Information sending from Java to Arduino
Hi!
I want to send data from a Java program on my PC to an Arduino. I can send data to both direction, but I have some trouble with data sending to Arduino - sent data is incorrect.
Arduino code:
  if (Serial.available () > 0) {
    int solution = Serial.read();
    if (solution == 1) {
      soundVolumeVolt();
    else if (solution == 2) {
      FFTsound();
    delay(100);
void FFTsound() {
  /*SAMPLING*/
  microseconds = micros();
  for (int i = 0; i < samples; i++)
    vReal[i] = analogReadFast(CHANNEL);
    vImag[i] = 0;
    while (micros() - microseconds < sampling_period_us) {
      //empty loop
    microseconds += sampling_period_us;
  /* Print the results of the sampling according to time */
  //   Serial.println("Data:");
  //   PrintVector(vReal, samples, SCL_TIME);
  FFT.Windowing(vReal, samples, FFT_WIN_TYP_HAMMING, FFT_FORWARD);  /* Weigh data */
  //   Serial.println("Weighed data:");
  FFT.Compute(vReal, vImag, samples, FFT_FORWARD); /* Compute FFT */
  //   Serial.println("Computed Real values:");
  //   PrintVector(vReal, samples, SCL_INDEX);
  //   Serial.println("Computed Imaginary values:");
  //   PrintVector(vImag, samples, SCL_INDEX);
  FFT.ComplexToMagnitude(vReal, vImag, samples); /* Compute magnitudes */
  // Serial.println("Computed magnitudes:");
  PrintVector(vReal, (samples >> 1), SCL_FREQUENCY);
  double x = FFT.MajorPeak(vReal, samples, samplingFrequency);
  // Serial.println(x, 6); //Print out what frequency is the most dominant.
  //  while(1); /* Run Once */
  delay(2000); /* Repeat after delay */
// changing the register value of prescaler, for increase max samplingFreq, you can use it instead of analogRead
int analogReadFast(int CHANNEL) {
  byte ADCregOriginal = ADC0_CTRLC;
  ADC0_CTRLC = 0x54; // reduced cap, Vdd ref, 32 prescaler. See page 408 in the datasheet to change register value
  int adc = analogRead(CHANNEL);
  ADC0_CTRLC = ADCregOriginal;
  return adc;
void PrintVector(double *vData, uint16_t bufferSize, uint8_t scaleType)
  double numbers[16];
  for (uint16_t i = 0; i < bufferSize; i++)
    double abscissa;
    /* Print abscissa value */
    switch (scaleType)
      case SCL_INDEX:
        abscissa = (i * 1.0);
      case SCL_TIME:
        abscissa = ((i * 1.0) / samplingFrequency);
      case SCL_FREQUENCY:
        abscissa = ((i * 1.0 * samplingFrequency) / samples);
    //  Serial.print(abscissa, 6);
    if (scaleType == SCL_FREQUENCY)
      //   Serial.print("Hz");
      numbers[i] = {vData[i]}; //save calcuated magnnitudes data to array
    doc["Harmonic"][i] = numbers[i]; // creating json based on array
    //   Serial.print(" ");
    //   Serial.println(vData[i], 4);
  serializeJson(doc, Serial);
void soundVolumeVolt() {
  unsigned long startMillis = millis();
  unsigned int peakToPeak = 0;
  unsigned int signalMax = 0;
  unsigned int signalMin = 1024;
  while (millis() - startMillis < sampleWindow)
    sample = analogReadFast(CHANNEL);
    if (sample < 1024)
      if (sample > signalMax)
        signalMax = sample;
      else if (sample < signalMin)
        signalMin = sample;
  peakToPeak = signalMax - signalMin;
  Serial.println(peakToPeak);
Java code:
 package IRSend;
import com.fazecast.jSerialComm.SerialPort;
import java.io.*;
import com.google.common.collect.Lists;
import io.appium.java_client.MobileElement;
import io.appium.java_client.android.AndroidDriver;
import io.appium.java_client.android.AndroidElement;
import io.appium.java_client.android.nativekey.AndroidKey;
import io.appium.java_client.android.nativekey.KeyEvent;
import org.openqa.selenium.By;
import org.openqa.selenium.NoSuchElementException;
import org.openqa.selenium.remote.DesiredCapabilities;
import java.net.MalformedURLException;
import java.net.URL;
import java.util.*;
import java.util.concurrent.TimeUnit;
import org.json.*;
public class lkj {
    private static SerialPort chosenPort;
    private static BufferedReader input;
    static AndroidDriver<AndroidElement> driver;
    static Map< String, Object > driver_args = new HashMap< >();
    static List <AndroidElement> elements;
    public static void main(String[] args) {
        chosenPort = SerialPort.getCommPort("COM3");
        chosenPort.openPort();
        chosenPort.setBaudRate(9600);
        chosenPort.setComPortTimeouts(SerialPort.TIMEOUT_SCANNER, 0, 0);
        try {
            connect();
        } catch (Exception e) {
            System.out.println(e.getMessage());
        // Initialize report
        List<String> report = new ArrayList<>();
        report.add("ENG LOCAL:\n");
        jserialInputPreset();
        try {
            TimeUnit.SECONDS.sleep(2);
        } catch (InterruptedException e) {
            e.printStackTrace();
        jserialOutputPreset();
