This seems pretty simple to implement, but having trouble wrapping my mind around it -
I have 6 button inputs, I'd like to record buttons pressed, the timing of the presses, and then replay them. Essentially this, but with 6 morse buttons instead of one (not my code, btw):
// repeats what you do
const byte morseBtn = 4;
const byte modeBtn = 6;
const byte slowerBtn = 8;
const byte fasterBtn = 10;
const byte led = 9;
const byte sampleLength = 1; // 1 ms
const byte maxSamples = 100;
boolean inRecordMode = false;
boolean wasInRecordMode = false;
// buffers to record state/duration combinations
boolean states[maxSamples];
int durations[maxSamples];
int currentSampleCycles;
short idxPlayback = 0;
short idxRecord = 0;
float playbackMultiplier = 1.0; // 0.5=>double speed, 2.0=>half speed
const float speedStep = 0.0005;
pinMode(modeBtn, INPUT);
pinMode(morseBtn, INPUT);
pinMode(fasterBtn, INPUT);
pinMode(slowerBtn, INPUT);
pinMode(led, OUTPUT);
void resetForRecording() {
// reset record buffers
memset(states, 0, sizeof(states));
memset(durations, 0, sizeof(durations));
idxRecord = 0; // reset record idx just to make playback start point obvious
// reset playback markers
idxPlayback=0;
currentSampleCycles=0;
inRecordMode = digitalRead(modeBtn);
if(inRecordMode == true) {
if(!wasInRecordMode) {
resetForRecording();
recordLoop();
// continue playing loop
playbackLoop();
wasInRecordMode = inRecordMode; // record prev state for next iteration so we know whether to reset the record arr index
void recordLoop() {
boolean state = digitalRead(morseBtn);
digitalWrite(led, state); // give feedback to person recording the loop
if(states[idxRecord] == state) {
// state not changed, add to duration of current state
durations[idxRecord] += sampleLength;
// state changed, go to next idx and set default duration
idxRecord++;
if(idxRecord == maxSamples) { idxRecord = 0; } // reset idx if max array size reached
states[idxRecord] = state;
durations[idxRecord] = sampleLength;
delay(sampleLength); // slow the loop to a time constant so we can reproduce the timelyness of the recording
void playbackLoop()
if(digitalRead(fasterBtn)) {
playbackMultiplier-=speedStep;
if(digitalRead(slowerBtn)) {
playbackMultiplier+=speedStep;
// play the loop back at the desired speed without blocking the loop
if(currentSampleCycles == 0 && durations[idxPlayback] != 0) {
// state changed
digitalWrite(led, states[idxPlayback]); // set led
if(idxPlayback == maxSamples) {
// EOF recorded loop - repeat
idxPlayback=0;
if(durations[idxPlayback]*playbackMultiplier <= currentSampleCycles) {
// EOF current sample in recorder buffer
idxPlayback++; // move to next sample
currentSampleCycles = 0; // reset for next sample
// still in same sample, but in next cycle (==sampleLength approx)
currentSampleCycles++;
delay(sampleLength); // keep time same as we had for record loop (approximately)
Conceptually I think I understand it, but... again, troubles. Attempting to roll my own, but so far no luck. Has anyone written code like this yet? Any thoughts/advice?
Thanksfolks.
