0; i--) {
    digitalWrite(clockPin, LOW);
    int val = registers[i];
    digitalWrite(dataPin, val);
    digitalWrite(clockPin, HIGH);
  registers[index] = value;
  delay(5);
The code and circuit come from this link Arduino 74hc595 with 18 led effects.
Absolutely feasible. However, this code is implemented with delay() calls. Once a pattern starts you cannot read the button because the delays block the code. This will require a complete restructuring of the code. Fortunately once you implement one pattern and learn how to detect the button state the others should be easy to complete.
Each pattern should be implemented with a state machine and the millis() call. That way the button can be read every loop iteration without any blocking. Look at the following tutorials:
State Machine
BlinkWithoutDelay
Arduino Multiple Things
Several Things at a Time
looks like the code sequences through each possible effect instead of repeatedly executing one effect.
a switch statement can be used to repeatedly execute some desired effect based on the value of a variable.
recognizing button presses can be used to increment thru values of that variable. (you could call it a state machine, but it's not that complicated, and you only need to do one thing at a time, unless ...)
looks like some effects can take several seconds. it's not clear if you want to be able to switch between effects before one completes.
without significantly rewriting the code, a button may need to be pressed at the end of an effect for the button press to be recognized
