Hello there!
I am trying to use a BME280 sensor (pressure,temperature and humidity sensor) and store it's data into a text file that exists in an SD card. But i have come across many and different problems.
First of all, i am using a WeMos D1 mini as my microcontroller, the no-brand bme280 sesnsor (https://www.ebay.com/itm/GY-BME280-3-3-BME280-Atmospheric-Pressure-Humidity-Sensor-Mo
dule-Arduino-SPI-IIC-/361970198224) and the no-brand SD card shield for the wemos d1 mini.
I am trying to connect those two to the wemos as 2 slaves that i will supposedly switch between by pulling each select pin to LOW when i need it. But, I cannot seem to be able to get the SD to initialize. Ofcourse i have tested them separately and they work like charm.
I am connecting them like this:
WEMOS PINS SD SHIELD PINS BME280 PINS
D1 D5 (CLK) SCK
D2 D7 (MOSI) SDA(MOSI)
D3 - CSB
D4 D6 (MISO) SDO(MISO)
D8 D8 (CS) -
I am powering them both with 3.3V (which is the working voltage for both)
I am completely lost at this point, any help would be MUCH appreciated.
My code is like this
#include "SdFat.h"
SdFat SD;
#define BME_SCK D1
#define BME_MISO D4
#define BME_MOSI D2
#define BME_CS D3
#define SD_CS 8
File myFile;
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME280 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK); // software SPI
unsigned long delayTime;
pinMode(3, OUTPUT);
pinMode(8, OUTPUT);
digitalWrite(3, LOW);
if (!bme.begin()) {
Serial.println("Could not find a valid BME280 sensor, check wiring!");
while (1);
int temp = bme.readTemperature();
digitalWrite(3, HIGH);
Serial.print("Initializing SD card...");
digitalWrite(8, LOW);
if (!SD.begin(SD_CS,SPI_HALF_SPEED)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
myFile = SD.open("test1.txt", FILE_WRITE);
if (myFile) {
myFile.println(temp);
myFile.close();
Serial.println("done.");
Serial.println("error opening test1.txt");
// re-open the file for reading:
myFile = SD.open("test1.txt");
if (myFile) {
Serial.println("test1.txt:");
while (myFile.available()) {
Serial.write(myFile.read());
myFile.close();
// nothing happens after setup
