russellz:
I don't think it will make much difference which capacitors you use. Heat sinking won't make much difference with the plastic casing. The esr you get will be a good order of magnitude lower than that of the coil if my guess of its dimensions is about right.Russell.
Thanks, Russell. I'll go with the larger of the two, and hope for the best as far as heating
