Initializing argument 3 of 'void HardwareSerial::begin(long unsigned int, SerialConfig, SerialMode, uint8_t)' 87 | void begin(unsigned long bau
Hi i'm new to arduino programming, and i'm not sure what i've done wrong. Please, help me
#define DEBUG true
#include <ESP8266WiFi.h>
#include <ArduinoJson.h>
#include "ApiHandler.h"
String serverIP = "";
String API_ENDPOINT = "/api/location/";
String lats;
String longi;
String msg;
const char* ssid = "";
const char* password = "";
const int TX_pin = ?;
const int RX_pin = ?;
WiFiClient client;
ApiHandler apiHandler(client);
uint16_t dataDelay = 60000;
  connectToWiFi();
  Serial1.begin(115200, SERIAL_8N1, TX_pin, RX_pin);
  msg = "";
  msg = sendData("AT", 1000, DEBUG);
  while ( msg.indexOf("OK") == -1 ) {
    Serial.println("Trying");
  msg = "";
  msg = "";
  msg = sendData("AT+GPSLP = 2", 2000, DEBUG);
    msg = sendData("AT+GPSLP = 2", 1000, DEBUG);
  msg = "";
  msg = sendData("AT+SLEEP = 1", 2000, DEBUG);
    msg = sendData("AT+SLEEP = 1", 1000, DEBUG);
  if (WiFi.status() == WL_CONNECTED) {
    readGPS();
    Serial.println("WiFi Disconnected. Reconnecting...");
    connectToWiFi();
  delay(dataDelay);
void readGPS() {
  Serial1.println("AT+LOCATION=2\r\n");
  delay(2000);
  String response = "";
  while (Serial1.available()) {
    response += (char)Serial1.read();
    delay(1);
  int index = response.indexOf("2");
  if (index != -1) {
    response = response.substring(index + 5);
    int commaIndex = response.indexOf(',');
    if (commaIndex != -1) {
      lats = response.substring(0, commaIndex);
      longi = response.substring(commaIndex + 1, commaIndex + 9);
      String response = apiHandler.sendPostRequest(serverIP + API_ENDPOINT, lats, longi);
      Serial.println(response);
void connectToWiFi() {
  WiFi.mode(WIFI_STA);
  Serial.println("Connecting to WiFi");
  WiFi.begin(ssid, password);
  int attempts = 0;
  while (WiFi.status() != WL_CONNECTED && attempts < 20) {
    Serial.print(".");
    attempts++;
  Serial.println("");
    Serial.print("Connected to WiFi network with IP Address: ");
    Serial.println("Failed to connect to WiFi. Please check your credentials or restart the device.");
String sendData(String command, const int timeout, boolean debug)
  String temp = "";
  Serial1.println(command);
  long int time = millis();
  while ( (time + timeout) > millis())
      char c = Serial1.read();
      temp += c;
  if (debug)
    Serial.print(temp);
  return temp;
end this is error:
initializing argument 3 of 'void HardwareSerial::begin(long unsigned int, SerialConfig, SerialMode, uint8_t)'
   87 |     void begin(unsigned long baud, SerialConfig config, SerialMode mode, uint8_t tx_pin)
exit status 1
Compilation error: invalid conversion from 'int' to 'SerialMode' [-fpermissive]
the statement
looks like code for setting up Serial1 on a ESP32
if you are using an ESP8266 and require a second serial port have a look at espsoftwareserial
also have a look at the section on serial in ESP8266 nodemcu-details-specifications
