Unfortunately, the read range is inadequate. It is my understanding that by increasing the output power, the read range can be increased. Could I use a voltage amplifier between the RFID reader the and coil to increase the power and thus the read range?
Although I can't remember the make, I have seen RFID tags being read off cattle at a range of 500mm to 1 metre. You might want to look at the websites of agricultural suppliers to see if any meet your range requirements and then see if you can find out whats in them.
Right now, if I hold an RFID microchip, the reader picks up the chip at a radial distance of 6". However, I want the reader to be able to pick up a microchip embedded under the skin of my cat. When reading my cat's microchip, the reader can only pick up the chip when it's about 2" from the coil. Keep in mind, this isn't a radial distance of 2".
I would like to increase this range to a 2" radial read range.
Also, the Q factor can be increased by reducing the inductors resistance. What would happen in an RLC circuit if I ran a resistor in parallel to the inductor?
Grumpy_Mike:
Adding a R into a resonant circuit will lower its Q.
Connecting a resistor in any fashion into a resonant circuit will lower its Q. Series, parallel, sideways ...
The resistance of the inductor is in its wire. To reduce that resistance, you would need to use thicker wire in re-building the inductor. Which is where as Mike says, you need to be able to calibrate your new components.
Thicker wire, or litz wire. Litz wire is made of multiple strands of very small insulated wire, usually wrapped with some kind of fabric strands. It is NOT the same as stranded wire.
The insulation melts away with the heat of a soldering iron, so you just twist and solder the ends as if it were normal stranded wire.
As you go higher in frequency, the current becomes constrained increasingly in just the skin of the conductor. So larger wire gives you more surface area, but a lot of small wires can give you a -lot- more surface area in a smaller total diameter.
But if the strands aren't insulated from each other, then it acts like a single wire with grooves cut in it, making it worse than a single piece of solid wire.
