Information - *.hex - file
Good Morning,
Id like to know where i can find the file *.hex after arduino has been compiled or uploaded,
could you help me kindly with this ?
Thanks
gnusso
what os do you use?
Hi All,
I've change the "build.path=/" inside the preferences,
and after during the "verify" pushing "shift" during it I've seen that inside the folder is present a file named:
sketchname.cpp.hex
is enough for use normal programmer renaming file "in sketchname.hex" for use "ATMEGA328" with only minimal part ?
Thanks
Gnux
yes, if the target perfectly matches your setup
Perfect Thanks for the information,
Andrea
and If I would like make file with WIN 7 like operating system which is the procedure ?
thanks
gnux
