Hello folks,
i bought a glcd from digole (http://www.digole.com/index.php?productID=844) and got it working with the digole library and a mighty 1284. Since this package uses an additional PCB to drive the lcd and there is no good documentation of the library about how to raise the spi clock (seems to use Software SPI at a low clock rate, very slow if you want to switch a page like 100-200ms) we cut all connections to the PIC on the PCB in order to drive the glcd manually (http://www.digole.com/index.php?productID=537) with the u8glib. It worked out but the output is mirrored, can´t find any function for mirroring in the u8glib either so i guess this is an initialisation problem ?
#include "U8glib.h"
//SPI Com: SCK = 13, MOSI = 11, CS = 10, RS/A0 = 9
//U8GLIB_64128N u8g(13, 11, 10, 9); // throws pefect image, after 1 second it switches to mirrored
U8GLIB_LM6059 u8g(13, 11, 10, 9); //screen split in half
//U8GLIB_LM6063 u8g(13, 11, 10, 9); //frame is shifted by 2-3 pixels
//U8GLIB_NHD_C12864 u8g(13, 11, 10, 9);//throws black screen
//U8GLIB_DOGM128 u8g(13, 11, 10, 9); //throws black screen
void draw(void) {
// graphic commands to redraw the complete screen should be placed here
u8g.setFont(u8g_font_unifont);
// u8g.setFont(u8g_font_osb21);
u8g.drawStr( 20, 22, "Hello world");
u8g.drawStr( 45, 35, "with");
u8g.drawStr( 38, 54, "u8glib");
u8g.drawFrame(0,0,128,64);
void setup(void) {
// flip screen, if required
//u8g.setRot180();
void loop(void) {
// picture loop
u8g.firstPage();
do {
draw();
} while( u8g.nextPage() );
// rebuild the picture after some delay
Any help would be appreciated