        chosenPort.closePort();
    private static void jserialInputEqual(){
        OutputStream output = chosenPort.getOutputStream();
        try {
            Thread.sleep(100);
        try {
            output.write(1);
            output.flush();
            Thread.sleep(100);
        } catch (IOException e) {
    private static void jserialInputPreset(){
        try {
            Thread.sleep(100);
        try {
            output.write(2);
            output.flush();
            Thread.sleep(100);
    private static void jserialOutputPreset() {
        try {
            Thread.sleep(100);
        String arduino = null;
        try {
            input = new BufferedReader(new InputStreamReader(chosenPort.getInputStream()));
            arduino = input.readLine();
            Thread.sleep(100);
        System.out.println(arduino);
    private static void dpad(AndroidKey key) {
        driver.pressKey(new KeyEvent(key));
    private static MobileElement findElementByImage(String using) {
        try {
            return driver.findElementByImage(using);
        } catch (NoSuchElementException e) {
            return null;
    private static AndroidElement findElementWrapper(String using) {
        try {
            return driver.findElement(By.id(using));
            return null;
    private static AndroidElement findElementByXPathWrapper(String using) {
        try {
            return driver.findElementByXPath(using);
            return null;
    public static void connect() throws MalformedURLException {
        DesiredCapabilities dc = new DesiredCapabilities();
        dc.setCapability("deviceName", "komagome");
        dc.setCapability("noReset", "true");
        dc.setCapability("platformName", "Android");
        dc.setCapability("platformVersion", "9");
        URL url = new URL("http://127.0.0.1:4723/wd/hub");
        driver = new AndroidDriver < AndroidElement > (url, dc);
        driver.manage().timeouts().implicitlyWait(5, TimeUnit.SECONDS);
        System.out.println("Application started....");
The logic of the code is simple - Java sends the number (int), Arduino receive it and fulfills the condition. But the condition was never met. This is hard to debug because I can’t open the serial monitor of the Arduino when I’m communicating with my Java program. So I added Serial.println(solution). If I enter 1 in Arduino terminal, that shows 49, if I enter 1 via Java output.write(1);and receive it, Java terminal shows 1. I know, that Serial.read() takes on values in ASCII, so I tried method Serial.parseInt(), but it doesn't work either.
I think the problem is in Java code, but I can't detect it. I have been doing programming not so long ago, so please describe your answers in detail. I checked similar topic and there was problem in end marker, but I don't know how to create it.
Thanks in advance!
I do not know what Java sends. I know nothing of that language.
If you are receiving ASCII for 1 then use '1' in your if.
if (solution == '1')
I tried this method, but it does not work(
Thank you.
my understanding is the above reads a single byte, but your java code may be sending an int, 4 bytes. but intel processors are little-endian, so should send the LSB first
you have a 100 ms delay. why?
and how is the serial bit rate set/determine in the java code? is it 9600?
Instead of
try
output.println("2");
instead that will send 2 as text with a new line following (avoids BigEndian/LittleEndian problems)
Then in the Arduino
try
String input;
  Serial.println(F("soundVolumeVolt"));
void FFTsound() {
  Serial.println(F("FFTsound"));
String input;
  input = Serial.readStringUntil('\n'); // block here for 1sec each loop looking for input
  // if nothing will return empty input
  input.trim(); //remove and \r and leading/trailing white space
  if (input.length() > 0) { // got something
    if (input == "1") {
      soundVolumeVolt();
    } else if (input == "2") {
      FFTsound();
      Serial.println(F("Invalid"));
      // invalid input ignore
      // flash led??
For debugging try just writing back to the Serial and picking it up in the Java
Delay is a habit for me, because sometimes Arduino slow down from the loop, we can delete the delay in this case.
Initialization of serial port in java
OutputStream class hasn't prinln method, only bitwise data transfer, but i tried to use symbol class PrintWritter in Java, and Serial.parseInt() in Arduino. it's work!
Java code:
        PrintWriter outArduino = new PrintWriter(chosenPort.getOutputStream());
        try {
            Thread.sleep(100);
        outArduino.print(2);
        outArduino.flush();
Arduino code:
    int solution = Serial.parseInt();
      soundVolumeVolt();
      FFTsound();
    else {
      Serial.println("loh");
    delay(100);
Thanks all!
