INFRARED Sending raw codes
Hello guys, I want send a IR signal to turn my lamp ON/OFF, I used a example from IRremote library (IRrecvDumpV2) and I got this with my IR receiver:
Encoding  : UNKNOWN
Code      : A32AB931 (32 bits)
Timing[23]:
     +1200, - 450     +1250, - 450     + 400, -1250     +1200, - 450
     +1250, - 450     + 400, -1250     + 400, -1250     + 400, -1250
     + 400, -1250     + 400, -1250     + 400, -1250     +1250
unsigned int  rawData[23] = {1200,450, 1250,450, 400,1250, 1200,450, 1250,450, 400,1250, 400,1250, 400,1250, 400,1250, 400,1250, 400,1250, 1250};  // UNKNOWN A32AB931
The encoding is unkown, so, I tried to send it as raw with this example:
#include <IRremote.h>
IRsend irsend;
  int khz = 38; // 38kHz carrier frequency for the NEC protocol
  unsigned int irSignal[] = {1200,450, 1250,450, 400,1250, 1200,450, 1250,450, 400,1250, 400,1250, 400,1250, 400,1250, 400,1250, 400,1250, 1250}; //AnalysIR Batch Export (IRremote) - RAW
  irsend.sendRaw(irSignal, sizeof(irSignal) / sizeof(irSignal[0]), khz); //Note the approach used to automatically calculate the size of the array.
  delay(1000); //In this example, the signal will be repeated every 5 seconds, approximately.
It's not turning it on, what's the problem? Thanks
Bumping threads is discouraged in the forum guidelines.
