Hello Everyone,
I have a project with SIM800L, Keypad(4x4) and LCD(16x2). I want to input phone number with keypad(number phone - 12 digits) show to LCD, set that to a variable to send sms to another number phone. Please help me complete project, Thank you!
Please show us your work to date.
Always show us a good schematic of your proposed circuit.
Show us a good image of your ‘actual’ wiring.
Give links to components.
In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch.
Use the < CODE / > icon from the ‘posting menu’ to attach the copied sketch.
I'm a newbie and i just coding arduino recently. My project now complete call and send sms to someone, but i need to change the phone number to another and set as a variable when i need. i don't know this.
#include <SoftwareSerial.h>
//Create software serial object to communicate with SIM800L
SoftwareSerial mySerial(3, 2); //SIM800L Tx & Rx is connected to Arduino #3 & #2
const int pinButton = 11;
int running = 0;
pinMode(pinButton, INPUT);
//Begin serial communication with Arduino and Arduino IDE (Serial Monitor)
//Begin serial communication with Arduino and SIM800L
mySerial.begin(9600);
Serial.println("Initializing...");
mySerial.println("AT"); //Once the handshake test is successful, it will back to OK
updateSerial();
int stateButton = digitalRead(pinButton);
if (stateButton == 1 && running == 0)
Serial.println("BUTTON PRESSED");
updateSerial();
mySerial.println("AT+CMGF=1");
updateSerial();
mySerial.println("AT+CMGS=\"+phone number\"");
updateSerial();
mySerial.print("Message");
updateSerial();
mySerial.write(26);
delay(100);
running ++;
delay(100);
else if (stateButton == 1 && running >= 1 && running <= 6)
mySerial.println("ATD+ +phone number;");
updateSerial();
delay(60000);
mySerial.println("NO ONE PICKUP");
delay(100);
mySerial.println("ATH"); //end call
updateSerial();
delay(100);
mySerial.println("END CALL");
running ++;
Serial.println("END CODE");
void updateSerial()
while (Serial.available())
mySerial.write(Serial.read());//Forward what Serial received to Software Serial Port
while(mySerial.available())
Serial.write(mySerial.read());//Forward what Software Serial received to Serial Port
Please edit your post #4, select all code and click the <CODE> button to apply so-called code tags and next save your post. It makes it easier to read, easier to copy and the forum software will display it correctly.
