Hey there...
I have a question. I've been trying to index an SD Card. Bassically my plan is to have a functions which gives me two string arrays, one containing the short names, and one containing the long names.
I found this code
#include <SdFat.h>
SdFat sd;
const uint8_t SD_CS_PIN = SS;
// does not implement directory byte 12 for lowercase bits with 8.3 names.
// bit 0X10 means lowercase extension and bit 0X08 lowercase basename
void listLfn(SdBaseFile* dirFile) {
uint8_t offset[] = {1, 3, 5, 7, 9, 14, 16, 18, 20, 22, 24, 28, 30};
char name[13];
char lfn[131];
bool haveLong = false;
dir_t dir;
uint8_t i;
uint8_t lfnIn = 130;
uint8_t ndir;
uint8_t sum;
uint8_t test;
dirFile->rewind();
while (dirFile->read(&dir, 32) == 32) {
if (DIR_IS_LONG_NAME(&dir)) {
if (!haveLong) {
if ((dir.name[0] & 0XE0) != 0X40) continue;
ndir = dir.name[0] & 0X1F;
test = dir.creationTimeTenths;
haveLong = true;
lfnIn = 130;
lfn[lfnIn] = 0;
} else if (dir.name[0] != --ndir || test != dir.creationTimeTenths) {
haveLong = false;
continue;
char *p = (char*)&dir;
if (lfnIn > 0) {
lfnIn -= 13;
for (i = 0; i < 13; i++) {
lfn[lfnIn + i] = p[offset[i]];
} else if (DIR_IS_FILE_OR_SUBDIR(&dir)
&& dir.name[0] != DIR_NAME_DELETED
&& dir.name[0] != DIR_NAME_FREE) {
if (haveLong) {
for (sum = i = 0; i < 11; i++) {
sum = (((sum & 1) << 7) | ((sum & 0xfe) >> 1)) + dir.name[i];
if (sum != test || ndir != 1) haveLong = false;
SdFile::dirName(dir, name);
Serial.print(name);
if (haveLong) {
Serial.print(" ");
Serial.print(lfn + lfnIn);
} else if (dir.reservedNT) {
Serial.print(" 8.3 lowercase bits: ");
Serial.print(dir.reservedNT, HEX);
haveLong = false;
if (dir.name[0] == DIR_NAME_FREE) return;
haveLong = false;
if (!sd.begin(SD_CS_PIN)) sd.initErrorHalt();
// list files in root directory (volume working directory)
listLfn(sd.vwd());
Serial.println("Done");
void loop() {}
in this thread How to read full name of a file with SdFat - Storage - Arduino Forum
Which gives me all filenames of the root, but i need a funtion that i can call in the setup that would write the paths of all files to two array (short path array, and long path array), and i just can't get it figured out. The problem is i don't fully understand the code from that thread, which wouldn't be to much of an issue as long as it would work...
Anyhow, why i need to index the card, is because i'm trying to build an mp3 player which this shield SparkFun MP3 Player Shield - DEV-12660 - SparkFun Electronics and i don't want to have to name all the mp3 files "track1.mp3, track2.mp3, track3.mp3, etc." or similar. I want it to play whatever supported audiofiles it can find, and it should also be able to display the filename (the long one of course).
And so far it plays music just fine, but it doesn't play files that don't follow a certain "name rule", which is not the idea...
Anyhow, any help would be appriciated!
Thanks in advance!
Regards,
Delphiño
